04 F250 request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by a26rock, this thread has received 1 replies and been viewed 1091 times.
post #1 of 2 (permalink) Old 02-20-2009, 03:34 AM Thread Starter
1ftnw21p54ed40023
Thank you
a26rock is offline
post #2 of 2 (permalink) Old 02-20-2009, 04:14 PM
4play's Avatar
here ya go,
OASIS RESULT:
1FTNW21P54ED40023
02/20/2009
12:12:34
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS AN OPEN CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/14/2004 BUILD DATE
04/28/2004 SALE MILEAGE
00059
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0712 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: MARK FREDERICK
OPTIONS:
EXPIRATION DATE: 05/14/2006
DISTANCE: 37,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07967
ESP CONTRACT START DATE: 05/14/2004
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
02/09/2009
DEALER: Atlantic Ford Truck Sales, Inc
WARRANTY CLAIM NUMBER: 110984 ODOMETER: 073829M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 8A616AA CLUTCH ASY-FAN A/C 001 081103A 42 DOES NOT OPERATE PROPERLY
4C3Z 9P456AF COOLER - EGR 001 081103B
VC 5 003 081103D
000 081103G
73829 1263 02-10-09 VERIFY CONCERN.PERFORM VISUAL INSPECTION AND FOUND WATER STAINS ON RIGHT SIDE EXHAUST MANIFOLD.CHECKED OASIS FOR TSB OR SSM AND FOU ND TSB FOR LOOSING COOLANT.PRESSURE TEST AND COOLANT RUNNING OUT OF EXHAUST AND ENGINE LOCKED UP.REMOVED GLOW PLUGS AND TURNED ENGINE OVER TO GET COO LANT OUT OF CYLINDER.PERFORMED PRIOR APPROVAL.IT HAS BEEN 24 HOURS AND HAVE
10/08/2008
WARRANTY CLAIM NUMBER: 109610 ODOMETER: 070152M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 081103A 42 DOES NOT OPERATE PROPERLY
VC 7B 003 081103B
F81Z 8287EA CLAMP ASY-RAD HOSE 001 081103G
70152 FAILED EGR COOLER VERIFIED CONCERN. VISUAL INSPECTION. ENGINE WILL NO T CRANK OVER. FOUND TSB 08-11-03 FOR COOLANT LOSS. DIAG AND APPLIED FOR PRI OR APPROVAL, CODE PAAEN. VENTED CYLINDERS, REPLACED EGR COOLER UNDER SPW RE PLACED LAST MAY 19TH.
05/19/2008
WARRANTY CLAIM NUMBER: 107830 ODOMETER: 066375M
LABOR OP
CONDITION CODE
CONDITION DESC
VC 7B 002 081103B
4C4Z 8592AA CONNECTION-CYL HD WA 001
6C3Z 5A231AA CLAMP-MUFFLER 001
6C3Z 6K786CA CLAMP AIR COOLING 001
66389 1263 05-23-08 VERIFIED COMPLAINT. DRAINED OUT ABOUT 1GAL OF WATER. RU STED DEGAS BOTTLE. REMOVED EGR VALVE AND PRESSURE TESTED. FOUND WATER IN I NTAKE MANIFOLD. HEADS AND HEAD GASKETS HAVE BEEN REPLACED. REPLACED EGR COO LER. ROAD TESTED NO POWER AND BLACK SMOKE. P0401, P0403, P0405, P2262 AND U0306. REPROGRAMMED FICM AND ROAD TESTED, STILL BLACK SMOKE AND NO POWER. D
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 3 6N06 000302 V3C3Z 99501A42 BAA B66 42 2729
AWS Claim Key: 1506912 Trx Code: 2 Labor Hrs: 2
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2004 Doc #:561219A
Cust Comments: CUST STATES AER INSTALLED TONNEAU COVER CAME LOOSE ON FRONT HINGE AND SLID FORWARD AND DAMAGED CAB & TONNNEAU COVER & PLASTIC BED CAPS...SERVICE PART WARRANTY SEE INV# 108737 5 22 04 316
Tech Comments: REPLACE TONNEAU COVER FRONT HINGE CAME LOOSE ON TONNEAU COVER ALLOWING COVER TO SLIDE FORWARD AND CAUSING DAMAGE TO REAR OF CAB AND MOLDINGS.TONNEAUCOVER HINGE WHERE IT MOUNTS TO TONNEAU COVER WAS LOOSE AND DID NOT HOLD.THIS IS A PART DEFECT
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 3 6Y05 000001 * MAINT * A99 82 4988
AWS Claim Key: 1529635 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2004 Doc #:562782A
Cust Comments: 5000 MILES (8000 KMS) MAINT. L
Tech Comments: 4988 1.2 ROTATED 8 LUG TIRES WHEELS. CHANGED OIL AND FILTER. DIESEL.
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 7 5K06 * * * * * * 10948
AWS Claim Key: 2565519 Trx Code: 04C07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-NOV-2004 Doc #:569328B
Cust Comments: RECALL# 04C07 GOODYEAR ATS TIRE INSPECTION REPLACEMENT
Tech Comments: 10948 RECALL 04C07 .2 HRS PERFORMED RECALL 04C07A INSPECTED ALL 4 TIRES NO REPLACEMENT NECESARY HAVE LOAD RATE E LF TIRE MKB9 BXEV 0504 RF TIRE MKB9 BXEV 0304 LR TIRE MKB9 BXEV 0304 RR TIRE MKB9 BXEV 0504 SPARE XLW8 E423 0704
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 7 6Y05 000001 * MAINT * A99 82 10948
AWS Claim Key: 2565518 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-NOV-2004 Doc #:569328A
Cust Comments: 10000 MILES (16000 KMS) MAINT. L
Tech Comments: 10948 PERFORMED 10000 MILE MAINT AND PERFORMED MULTI POINT INSP
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 10 3A03 * * * * * * 14935
AWS Claim Key: 4370496 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2005 Doc #:576944A
Cust Comments: 04B24 TRANSMISSION REVERSE PLANET REPLACEMENT
Tech Comments: 14935 RECALL 04B24N 6.4 TIME TO RR TRANS TO INSPECT INSTALL KT 1 REPLACE FITERS RE FILL ROAD TEST PER RECALL
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 10 6Y05 000001 * MAINT * A99 82 14935
AWS Claim Key: 4370497 Trx Code: 0712S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2005 Doc #:576944C
Cust Comments: 15000 MILES (24000 KMS) MAINT. L DIESEL OIL CHANGE, ROTATE TIRES, REPLACE FUEL FILTERS, GENERAL CK OVER
Tech Comments: 14935 15000 TIME TO CHANG OLF FUEL FILTERS,ROTATE TIRES
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 15 6Y05 000001 * MAINT * A99 82 18714
AWS Claim Key: 6094878 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-JUL-2005 Doc #:585727A
Cust Comments: 20000 MILES (32000 KMS) MAINT. L
Tech Comments: 18714 CHANGED OIL AND FILTER, ROTATED TIRES
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 17 * * * * * * * 21975
AWS Claim Key: 7100345 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:590099C
Cust Comments: RECALL 59B01 ONE TIME TEST DRIVE
Tech Comments: 21975 RECALL 59B01A 0.3 TIME TO ROAD TEST CK OUT ALL OK PER RECALL
AWS Claim Key: 7100343 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:590099A
Cust Comments: RECALL 05S34 FUEL INJECTOR MODULE WIRING HARNESS REPAIR
Tech Comments: 21975 RECALL 05S34F 1.3 TIME TO INSTALL BOTH REPAIRE KITS PER RECALL NO CHAFING ROAD TEST ALL OK
AWS Claim Key: 7100344 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:590099B
Cust Comments: RECALL 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT OBD SYSTEM RECALIBRATION
Tech Comments: 21975 RECALL 05E15G 1.3 TIME REPLACE EBP SENSOR AND CONECTOR REFLASH PERRECALL
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 19 6Y05 000001 * MAINT * A99 82 25169
AWS Claim Key: 7807671 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07967 - * Name: FORD COUNTRY OF LEWISVILLE Ph: 972-2212900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2005 Doc #:594278A
Cust Comments: 25000 MILES (40000 KMS) MAINT. L
Tech Comments: 25169 PERFORMED 25K CHANGED OIL AND FILTER ROTATE TIRES
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 26 3A15 0701XX 4C3Z 7G383 AA P59 41 35027
AWS Claim Key: 9578712 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04843 - * Name: MAROONE FORD OF FORT LAUDERDALE Ph: 954-5643221 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2006 Doc #:959392A
Cust Comments: W CUST STATES TRANS IN REVERSE DELAYS BOUNCES
Tech Comments: TRANS DIAG R R PAN NEC TO OH VALVE BODY STICKING AND REP SOLENOIDS ALSO STICKING
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 27 1C03 03XXXX 5C3Z 6079 C D50 42 36098
AWS Claim Key: 9944045 Trx Code: E72 Labor Hrs: 16.5
Dlr Cd-Sub Cd: 04843 - * Name: MAROONE FORD OF FORT LAUDERDALE Ph: 954-5643221 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-JUL-2006 Doc #:963395A
Cust Comments: W CUST STATES ENGINE LOOSING COOLANT BLOWS WHITE SMOKE ADVISE
Tech Comments: PERFORM DIAG PER TSB PRESSURE TEST R R HEADS BLOWNAND EGR COOLER
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 27 1H03 030008 4C3Z 9F452 A D50 42 36333
AWS Claim Key: 9977882 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 04843 - * Name: MAROONE FORD OF FORT LAUDERDALE Ph: 954-5643221 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2006 Doc #:964420A
Cust Comments: W CUST STATES ENGINE RUNS ROUGH BLOWS SMOKE LACKS POWER SEE ATTACHED
Tech Comments: RUN ENG PERF DIAG FOUDN EGR SPRING WEAK REP VALVE AND REPROGRAM PCM
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 38 1A01 030102 3C3Z 6049 CARM L87 D1 56912
AWS Claim Key: 11865573 Trx Code: E72 Labor Hrs: 16.8
Dlr Cd-Sub Cd: 04843 - * Name: MAROONE FORD OF FORT LAUDERDALE Ph: 954-5643221 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2007 Doc #:991375A
Cust Comments: CUST STATES COOLANT BLOWING OUT OF COOLANT BOTTLE ALSO FAN KICKS ON OFTEN CHECK AND ADVISE
Tech Comments: PERFORM DIAG PER TSB 071405 FOUND HEADGASKETS LEAKING R R HEADS CHECK FLATNESS .040 VARIANCE REP 2 HEADS AND EGR COOLER AND GASKETS
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 46 6Y20 000001 * MISC * A99 82 63320
AWS Claim Key: 12433785 Trx Code: P98 Labor Hrs: 0
Dlr Cd-Sub Cd: 04843 - * Name: MAROONE FORD OF FORT LAUDERDALE Ph: 954-5643221 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2008 Doc #:021259A
Cust Comments: P98 REFUND FOR POWRETRAIN DEDUCTABLE PER FORD
Tech Comments: REFUND PER FORD FOR 991375
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 49 1H03 030804 4C3Z 9P456 AF D50 42 66375
AWS Claim Key: 12673701 Trx Code: E72 Labor Hrs: 8.8
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 954-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2008 Doc #:107830A
Cust Comments: D50, ENGINE BLOWING WHITE SMOKE(CHECK FOR CAUSE AND ADVISE)
Tech Comments: 66389 1263 05 23 08 VERIFIED COMPLAINT. DRAINED OUT ABOUT 1GAL OF WATER. RUSTED DEGAS BOTTLE. REMOVED EGR VALVE AND PRESSURE TESTED. FOUND WATER IN INTAKE MANIFOLD. HEADS AND HEAD GASKETS HAVE BEEN REPLACED. REPLACED EGR COOLER. ROAD TESTED NO POWER AND BLACK SMOKE. P0401, P0403, P0405, P2262 AND U0306. REPROGRAMMED FICM AND ROAD TESTED, STILL BLACK SMOKE AND NO POWER. DATA
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 54 1H03 030804 4C3Z 9P456 AF D50 42 70152
AWS Claim Key: 12926479 Trx Code: E88 Labor Hrs: 10.2
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 954-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-OCT-2008 Doc #:109610A
Cust Comments: CUST CLAIMS OF ALOT OF WHITE SMOKE(REFER TO RO 107830)
Tech Comments: 70152 FAILED EGR COOLER VERIFIED CONCERN. VISUAL INSPECTION. ENGINE WILL NOT CRANK OVER. FOUND TSB 08 11 03 FOR COOLANT LOSS. DIAG AND APPLIED FOR PRIOR APPROVAL, CODE PAAEN. VENTED CYLINDERS, REPLACED EGR COOLER UNDER SPW REPLACED LAST MAY 19TH.
1FTNW21P54ED40023 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-APR-2004 14-MAY-2004 152007 USA 58 1H03 030804 4C3Z 9P456 AF D42 42 73829
AWS Claim Key: 13072711 Trx Code: E72 Labor Hrs: 11.3
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 954-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2009 Doc #:110984A
Cust Comments: CUST CLAIMS OF COOLNAT COMSUMPTION,ALOT OF WHITE SMOKE COMMING OUT OF TAIL PIPE
Tech Comments: 73829 1263 02 10 09 VERIFY CONCERN.PERFORM VISUAL INSPECTION AND FOUND WATER STAINS ON RIGHT SIDE EXHAUST MANIFOLD.CHECKED OASIS FOR TSB OR SSM AND FOUND TSB FOR LOOSING COOLANT.PRESSURE TEST AND COOLANT RUNNING OUT OF EXHAUST AND ENGINE LOCKED UP.REMOVED GLOW PLUGS AND TURNED ENGINE OVER TO GET COOLANT OUT OF CYLINDER.PERFORMED PRIOR APPROVAL.IT HAS BEEN 24 HOURS AND HAVE NOT HEARD
4play is offline
F250 Oasis request please! F250 4x4freak Ford Oasis requests 1 02-12-2009 09:12 PM
OASIS Request: 2005 F250 6.0 PSD jmerlet Ford Oasis requests 1 11-28-2007 05:16 PM
2006 F250 request surfdunn Ford Oasis requests 0 11-23-2007 05:18 PM
ok will 20 in. 07 f250 rims fitt on my 03 f250 ? 03f250 General Ford Truck and Excursion 7 03-02-2007 02:23 PM
2005+ f250 factory wheels on a 2004 f250 4wd kline925 General Ford Truck and Excursion 2 10-16-2006 05:46 PM
