04 6.0 request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ofc. Garcia, this thread has received 1 replies and been viewed 765 times.
post #1 of 2 (permalink) Old 02-23-2009, 12:31 AM Thread Starter
1FTNW21P84EB56467
Thanks in advance!
Thomas
Ofc. Garcia is offline
post #2 of 2 (permalink) Old 02-23-2009, 04:57 AM
4play's Avatar
OASIS RESULT:
1FTNW21P84EB56467
02/23/2009
00:54:47
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
31 ENGINE CALIBRATION
WARNING MESSAGES
OTHER WTYS MAY APPLY/REACQUIRED VEH WTY EXP 09-05-2006 DISTANCE 21845
*** ERROR *** could not find named value for: [arn_message]
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/01/2004 BUILD DATE
11/21/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
09/15/2008
DEALER: Matthews-Currie Ford Company
WARRANTY CLAIM NUMBER: 002927 ODOMETER: 058342M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 7823394AA DRIVE ASY-PWR LIFT W 001 40374B 01 BROKEN/CRACKED
VERIFY REAR WINDOW INOP REMV TRIM PANEL REPLACE BRKN WINDOW REGULATOR ASSY R ETEST PASS
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 0 * * * * * * * 6
AWS Claim Key: 211829 Trx Code: TDE Labor Hrs: 0
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2003 Doc #:05711351
Cust Comments: MISSING POWER STROKE STICKER CC16196 0496378218 11 30 2003
Tech Comments: MISSING NO CHARGE
AWS Claim Key: 211830 Trx Code: TDE Labor Hrs: 0
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2003 Doc #:05711352
Cust Comments: MISSING LONG SHINEY TYPE VALVE CAPS CC57086 0496378218 11 30 2003
Tech Comments: 0 NO CHARGE
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 4 2G05 031405 * RECAL * D13 42 4941
AWS Claim Key: 1911741 Trx Code: 2 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2004 Doc #:335666A
Cust Comments: CUSTOMER STATES VEHICLE HAS ROUGH IDLE.
Tech Comments: 4941 PERFORM DIESEL ENGINE PERFORMANCE WORKSHEET, REPROGRAM PCM TO LATEST CALIBRATION PER SSM 17032 17048 (4U7A.12A650.BJA) FILE NAME (VXBC3H6), ROAD TEST RETEST PASS...409
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 5 1H03 030008 3C3Z 9J460 AA D21 42 6393
AWS Claim Key: 2152988 Trx Code: S07 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2004 Doc #:337096A
Cust Comments: CUSTOMER STATES VEHICLE STALLS AT A LIGHT AT TIMES.
Tech Comments: 6393 PERFORM DIESEL ENGINE PERFORMANCE WORKSHEET, WDS HOOK UP EEC TEST P0472 EBP LOW VOLTAGE, POINPOINT TEST, REPLACE EBP EXHAUST BACK PRESSURE SENSOR, ROAD TEST RETEST P1000...409
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 12 6Y20 000079 * RAV * A99 82 9645
AWS Claim Key: 5399289 Trx Code: RAV Labor Hrs: 1
Dlr Cd-Sub Cd: 00783 - * Name: BILL CURRIE FORD LINCOLN MERCURY Ph: *-* St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2005 Doc #:70562501
Cust Comments: PERFORM RAV INSPECTION
Tech Comments: RAV INSPECTION
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 12 2B01 030707 3C3Z 12K073 AA D21 28 9645
AWS Claim Key: 5399288 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 00783 - * Name: BILL CURRIE FORD LINCOLN MERCURY Ph: *-* St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2005 Doc #:70562503
Cust Comments: STALL QUITS ACCEL ALL ENG TEMP CC D21
Tech Comments: DIESLE PERFORMANCE TESTS,REPLACE CAM POSITION SENSOR AND VGT SENSOR,OPEN CRKT P0341
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 15 * * * * * * * 9765
AWS Claim Key: 6209142 Trx Code: 05S34 Labor Hrs: 1
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUL-2005 Doc #:08377240
Cust Comments: 05S34 FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
Tech Comments: INSTALL FICM REPAIR KIT
AWS Claim Key: 6209143 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUL-2005 Doc #:08377251
Cust Comments: 59B01
Tech Comments: CUST ASSURANCE TEST DRIVE
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 15 2E06 030008 4C3Z 9F838 AB D21 42 9824
AWS Claim Key: 6269532 Trx Code: S07 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2005 Doc #:08404151
Cust Comments: CUST STATES VEH STALLS OUT WHILE DRIVING SEE HISTORY TN 103
Tech Comments: CUST STATES VEH STALLS OUT INTERMITANTLY PERFORM DIESEL DIAG MONITOR DATA LOGGER AND TEST DRIVE TO DUPLICATE CONCERN. ICP SENOSR READING DROPPED AND STALLS REPLACE ICP SENSOR. REPROGRAM PCMTCM AND FICM WITH LATEST CALBRATION VERIFY 60 REPAIR AND TEST DRIVE AND RECHECK OK
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 17 * * * * * * * 11571
AWS Claim Key: 7294749 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2005 Doc #:08815740
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Tech Comments: EP SESOR AND RECALIBRATION
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 19 7N02 011105 4C3Z 1523394 AA G07 42 13433
AWS Claim Key: 7801598 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2005 Doc #:09078051
Cust Comments: CUST STATES REAR WINDOW WILL NOT CLOSE AFTER BEING OPEN INSTALL SOP TN 104 USE SPO 05314013
Tech Comments: VERIFY CUST CONCERN REAR POWER SLIDING WINDOW INTER INOP REMOVE REAR INTERIOR TRIM TO REPLACE MOTOR REGULATOR ASSY. RETEST PASS
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 23 5V01 060301 * 1125 * N27 13 18962
AWS Claim Key: 9091005 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2006 Doc #:09888052
Cust Comments: CUSTOMER STATES THERE IS A BRAKE PULSATION
Tech Comments: VERIFY PU7LSATION RESURFACE FT ROTORS TO ELIMINATE PULSATION . REROAD TEST VERIFY CONCERN
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 25 7N02 011105 4C3Z 1523394 AA G07 42 20753
AWS Claim Key: 9458412 Trx Code: E89 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:00168251
Cust Comments: OWNER STS REAR SLIDER INOP ADVISE.
Tech Comments: REGULATOR DRIVE ASSEMBLY REAR DOOR WINDOW REGULATOR ELECTRIC REPLACE R AND R REAR WINDOW TO ACESS REGULATOR AND MOTOR REPLACE RETEST PASS
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 31 1D02 031001 3C3Z 9433 AA L65 D8 28561
AWS Claim Key: 10750927 Trx Code: S07 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2006 Doc #:01137652
Cust Comments: OWNER STATES THAT THERE IS A CLEAR OILY SUBSTANCE LEAKING MIDDLE OF THE ENGINE COMPARTMENT
Tech Comments: VERIFY CONCERN PERF DIAG LEAK AT EGR COOLER REPL RETEST PASS
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 36 1A02 030102 * 6051 * L87 42 35216
AWS Claim Key: 11670192 Trx Code: E84 Labor Hrs: 21.3
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2007 Doc #:00352004
Cust Comments: CUSTOMER STATES CLEAR COLORED FLUID LEAK UNDER FRONT OF VEHICLE
Tech Comments: HEAD GASKT LEAKING CP: 6051 VERIFY CONCERN FND COOL HAD BEEN LKG FROM DEGAS THROUGH CAP PERF CL SYS PRESS NO EXTERNAL LKS FND PERF DIAG PERF EGR TST FAIL REMV CLEAN RETEST PER 061906 FAIL REPL EGR PERF COMB TST FAIL PERF COMP TST PERF DAIG PER 06 21 02 EOT 212 DEG ECT 204 DEG PRESS OVER 19PSI REMV CYL HDS FND GSKT LKG INSP HD AND BLK BNCH TST EGR CLR OK REPL HD GSKT REASSM PE
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 36 2G05 031405 * RECALEM * P66 04 35216
AWS Claim Key: 11670193 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2007 Doc #:00352005
Cust Comments: CUSTOMER STATES VEHICLE SEEMS TO SHIFT HARSHLY
Tech Comments: UPDATE NEEDED CP: RECALEM VERIFY CONCERN PERF TRANS DIAG PER TSB 05 17 16 PERF SHIFT STRAT RELEARN PROCED RETEST PASS
1FTNW21P84EB56467 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2003 01-JUN-2004 124901 USA 53 7N02 011105 6C3Z 7823394 AA G07 01 58342
AWS Claim Key: 12883818 Trx Code: P05 Labor Hrs: 1
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2008 Doc #:00292701
Cust Comments: BODY SHOP WARRANTY C/S POWER WINDOW BACK GLASS INOP WILL NOT OPEN
Tech Comments: VERIFY REAR WINDOW INOP REMV TRIM PANEL REPLACE BRKN WINDOW REGULATOR ASSY RETEST PASS
4play is offline
Ofc. Garcia (02-23-2009)
Request Please Inthesticks Ford Oasis requests 1 01-30-2008 12:32 AM
request please shawnrans Ford Oasis requests 1 01-11-2008 06:11 PM
request. Rcannon Ford Oasis requests 1 10-23-2007 01:31 AM
Request Please!! dotson90 Ford Oasis requests 1 01-08-2007 02:33 AM
