build sheet for a 2004 Excursion... please!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by olslyfox, this thread has received 1 replies and been viewed 814 times.
post #1 of 2 (permalink) Old 02-24-2009, 09:10 PM Thread Starter
contemplating buying a 2004 Excursion
need a build sheet for vin #
1FMNU44P34ED59064
particular interest is locking differential?
Thx!!
Larry
olslyfox is offline
post #2 of 2 (permalink) Old 02-25-2009, 04:56 AM
4play's Avatar
3.73 ratio, limited slip rear, not gonna get started on build sheets
OASIS RESULT:
1FMNU44P34ED59064
02/25/2009
00:54:14
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/03/2004 BUILD DATE
05/18/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
07/15/2008
DEALER: Sames Crow Ford Lincoln Mercur
WARRANTY CLAIM NUMBER: 591928 ODOMETER: 044148M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7210BBA LEVER GEAR SHIFT 001 7210A 01 BROKEN/CRACKED
44148 CONFIRMED END OF TOW- HAUL SHIFT LEVER BROKEN REMOVED LOWER DASH PANE L. REMOVED IGNITION CYLINDER. REMOVED TILT LEVER AND COLUMN COVERS RELACED SHIFT LEVER. REASSEMBLED.
| On-line 1878
END OF OASIS REPORT FOR 1FMNU44P34ED59064
4play is offline
olslyfox (02-28-2009)
build sheet?? BIG C 2008-2010 6.4L Power Stroke 8 02-18-2009 10:06 PM
Oasis report & Build sheet, Thanks parasail Ford Oasis requests 1 07-06-2007 01:28 AM
OASIS report and build sheet please 389SixPack Ford Oasis requests 2 06-25-2007 03:50 PM
Oasis report & Build sheet, if possible. Thanks parasail Ford Oasis requests 2 06-15-2007 02:17 AM
VIN# Check, Build Sheet. Thanks in advance! parasail General GM Truck Forum 2 05-01-2007 03:08 PM
