Oasis Help 03 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by madvan, this thread has received 2 replies and been viewed 570 times.
post #1 of 3 (permalink) Old 03-03-2009, 07:34 PM Thread Starter
Oasis Help 03
Need a report on a 2003 6.0 diesel.
1FTSW31P03ED27297
Thanks in advance for any help.
Bill
madvan is offline
post #2 of 3 (permalink) Old 03-03-2009, 09:21 PM
4play's Avatar
OASIS RESULT:
1FTSW31P03ED27297
03/03/2009
17:20:54
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/30/2003 BUILD DATE
05/07/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0711 - EXPIRED
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: CHRISTINE DAVIS
OPTIONS:
EXPIRATION DATE: 05/30/2008
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 47433
ESP CONTRACT START DATE: 05/30/2003
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 4 3A11 070100 3C3Z 7000 GK P59 69 9931
AWS Claim Key: 2823030 Trx Code: 1 Labor Hrs: 7.1
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-SEP-2003 Doc #:101048A
Cust Comments: VEC CUTS OUT WHEN PUT IN DRIVE SLIPS IN REVERS SLIPPING IN DRIVE YESTERDAY TOW HAUL LIGHT FLASHES VEC HOPS IN REVERSE
Tech Comments: 5977 TRANS SLIPS OUT OF GEAR. DIAG TESTS KOER KOEOCODE P2700 P2701 P2703 P2552 P0730 P0148, TRANS PRESSURE, REPLACE TRANSMISSION, RETEST AND CLEAR CODES OK. FOUND METAL IN PAN SPOKE WITH HOTLINE AND THEY ADVISED TO REPLACE TRANS HOTLINE #31XHZ003
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 9 2A01 031201 3C3Z 9N622 AA G29 28 18064
AWS Claim Key: 4516479 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2004 Doc #:107114A
Cust Comments: CUST STATES CHECK AIR FILTER LIGHT ON
Tech Comments: 5977 AIR FILTER MINDER LIGHT ON. TEST AND REPLACE MINDER
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 13 7B02 140201 4C3Z 10346 AA C25 28 23997
AWS Claim Key: 6271901 Trx Code: E83 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-MAY-2004 Doc #:111859A
Cust Comments: DIED ON SIDE OF ROAD,CUST STATES BATTERY LIGHT WAS FLASHING,
Tech Comments: 5977 VEH STALLED OUT. TEST BATTERIES 0 VOLTS, CHARGE BOTH BATTERIES 45 MIN RETEST BATT 1.14 V, NEC TO REPLACE BOTH BATTERIES DRAWN DOWN FROM BAD ALTERNATOR, TEST ALTERNAOTR 10 VOLTS, REPLACE ALTERNAOTR
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 14 1D01 030008 3C3Z 6701 AA L65 D1 25933
AWS Claim Key: 6806498 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2004 Doc #:113014B
Cust Comments: OIL LEAK UNDER VEH,
Tech Comments: 5977 OIL LEAK UNDER VEH. WHILE TRANS OUT ON LINE ATEST FOR OIL LEAK AND FOUND REAR MAIN SEAL LEAKINGREPLACE SEAL
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 14 3A11 070100 3C3Z 7000 GKRM P51 49 25933
AWS Claim Key: 6823770 Trx Code: E90 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2004 Doc #:113014A
Cust Comments: TOWED IN ,HOPS IN REVERSE,DELAYS GOING IN GEAR,SLIPS WHEN SHIFTING ,CUST
Tech Comments: 5977 VEH SLIPS WHEN SHIFTING AND HOPS IN REVERSE. ELEC TRANS TEST, REMOVE TRANS PAN FOUND METAL IN SYSTEM, INSPECT AND FOUND TRANS CASE WORN CLUTCHES BURNED AND SOLENOIDS FILLED WITH METAL, CALL HOTLINE#3IXHZ003 ADVISED TO ORDER TRANS, INSTALL REMAN TRANS WITH COOLER AND INLINE FILTER KIT, RECHECK OK. TRANS INSTALLED ON RO 101048 WAS FROM THE FACTORY AND CAME WITH NO COOLER OR KIT IT WS OK TO FLSH
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 14 2A01 031201 3C3Z 9N622 AA G29 42 26041
AWS Claim Key: 6842040 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-JUL-2004 Doc #:113832A
Cust Comments: AIR FILTER INDICATOR COMES ON,PART UNDER HOOD FELL APART,
Tech Comments: 5977 AIR FILTER WARNING LIGHT ON. TEST AND REPLACEAIR FILTER MINDER
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 15 2G05 031405 * RECAL * P59 42 28096
AWS Claim Key: 7338365 Trx Code: E84 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2004 Doc #:115217B
Cust Comments: BANGS HARD COMING TO STOP ,CUST STATES
Tech Comments: 5977 VEH SHIFTS HARD ON DOWN SHIFT. DIESEL DIAG TESTS 1 15 NO CODES, REPROGRAM PCM, ROAD TEST OK
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 17 7S06 030008 3C3Z 12B637 BA D50 28 31137
AWS Claim Key: 8200977 Trx Code: S07 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-OCT-2004 Doc #:117061E
Cust Comments: ENGINE RUNS ROUGH,CUST STATES S.O.P HARNESS
Tech Comments: DIESEL DIAG TEST 1 THRU 15.FOUND CHAFFED ENGINE HARNESS.R AND I AIR FILTER HOUSING,FAN,FAN SHROUD,INTERCOOLER PIPES,AC COMPRESSOR.REPLACED ENGINE WIRING HARNESS.RETEST OK.
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 17 7G02 120203 4C3Z 18476 BA E23 42 31137
AWS Claim Key: 8131474 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-OCT-2004 Doc #:117061A
Cust Comments: COOLANT SMELL THROUGH AC VENTS ON ACCEL ,CUST STATES
Tech Comments: PRESSURE LEAK TEST,FOUND COOLANT LEAK BEHIND DASH.R AND R HEATER CORE AND REFILLED COOLANT.RETEST OK
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 19 3Y11 070701 YC3Z 7G360 AA P82 42 34630
AWS Claim Key: 9031778 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 02956 - * Name: AL PACKER FORD WEST Ph: 561-7901100 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-DEC-2004 Doc #:120180A
Cust Comments: SHIFT ON FLY DOESNT WORK ,CUST HAS TO MANUALLY ENGAGE HUBS
Tech Comments: 9813 SHIFT ON FLY INOP. EEC TEST, REPLACE SHIFT MOTOR INOP
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 48 * * * * * * * 58066
AWS Claim Key: 15067180 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03475 - * Name: PALATKA FORD LINCOLN-MERCURY Ph: 386-3288881 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2007 Doc #:05077241
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: 06E17 RECALL REPROGRAM PCM, TCM, AND FICM
AWS Claim Key: 15067179 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03475 - * Name: PALATKA FORD LINCOLN-MERCURY Ph: 386-3288881 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2007 Doc #:05077240
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: 59B01 RECALL CUSTOMER ASSURANCE TEST DRIVE REPLACE
1FTSW31P03ED27297 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 07-MAY-2003 30-MAY-2003 124219 USA 50 1H03 030804 3C3Z 9P456 AE D42 D8 60438
AWS Claim Key: 15415899 Trx Code: E72 Labor Hrs: 20.1
Dlr Cd-Sub Cd: 03475 - * Name: PALATKA FORD LINCOLN-MERCURY Ph: 386-3288881 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-JUN-2007 Doc #:053487B
Cust Comments: CUST STATES WHILE DRIVING LOST POWER AND ENGINE QUIT.
Tech Comments: PERFORM DIESEL DIAG FOR NO START,NO ICP PRESSURE,HOOK UP BLOCK OFF TOOLS,PPT ICP,REPLACE IPR VEH STARTS,PERFORM PERFORMANCE TEST TEST PRESSURE AT DEGAS EXCESSIVE,R&R HEADS & GASKETS,ROAD TEST OK
4play is offline
madvan (03-03-2009)
post #3 of 3 (permalink) Old 03-03-2009, 11:18 PM Thread Starter
Thanks 4play!!!
Can now see why its a low mileage truck.
Bill
madvan is offline
