2004 F350 Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cjmair, this thread has received 8 replies and been viewed 1533 times.
post #1 of 9 (permalink) Old 03-04-2009, 04:31 PM Thread Starter
2004 F350 Report
I was hoping to have an Oasis report pulled on a vehicle I just bought and am having a lot of problems with. The VIN is 1ftsw31p04ed05494.
Thank you very much,
Chris
cjmair is offline
post #2 of 9 (permalink) Old 03-05-2009, 05:32 AM
4play's Avatar
OASIS RESULT:
1FTSW31P04ED05494
03/05/2009
01:30:41
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/17/2004 BUILD DATE
04/04/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
09/08/2008
DEALER: Brent Brown Ford Lincoln Mercu
WARRANTY CLAIM NUMBER: 002690 ODOMETER: 056071M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9G489AARM KIT TRBCH CTR HSG RO 001 081613F 42 DOES NOT OPERATE PROPERLY
W302677 001
W302676 001
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001
XL 2 MOTORCRAFT BATTERY 001
PM 4B BATTERY ASY 001
PM 2 MOTORCRAFT BATTERY 001
W705589S 004
4.0 081613F INTALLED TURBO REPLAMENT PARTS AS PER TSB
09/08/2008
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 8620DB BELT-W/PUMP FAN&GENE 001 1007D 42 DOES NOT OPERATE PROPERLY
3C2Z 6B209AA TENSIONER FEAD ASSY 001 6209A
7C3Z 8678B PULLEY ASY-BELT IDLE 001 8616A
5C3Z 8509A PULLEY WATER PUMP 001
4C3Z 8A616AA CLUTCH ASY-FAN A/C 001
WARRANTY, RAN COMPLETE NVH DIAG FOUND BELT PULLEYS AND BELT GLAZZED A ND WORN REMOVED FAN, FAN CLUTCH. REPLACED FAN CLUTCH RE MOVED SERP BELT. DRIVE PULLEY AND TENSIONER AND WATER PUMP PULLEY RE TES TED RE ASSEMBLED RE TESTD OK
07/21/2008
WARRANTY CLAIM NUMBER: 001694 ODOMETER: 054610M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089BA ACTUATOR ASSY 001 6005F 42 DOES NOT OPERATE PROPERLY
4C3Z 9J460A SENSOR ASY EGR PR VL 001 6005F1X1
5C3Z 12224A 3 WAY VACUUM CONNECT 001 6005F2
3L3Z 12B579AB SENSOR EEC MASS AIR 001 6005F6
000 6005F8
000 6005F13
000 6005F18B
000 6005F21
000 6005F23
000 12650D25
000 6089A
000 12650D9
000 12650D84
WARRANTY,RAN EEC DIAG FOUND CODES P0299 P0470 P0404 P0405 RAN PIN POINT TESTS REMOVED AND REPLACED VGT SNESOR, AND MASS AIR FLOW SENSOR RE TEST DR OVE FOUND EBP VOLTAGE CHANGING ERRATIC REMOVED AND REPLACED EBP SENSOR AND REPLACED EBP WIRING CONNECTOR REPROGRAMED PCM, TCM, FICM, RE TEST ED , FUEL PRESSURE OK 47 OIL SYSETEM PASS RE KOEO KOER ALL TESTS PASS
07/21/2008
WARRANTY CLAIM NUMBER: 001661 ODOMETER: 054610M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F1 42 DOES NOT OPERATE PROPERLY
000 6005F1X1
000 6005F2
000 6005F6
000 12650D30
RAN EEC DIAG FOUND CODES P0401 P0404 P0405 P1335 RAN PINPT TESTS; REPROGRAMM ED PCM TCM FICM TO LATEST CALI. REKOEO KOER EGR FAILS. REMOVED EGR VALVE FOUND PLUGGED UP REPL EGR VALVE ADN RE KOEO KOER ALL TESTS PASS AT THI S TIME. RETEST DROVE OK PERFORMED DIAG STEPS
4play is offline
cjmair (03-15-2009)
post #3 of 9 (permalink) Old 03-05-2009, 12:29 PM Thread Starter
Thank you very much. I really do appreciate the time it took to run this report for me.
cjmair is offline
post #4 of 9 (permalink) Old 03-05-2009, 01:21 PM Thread Starter
I have a quick question. This report only goes back one year, is that normal for a history report? Thanks for all the help you guys do.
cjmair is offline
post #5 of 9 (permalink) Old 03-05-2009, 02:28 PM
4play's Avatar
see the last line where is says "Click Here for Full Warranty History" that part of the website is down. it should be back up later on today and i will post it when its back up.
4play is offline
cjmair (03-15-2009)
post #6 of 9 (permalink) Old 03-05-2009, 04:18 PM Thread Starter
Great, I was just curious. Thank you for all the help.
cjmair is offline
post #7 of 9 (permalink) Old 03-05-2009, 04:41 PM
4play's Avatar
ok here is the rest of it...lots
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 6 2E02 030408 3C3Z 9N693 JA L65 D8 7493
AWS Claim Key: 3870383 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2005 Doc #:56212001
Cust Comments: CUSTOMER STATES HAS OIL LEAK DIAG AND FIX LAST OIL CHANGE 2000 MILES AGO
Tech Comments: CHECKED OUT ADDED DYE TO ENGINE OIL AND BLACKLIGHT TESTED FOUND LEAK FROM CAM POS SENSOR ORINGS REPLACED ORINGS AND
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 6 2H02 030008 3C3Z 6F089 AA D42 42 7493
AWS Claim Key: 3896935 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2005 Doc #:56212002
Cust Comments: CUSTOMER STATES SEEMS TO SURGE AT 75 80MPH
Tech Comments: CHECKED OUT RAN 6.0 PERFORMANCE DIAG FOUND STICKING VGT SOLE REPLACED VGT AND UPDATED PCM TO LATEST CALIBRATION ALL OK.
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 6 3A03 * * * * * * 7493
AWS Claim Key: 3870382 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2005 Doc #:56212003
Cust Comments: CUSTOMER HAS RECALL # 04B24 REVERSE PLANET GEAR
Tech Comments: 1 PERFORM RECALL ONLY KIT 1 WAS NEEDED.OPER 04B24N 6.4 HRS.
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 7 2G04 031401 * 12A650 * D42 04 9160
AWS Claim Key: 4512583 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2005 Doc #:56369901
Cust Comments: CUSTOEMR STATES LACK OF POWER DIAG AND FIX
Tech Comments: WARRANTY, RAN PERFORMANCE DIAG NO CODES I PERFORMED AN REPROGRAM ON THE PCM, TCM, AND FICM RE TESTED OK
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 10 1G04 030008 5C3Z 8509 A N11 30 13443
AWS Claim Key: 6022883 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:56758101
Cust Comments: CST STATES THERE IS A NOISE COMING FROM THE ENGINE AREA WHILE RUNNING.
Tech Comments: PERFORMED TSB 05 13 16 051316A 1.3
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 10 2E02 030408 3C3Z 9N693 HA L65 D1 13443
AWS Claim Key: 6022882 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:56758102
Cust Comments: CST STATES THERE OIL LEAK COMING FROM THE ENGINE PASS SIDE.
Tech Comments: ADDED DYE TO ENGINE OIL AND BLACKLIGHT TESTED FOUND OIL LEAK FROM CAM SENSOR ORINGS AND FROM LOW PRESSURE OIL PUMP REG. CAP ORING REPLACED ORINGS TEST DROVE ALL OK.
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 10 * * * * * * * 13443
AWS Claim Key: 6022881 Trx Code: 05S34 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:56758103
Cust Comments: CST REQUEST TO HAVE THE RECALL 05 S 34 COMPLETED.
Tech Comments: COMPLETED RECALL 05S34E 1.2 05S34G 0.3 W 2 DAYS RECALL RENTAL $100.00
AWS Claim Key: 6022880 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:56758104
Cust Comments: PERFORM RECALL 59B01
Tech Comments: 1 TEST DRIVE AFTER RECALLS PERFORMED
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 13 * * * * * * * 16674
AWS Claim Key: 6865277 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2005 Doc #:57135102
Cust Comments: CUSTOMER HAS RECALL # 59B01 TEST DRIVE
Tech Comments: 1 PERFORMED TEST DRIVE AS PER RECALL 59B01A.
AWS Claim Key: 6865278 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2005 Doc #:57135101
Cust Comments: CUSTOMER HAS RECALL # 05E15 EXHAUST BACK PRESSURE SENSOR
Tech Comments: 1 REPLACED EBP SENSOR AND CONNECTOR. REPROGRAMMED PCM AS PER RECALL 05E15G.
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 17 1H03 030008 * 9F452 * D36 42 22080
AWS Claim Key: 8339097 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2006 Doc #:57789901
Cust Comments: CUSTOMER STATES WHILE DRIVING TRUCK WAS SURGING AND SEEM TO BLOW BLACK SMOKE, ALSO RUNS ROUGH DIAG AND FIX
Tech Comments: CHECKED OUT RAN 6.0L PERFORMANCE GUIDE SHEET DIAG WITH TEST DRIVE FOR INTERMITANT DIAG PERFORMED PINPOINT TESTS W9 W13 FOUND STICKING EGR VALVE REPLACED EGR VALVE AND CLEANED EGR PASSAGEWAYS REPEATED ALL OPERATION CODES AND TIMES AS FOLLOWS 6005F 0.4 6005F13 0.2 6005F1 0.1 6005F2 0.1
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 19 1G03 030507 * 8620 * N11 33 24372
AWS Claim Key: 8884933 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:58104101
Cust Comments: CUSTOMER STATES THAT THERE IS A REALLY BAD SQUEAKING NOISE COMING FROM THE BELT SYSTEM, DIAGNOSE AND ADVISE
Tech Comments: WARRATNY,DEGLAZED THE BELT AND INSTALLED DRESSIG RE TSTED OK
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 24 1H03 030804 4C3Z 9J460 A D42 42 31217
AWS Claim Key: 10193615 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2006 Doc #:58768501
Cust Comments: CUSTOMER STATES; VEHICLE DIES AND RUNS POORLY ROUGH HAPPENS INTERMIT.
Tech Comments: WARRANTY,I RAN IDS PERFORMANCE DIAG FOUND CODES P0470 ONLY, WHILE MONITORING PID MONITOR WHILE DRIVING FOUND THE MAP SENSOR IS WAY OUT OF RANGE, REPLACED MAP AND EBP RE TEST DROVE OK, AL PERFORMED STEPS 1 2 3 4 5 6 7 8 9 10A 12A 13 14 15
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 34 1H03 030008 5C3Z 9F452 AA D42 42 40620
AWS Claim Key: 11683378 Trx Code: S07 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 07805 - * Name: PREMIER FORD LINCOLN MERCURY, INC. Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:04-JUN-2007 Doc #:59619401
Cust Comments: GUEST STATES THE ENGINE LACKS POWER SURGES AND BLOWS SMOKE WHILE DRIVING DIAG AND ADVISE
Tech Comments: WARRANTY,IRAN EEC DIAG FOUND THE TRUCK HAS NO POWER AND SURG ING WHILE DRIVING, IRAN PERFORMANCE DIAG FOUND THE FUEL PRESSURE 50 UNDER LOAD OIL SYSTEM PASS. RAN PIN POINT TESTS AND FOUND THE EGR VA RE TESTED FOUND THE MASS AIR AND EBP ALSO OUT OF RANGE WHILE DRIVING REMOVED AND REPLACED EGR VALVE AND EBP SENSOR RE TEST DROVE RE QUICK TESTED OK PERFORMED STEPS 1 2 3 4 5 6A 6B 8 10A 11 12A 13 15 I A
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 47 1H03 030008 4C3Z 9F452 A D42 42 54610
AWS Claim Key: 12842181 Trx Code: E72 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03288 - * Name: BRENT BROWN FORD LINCOLN MERCURY, LLC Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2008 Doc #:00166101
Cust Comments: GUEST STATES TRUCK CUTS OUT WHEN LETTING OFF THROTTLE; DIAG
Tech Comments: RAN EEC DIAG FOUND CODES P0401 P0404 P0405 P1335 RAN PINPT TESTS; REPROGRAMMED PCM TCM FICM TO LATEST CALI. REKOEO KOER EGR FAILS. REMOVED EGR VALVE FOUND PLUGGED UP REPL EGR VALVE ADN RE KOEO KOER ALL TESTS PASS AT THIS TIME. RETEST DROVE OK PERFORMED DIAG STEPS
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 47 2H02 030407 5C3Z 6F089 BA D21 42 54610
AWS Claim Key: 12816454 Trx Code: E72 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 03288 - * Name: BRENT BROWN FORD LINCOLN MERCURY, LLC Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2008 Doc #:00169401
Cust Comments: DRIVE D GUEST STATES THAT THE TRUCK BLOWS ALOT OF BLACK SMOKE, ALSO THE TRUCK DIES WHILE DRIVING. DIAG AND ADVI
Tech Comments: WARRANTY,RAN EEC DIAG FOUND CODES P0299 P0470 P0404 P0405 RAN PIN POINT TESTS REMOVED AND REPLACED VGT SNESOR, AND MASS AIR FLOW SENSOR RE TEST DROVE FOUND EBP VOLTAGE CHANGING ERRATIC REMOVED AND REPLACED EBP SENSOR AND REPLACED EBP WIRING CONNECTOR REPROGRAMED PCM, TCM, FICM, RE TESTED , FUEL PRESSURE OK 47 OIL SYSETEM PASS RE KOEO KOER ALL TESTS PASS
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 49 1F05 030306 4C3Z 8A616 AA D42 42 56071
AWS Claim Key: 12888870 Trx Code: E72 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 03288 - * Name: BRENT BROWN FORD LINCOLN MERCURY, LLC Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2008 Doc #:00269002
Cust Comments: LIGHT LINE GUEST STATES THE SERPENTINE BELT MAKES A CHIRPING NOISE AT IDLE DIAG AND ADVISE
Tech Comments: WARRANTY, RAN COMPLETE NVH DIAG FOUND BELT PULLEYS AND BELT GLAZZED AND WORN REMOVED FAN, FAN CLUTCH. REPLACED FAN CLUTCH REMOVED SERP BELT. DRIVE PULLEY AND TENSIONER AND WATER PUMP PULLEY RE TESTED RE ASSEMBLED RE TESTD OK
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 49 2H01 030407 4C3Z 9G489 AARM D42 42 56071
AWS Claim Key: 12886406 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 03288 - * Name: BRENT BROWN FORD LINCOLN MERCURY, LLC Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2008 Doc #:00269001
Cust Comments: DRI/DEISEL DRIV GUEST STATES THE ENGINE SURGES AND LACKS POWER WHILE DRIVING DIAG AND ADVISE
Tech Comments: 4.0 081613F INTALLED TURBO REPLAMENT PARTS AS PER TSB
4play is offline
cjmair (03-15-2009)
post #8 of 9 (permalink) Old 03-05-2009, 06:57 PM Thread Starter
Wow, what a record. I am having problems with it overheating everytime I pull with it and with this record I think I am headed back to the car lot and start looking for a different truck. Thank you once again for the help.
cjmair is offline
post #9 of 9 (permalink) Old 04-01-2009, 03:35 PM
I would like my oasis report run.
Can I get my F350 SRW 2004 production date of 03/04 vin # 1FTSW31P64ED07721
Thanks in advance!
smokingrezel is offline
2004 6.0 powerstroke into 92 F350 7.3 brewdog Diesel Conversion 3 08-21-2007 01:37 AM
Oasis Report for 2004 F350 AZAuto Ford Oasis requests 1 07-28-2007 03:12 AM
2004 F350 Ultimate Tow Rig Custom Sleeper 28,900 tarponchaser Whats Been Sold 7 04-30-2007 06:27 PM
2004 f350 custom sleeper tarponchaser Whats Been Sold 0 04-14-2007 03:10 AM
2004 f350 6.0 rayb 2003-2007 6.0L Power Stroke 13 10-30-2005 06:57 PM
