Oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by w_huisman, this thread has received 2 replies and been viewed 565 times.
post #1 of 3 (permalink) Old 03-05-2009, 02:00 PM Thread Starter
w_huisman
w_huisman's Avatar
Oasis request
I have two of them I'd like to run please.
1FMSU45P74EA29736
AND
1FTNW21P84EB30063
Thanks!!!!!
http://thumb15.webshots.net/t/75/75/8/60/86/2734860860046140835zjSXvY_th.jpg
2006 F250 6.0 Lariat
cc sb 4x4 auto 70k, coolant filter, Insight + analog FP gauge. VXCF9H7 strategy
All else stock.
w_huisman is offline
post #2 of 3 (permalink) Old 03-05-2009, 04:43 PM
4play's Avatar
ok first one
OASIS RESULT:
1FMSU45P74EA29736
03/05/2009
12:42:43
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
ENGINE WARRANTY COVERAGE CANCELLED
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/26/2003 BUILD DATE
08/06/2003 SALE MILEAGE
00019
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0783 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: PETER PARKS
OPTIONS:
EXPIRATION DATE: 11/26/2006
DISTANCE: 46,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 09473
ESP CONTRACT START DATE: 11/26/2003
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 0 2G05 031405 * RECAL * D50 79 2
AWS Claim Key: 49780 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:07-OCT-2003 Doc #:210595A
Cust Comments: REPROGRAM MULTIPLE MODULES TO THE LATEST CALIBRATION LEVEL (SOFTWARE VERSION B27.90 OR LATER )
Tech Comments: PERFORM RECALL
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 1 2H02 030008 3C3Z 6F089 AA D36 42 198
AWS Claim Key: 187592 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2003 Doc #:213369A
Cust Comments: CUSTOMER STATES ENGINE SEEMS TO LACK POWER. CK ENGINE LIGHT IS ON. TRANSMISSION DOWNSHIFT WHEN TRYING TO CLIMB THE SLIGHTEST INCLINE IN THE ROAD. NO EXCESSIVE SMOKE FROM EXHAUST, EXHAUS
Tech Comments: 198 CHECKED FOR CODES P2263 AND P0272, CHECKED OPERATION OF THE VGT, PREFORMED PCED TESTS, INSTALLED NEW VGT SOLENOID AND TEST DROVE (OK), CLEARED CODES.
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 3 2E06 030008 3C3Z 9E527 AE D21 42 6134
AWS Claim Key: 406207 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:11-FEB-2004 Doc #:217147A
Cust Comments: DIESEL CUSTOMER STATES VEHICLE SEEMS TO LACK POWER AT HIGHER SPEEDS (ABOUT 35+ MPH). NOT AS BAD AS BEFORE WHEN VGT SOLINOID WAS OUT.
Tech Comments: 6134 CHECKED FOR CODES P0248, PREFORMED PCED TESTS, REPLACED #4 INJECTOR AND REPROGRAMMED PCM, TCM AND FICM.
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 3 6Y05 000001 * MAINT * A99 82 6134
AWS Claim Key: 406208 Trx Code: 0783S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:11-FEB-2004 Doc #:217147B
Cust Comments: 6000 MILES (10000 KMS) MAINT. L
Tech Comments: 6134 O F CHANGED ROTATED TIRES
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 4 6Y05 000001 * MAINT * A99 82 9092
AWS Claim Key: 620967 Trx Code: 0783S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-MAR-2004 Doc #:219363A
Cust Comments: 9000 MILES (15000 KMS) MAINT. L
Tech Comments: 9092 O F CHANGED
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 5 7H06 120305 * FREON * C05 42 12048
AWS Claim Key: 664621 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2004 Doc #:220023B
Cust Comments: CUSTOMER STATES A C DOES NOT BLOW COLD WHEN AMBIENT TEMP WAS ABOUT 50 DEGREES IN COLORADO.
Tech Comments: 12048 A C BLOWS WARM, COMPRESSOR NOT ENGAGING. CHECK COMPRESSOR FOR POWER AND GROUND, CHECK ACCS PID AND WAC PID. CHECK A C PRESSURES. FOUND TO BE COMPLETELY EMPTY. CHARGE WITH FREON AND DYE AND LEAK CHECK SYSTEM WITH BLACK LIGHT AND FOUND NO LEAKS. A C COOLING TO 40 DEGREES
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 5 6Y05 000001 * MAINT * A99 82 12048
AWS Claim Key: 664620 Trx Code: 0783S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2004 Doc #:220023A
Cust Comments: 12000 MILES (20000 KMS) MAINT. L
Tech Comments: 12048 COMPLETED 12000 MILE SERVICE, INCLUDING DIESEL ENGINE OIL CHANGE, TIRE ROTATION AND BRAKE INSPECTION.
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 5 7W88 000615 * NPF * A85 82 12048
AWS Claim Key: 693409 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2004 Doc #:220023C
Cust Comments: CUSTOMER STATES WHEN THE RADIO IS ON IN AM MODE, AND HEADLIGHTS ARE TURNED ON, THERE IS A LOT OF STATIC. NOISE GOES AWAY WHEN LIGHTS ARE TURNED BACK OFF.
Tech Comments: 12048 RADIO GETS STATIC ON AM 830 WHEN HEAD LIGHTS ARE ON, CHECK RADIO ANTENA AT RADOI AND GROUNDS CHECK ANTENA CABLE TO ANTENA BASE. SWAP RADIOS AND STILL DOES THE SAME THING. WHEN LISTENING TO AM LOCAL STATIONS THE STATIC IS NOT PRESENT. CALLED AUDIO HOTLINE REF # TCS66998 AND SAID TO BE NORMAL, AM DIAL STRETCHES 45 MILES APPROX.
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 6 6Y05 000001 * MAINT * A99 82 14906
AWS Claim Key: 922651 Trx Code: 0783S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2004 Doc #:222443B
Cust Comments: ADD LINE B FOR AIR FILTER, FUEL FILTER AND COOLANT
Tech Comments: ADD LINE B FOR AIR FILTER, FUEL FILTER AND COOLANT
AWS Claim Key: 922650 Trx Code: 0783S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:13-MAY-2004 Doc #:222443A
Cust Comments: 15000 MILES (24000 KMS) MAINT. L
Tech Comments: 14906 COMPLETE.
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 7 6Y05 000001 * MAINT * A99 82 18525
AWS Claim Key: 1203958 Trx Code: 0783S Labor Hrs: 0.8
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:07-JUN-2004 Doc #:223673D
Cust Comments: CHANGE ENGINE OIL AND FILTER DIESEL ENGINE
Tech Comments: 16353 O F CHANGED
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 9 6Y05 000001 * MAINT * A99 82 21015
AWS Claim Key: 1464408 Trx Code: 0783S Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2004 Doc #:91592401
Cust Comments: 21,000 MILE MAINT PER QCMP
Tech Comments: PERFORMED 21000 MILE MAINT PER QUALITY CARE MAINT MENU
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 10 6Y05 000001 * MAINT * A99 82 24082
AWS Claim Key: 1786851 Trx Code: 0783S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:03-SEP-2004 Doc #:91713401
Cust Comments: CUSTOMER STATES PERFORM 25K SERVICE LOF,ROTATE
Tech Comments: PERFORMED 25K SERVICE
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 11 6Y05 000001 * MAINT * A99 82 27271
AWS Claim Key: 2228852 Trx Code: 0783S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2004 Doc #:91836301
Cust Comments: OWNER REQUESTS 27K SERVICE
Tech Comments: WARR MAINT MU27 COMPLETE CHANGE OIL AND FILTER
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 13 6Y05 000001 * MAINT * A99 82 29925
AWS Claim Key: 2700098 Trx Code: 0783S Labor Hrs: 2.1
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:26-NOV-2004 Doc #:91970001
Cust Comments: CUSTOMER STATES PERFORM QUALITY CARE 30000
Tech Comments: PERFORM OIL AND FILTER CHANGE LUBRICATE CHASSIS, LUBRICATE DOORS,LOCKS,HOOD AND TRUNK CHECK AND FILL ALL FLUIDS .
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 14 7D01 170101 F4TZ 13N021 B L26 42 31404
AWS Claim Key: 2971224 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2004 Doc #:92047901
Cust Comments: CUSTOMER STATES LOW BEAM ON PASSENGERS SIDE HEADLIGHT IS INOP
Tech Comments: VERIFIED CONCERN FOUND RIGHT FRONT HEAD LAMP BULB BLOWN. REPLACED RIGHT FRONT HEAD LAMP BULB.
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 15 6Y05 000001 * MAINT * A99 82 33123
AWS Claim Key: 3781783 Trx Code: 0783S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2005 Doc #:92219401
Cust Comments: CUSTOMER STATES PERFORM 3K MAINTANCE
Tech Comments: CHANGED OIL AND FILTER PER QCM SCHEDULE
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 17 6Y05 000001 * MAINT * A99 82 36137
AWS Claim Key: 4549054 Trx Code: 0783S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2005 Doc #:92376305
Cust Comments: 36,000 MILE SERVICE
Tech Comments: . PERFORMED 36,000 MILE SEREVICE
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 18 6Y05 000001 * MAINT * A99 82 38813
AWS Claim Key: 5236108 Trx Code: 0783S Labor Hrs: 1.1
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2005 Doc #:92518701
Cust Comments: CUSTOMER STATES PERFORM 39K LOF,ROTATE
Tech Comments: PEFORMED 39,000 MILE SERVICE
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 19 6Y05 000001 * MAINT * A99 82 42176
AWS Claim Key: 5635649 Trx Code: 0783S Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2005 Doc #:92636101
Cust Comments: OWNER REQUESTS OIL AND FILTER CHANGE
Tech Comments: PERFORMED 42,000 MILE SERVICE
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 21 5A07 050200 * 4033 * L88 D8 44782
AWS Claim Key: 6389531 Trx Code: 0783D Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2005 Doc #:92780603
Cust Comments: CUSTOMER STATES THAT THE REAR DIFFERENTIAL IS LEAKING
Tech Comments: BASIC PART NUMBER IS 4033. THE CONDITON CODE IS D 8. VERIFIED THE CUSTOMER CONCERN AND FOUND THAT THE REAR COVER LEAKING. REMOVED THE COVER AND CLEANED. INSTALLED TA 29. REASSEMBLED . FILLED WITH FLUID AND VERIFIED THE REPAIR.
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 21 5B03 050300 2C3Z 3254 AA L85 D8 44782
AWS Claim Key: 6389530 Trx Code: 0783D Labor Hrs: 3.3
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2005 Doc #:92780604
Cust Comments: CUSTOMER STATES THAT THERE IS A FLUID LEAK COMING FROM THE DRIVERS SIDE FRONT.
Tech Comments: BASIC PART NUMBER IS 3254. THE CONDITION CODE IS 42. VERFIED THE CUSTOMER CONCERN. FOUND THAT THE FRONT AXEL SEAL WAS LEAKING FROM INSIDE THE DIFFERENTIAL. REMOVED THE FOLLOWING: FRONT TIRES, FRONT CALIPERS, FRONT ROTORS, FRONT SPINDLE, FRONT AXEL SHAFTS. REMOVED THE FRONT DIFF. COVER AND DRAINED FLUID. REMOVED CARRIER ASSEMBLEY AND THEN REMOVED THE FAILED SEAL. INSTALLED NEW SEAL WITH SPECIAL
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 21 6Y05 000001 * MAINT * A99 82 44782
AWS Claim Key: 6306566 Trx Code: 0783S Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2005 Doc #:92780601
Cust Comments: CUSTOMER REQUESTS 45,000 MILE SERVICE
Tech Comments: OIL AND FILTER CHANGE, LUBRICATE CHASSIS, LUBE HINGES, LOCKS LATCHES, DOORS, HOOD, AND TRUNK, CHECK AND FILL ALL FLUIDS
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 22 1H03 030008 4C3Z 9F452 A D36 42 46998
AWS Claim Key: 6934444 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 00755 - * Name: MORRIE'S BUFFALO FORD MERCURY Ph: 763-6821622 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:92928601
Cust Comments: CUSTOMER STATES THAT WHEN SITTING AT A STOP LITE WITH THE FOOT ON THE BRAKE THE VEHICLE WILL LERCH FORWARD. RIGHT AFTER THE IDLE BOGGS DOWN.
Tech Comments: BASIC PART NUMBER IS 9F452. THE CONDITION CODE IS 42. VERIFIED THE CUSTOMER CONCERN. PERFORMED DIESEL PERFORMACE SHEET DIAGNOSIS SHEET.EVERYTHING IN SPEC ACCORDING TO SHEET. CALLED HOTLINE AND TALKED TO JIM. REPORT NUMBER IS 5IMBH003. WAS INSTRUCTED TO CHECK PIDS AND SEE WHAT VOLTAGE THE EGR WAS READING. ANYTHING PAST .95 IS NOT IN SPEC. ERROR IN THE SHEET. INSTALLED NEW EGR VALVE AND RETESTED
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 23 1A03 030008 3C3Z 6006 AARM D13 42 47936
AWS Claim Key: 7103094 Trx Code: SSP Labor Hrs: 4.6
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:02641951
Cust Comments: CUSTOMER STATES VEHICLE RUNS ROUGH AT TIMES
Tech Comments: DOES NOT OPERATE PROPERLY CHECK EEC CODES P2263, P0402, P0266, CHECK FUEL PUMP PRESSURE OK, ROAD TEST 25 MILES ACTED UP 1 TIME, REMOVE EBP AND CLEAR OUT PLUGGED TUBE, REPLACE EBP SENSOR, RE PROGRAM PCM, REPAIR VERIFICATION ALLOWANCE, EXTRA TIME TO REPEAT FINAL QUICK TEST
1FMSU45P74EA29736 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 06-AUG-2003 26-NOV-2003 158584 USA 29 * * * * * * * 59753
AWS Claim Key: 8984159 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:03121152
Cust Comments: Y9B01 PROGRAM ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: OTHER CUSTOMER ASSURANCE TEST DRIVE
AWS Claim Key: 8984158 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:03121151
Cust Comments: 06E17 RECALL CONTROL MODULE RECALIBRATION
Tech Comments: OTHER RECALIBRATE CONTROL MODULES PER FORD RECALL
4play is offline
post #3 of 3 (permalink) Old 03-05-2009, 04:46 PM
4play's Avatar
second one
OASIS RESULT:
1FTNW21P84EB30063
03/05/2009
12:44:07
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
ARN MESSAGES
WARRANTY START DATE
12/31/2003 BUILD DATE
11/06/2003 SALE MILEAGE
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
09/02/2008
DEALER: Tousley Ford, Inc.
WARRANTY CLAIM NUMBER: 746975 ODOMETER: 075345M
LABOR OP
CONDITION CODE
CONDITION DESC
F2UZ 14526P FUSE-ELECTRICAL CIRC 002 MT12B637 42 DOES NOT OPERATE PROPERLY
4C3Z 12B637AA WIRING ENG CNTRL SNS 001 9600A
000 14526A
000 8080A
75351 VERIFY NO CRANK NO START. CAN NO HEAR GLOW PLUGS AND FUEL INJECTORS C YCLE WITH KOEO. ATTEMPT TO PERFORM KOEO SELF TESTS, NO PCM COMMUNICATIONS. I NSPECTED AND FOUND FUSE F2.22 20A BLOWN FOR PCM. REPLACE FUSE AND CYCLE KEY , FUSE BLOWS IMMEADIATLY. INSPECTED CIRCUT 361 FOR SHORTS. DISCONNECT PCM, EGR, GPCM, VISCUS FAN, MAF WITH NO CHANGE. WHEN GOING TO DISCONNECT IPR VA
1FTNW21P84EB30063 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-NOV-2003 31-DEC-2003 158644 USA 29 * * * * * * * 56521
AWS Claim Key: 9286883 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2006 Doc #:050422E
Cust Comments: 59B01 CUSTOMER STATES TO PERFORM ONE TIME TEST DRIVE PER RECALL
Tech Comments: PERFORMED TEST DRIVE PER RECALL
AWS Claim Key: 9286881 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2006 Doc #:050422C
Cust Comments: 05S34 CUSTOMER STATES TO PERFORM FICM WIRING HARNESS REPAIR PER RECALL
Tech Comments: PERFORMED FICM WIRING HARNESS REPAIR
AWS Claim Key: 9286882 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 09216 - * Name: FOREST LAKE FORD, INC. Ph: 651-4644600 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2006 Doc #:050422D
Cust Comments: 05E15 CUSTOMER STATES TO PERFORM EBP SENSOR REPLACEMENT AND ECM RECAL PER RECALL
Tech Comments: REPLACED SENSOR AND PERFORMED RECALIBRATION PER RECALL 05E15
1FTNW21P84EB30063 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-NOV-2003 31-DEC-2003 158644 USA 48 1H03 030008 3C3Z 9P458 AA L87 42 67865
AWS Claim Key: 12299181 Trx Code: E72 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2007 Doc #:05559501
Cust Comments: CHECK FOR COOLANT LEAK WAS DIAG AS EGR COOLER ...REPORT E
Tech Comments: REMOVED EGR VALVE AND INSPECT FOR COOLANT ALL OK FOUND EGR O RINGS DAMAGED. REPLACED O RINGS AND PRESS TEST COLD FOUND EGR HOSE LEAKING REPLACED HOSE AND ADAPTOR HOUSING NOW OK TOPPED OFF COOLANT
1FTNW21P84EB30063 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-NOV-2003 31-DEC-2003 158644 USA 50 1H03 030008 4C3Z 9F452 A D42 55 69359
AWS Claim Key: 12421562 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:25-JAN-2008 Doc #:05786901
Cust Comments: CHECK FOR TRUCK LOOSES POWER WILL NOT ACCELERATE BLOWING SMOKE ....SEE HISTORY
Tech Comments: TESTDROVE VEH AND EEC TEST CODE P0404. PERFORMED EGR TEST EGR FAILS POSITION TEST STICKING. REPLACED EGR VALVE AND RETEST NOW OK
1FTNW21P84EB30063 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-NOV-2003 31-DEC-2003 158644 USA 57 7S06 030008 4C3Z 12B637 AA D02 42 75345
AWS Claim Key: 12865915 Trx Code: E72 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 09372 - * Name: TOUSLEY FORD, INC. Ph: 651-4847231 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2008 Doc #:746975A
Cust Comments: STALLED WONT START NO CRANK.
Tech Comments: 75351 VERIFY NO CRANK NO START. CAN NO HEAR GLOW PLUGS AND FUEL INJECTORS CYCLE WITH KOEO. ATTEMPT TO PERFORM KOEO SELF TESTS, NO PCM COMMUNICATIONS. INSPECTED AND FOUND FUSE F2.22 20A BLOWN FOR PCM. REPLACE FUSE AND CYCLE KEY, FUSE BLOWS IMMEADIATLY. INSPECTED CIRCUT 361 FOR SHORTS. DISCONNECT PCM, EGR, GPCM, VISCUS FAN, MAF WITH NO CHANGE. WHEN GOING TO DISCONNECT IPR VALVE
4play is offline
OASIS Request Please Zurler Ford Oasis requests 2 10-23-2007 01:35 PM
Oasis request please! barry1me Ford Oasis requests 1 10-23-2007 01:29 AM
Oasis request please Fireguy Ford Oasis requests 1 10-23-2007 01:24 AM
OASIS Request midnight2004 Ford Oasis requests 1 10-23-2007 01:21 AM
OASIS Request, Please colorado_okie Ford Oasis requests 1 07-17-2006 12:27 AM
