OASIS Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PowerItUp, this thread has received 2 replies and been viewed 719 times.
post #1 of 3 (permalink) Old 03-09-2009, 02:46 AM Thread Starter
OASIS Request
OASIS requested please! Much appreciated.
VIN: 1FTMW21P13ED51275
PowerItUp is offline
post #2 of 3 (permalink) Old 03-09-2009, 06:31 AM
4play's Avatar
check you vin# i bet its this 1FTNW21P13ED51275 if so here you go, if not repost correct one
OASIS RESULT:
1FTNW21P13ED51275
03/09/2009
02:29:58
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/15/2003 BUILD DATE
06/07/2003 SALE MILEAGE
00006
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 2 2G05 031405 * RECAL * D13 42 3144
AWS Claim Key: 2137508 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05075 - * Name: LEWIS FORD SALES, INC. Ph: 479-4425301 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:14-AUG-2003 Doc #:02848652
Cust Comments: VEHICLE IDLE BOUNCES AROUND ON FIRST MORNING START UP
Tech Comments: SSM 16791. PCM PROGRAMMING ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 29 2G01 * * * * * * 33460
AWS Claim Key: 12368606 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05075 - * Name: LEWIS FORD SALES, INC. Ph: 479-4425301 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-2005 Doc #:027936B
Cust Comments: REMOVE OLD EECI LABEL
Tech Comments: REMOVED OLD LABEL
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 29 1H03 030008 4C3Z 9F452 A D50 42 33460
AWS Claim Key: 12368605 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 05075 - * Name: LEWIS FORD SALES, INC. Ph: 479-4425301 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-2005 Doc #:027936A
Cust Comments: HAS NO POWER WHEN COLD
Tech Comments: 33460 DIAG AND REPROGAMED PCM PER TSB 05 11 5 REPLACED EGR VALVE OUT OF RANGE REPLACED EBP SENSER,TEST DRIVE AND RETEST PREFORMED RECALL03L12 CODES WERE P0238,P0478,P2263,P0404,P0528,P2269
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 33 * * * * * * * 38977
AWS Claim Key: 13355015 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05075 - * Name: LEWIS FORD SALES, INC. Ph: 479-4425301 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2006 Doc #:032512B
Cust Comments: 06E17 RECALL
Tech Comments: 38977 PREFORMED RECALL 06E17
AWS Claim Key: 13341006 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05075 - * Name: LEWIS FORD SALES, INC. Ph: 479-4425301 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2006 Doc #:032512A
Cust Comments: 59B01 RECALL
Tech Comments: 38977 PREFORMED RECALL 59B01
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 39 2E06 030008 3C3Z 9F838 EA D42 42 46046
AWS Claim Key: 14412565 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 05131 - * Name: TRI-LAKES FORD-MERCURY Ph: 417-3347543 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2006 Doc #:19037601
Cust Comments: CK ENGINE LIGHT COMES ON & GOES OFF AFTER BEING DRIVEN; IDLE GOES UP & DOWN WHEN LIGHT IS ON. CUST STATES VEHICLE HAS NO POWER UPHILL WITH THROTTLE WIDE OPEN; CAN LET OFF OR PULL OVER FOR
Tech Comments: DIAG FOUND SHOCKED ICP SENSOR DUE TO OIL LEAKING INTO CONNECTOR. REPLACED ICP SENSOR AND TEST DROVE. VEHICLE IS RUNNING PROPERLY AT THIS TIME.
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 44 2B01 030707 3C3Z 12K073 AA L65 D1 52691
AWS Claim Key: 14870754 Trx Code: E72 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05131 - * Name: TRI-LAKES FORD-MERCURY Ph: 417-3347543 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2007 Doc #:19640902
Cust Comments: C S VEHICLE IS LEAKING OIL
Tech Comments: VERIFIED CONCERN BY ADDING DYE AND CHECK FOR LEAKS FOUND CAM SENSOR LEAKING OIL REPLACED CAM SENSORE AND VERIFIED LEAK REPAIR
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 44 2E03 030008 * 9E527 * D13 04 52691
AWS Claim Key: 14870753 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 05131 - * Name: TRI-LAKES FORD-MERCURY Ph: 417-3347543 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2007 Doc #:19640903
Cust Comments: C S VEHICLE RUNS ROUGH ON COLD START
Tech Comments: VERIFIED CONCERN REPROGRAMMED FICM AS PER TSB 06 22 3
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 44 1G01 03XXXX 3C3Z 8592 AB L87 D4 52691
AWS Claim Key: 14880908 Trx Code: E72 Labor Hrs: 0
Dlr Cd-Sub Cd: 05131 - * Name: TRI-LAKES FORD-MERCURY Ph: 417-3347543 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2007 Doc #:19640905
Cust Comments: C S VEHICLE IS LEAKING COOLANT FROM THE FRONT OF THE ENGINE
Tech Comments: PRESSURE TEST COOLING SYSTEM FOUND COOLANT TUBE FROM THE FRONT COVER TO HEATER HOSE RUSTED EXTREMELY AND LEAKING REPLACED TUBE AND VERIFIED REPAIR
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 44 1H03 030804 3C3Z 9P455 AB D41 04 52691
AWS Claim Key: 14877434 Trx Code: E72 Labor Hrs: 2
Dlr Cd-Sub Cd: 05131 - * Name: TRI-LAKES FORD-MERCURY Ph: 417-3347543 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2007 Doc #:19640904
Cust Comments: C S VEHICLE SURGES AND CEL IS ON
Tech Comments: VERIFIED CONCERN COMPLETED PREFORMANCE WORKSHEET CODE PO404 RECOMMEND CLEANED EGR VALVE AS PER TSB 06 19 6 REINSTALLED AND TEST CHECKED GOOD
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 44 1H03 030804 3C3Z 9P456 AE L87 D1 52691
AWS Claim Key: 14870755 Trx Code: E72 Labor Hrs: 5
Dlr Cd-Sub Cd: 05131 - * Name: TRI-LAKES FORD-MERCURY Ph: 417-3347543 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2007 Doc #:19640901
Cust Comments: CUST IS SEEING GOLD COOLANT ON GROUND . WITHIN A FEW MIN OF SITTING IT GOES FROM3IN CIRCLE TO A 3FT CIRLCE BY END OF DAY RIGHT SIDE REAR EXHAUST IS WHERE IT IS LEAKING DOWN, REAR OF HEAD W
Tech Comments: PRESSURE TEST COOLING SYSTEM AND FOUND EGR COOLER LEAKING REPLACED EGR COOLER ALSO REPLACED ENGINE OIL COOLER RETEST AND VERIFIED
1FTNW21P13ED51275 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-JUN-2003 15-JUL-2003 123211 USA 53 2H01 030407 3C3Z 6K682 CBRM D50 69 60285
AWS Claim Key: 15612680 Trx Code: E72 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 05131 - * Name: TRI-LAKES FORD-MERCURY Ph: 417-3347543 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2007 Doc #:20691101
Cust Comments: C S PASSENGER SIDE INTERCOOLER IS OVERBOOSTING AS HIGH AS 40PSI. C S FIXED TEMPORARILY.
Tech Comments: VERIFIED CONCERN FOUND CODE P0401,P0404,P0528 AND P132B KOER ODDTC P2263 TEST VVT AS PER TSB 07 16 1 PERFORM PINPOINT TEST KA FOUND VVT STICKING R REPLACED TURBO ALSO REPLACED HOT SIDE CAC HOSE DAMAGED DUE BY OVERBOOST .CLEARED CODES AND RESET KAM RELEAR VVT AND EGR CODE P0528 INSPECT WIRING AS PER TSB 07 03 10 REPROGRAMMED FICM,PCM,TCM AS PER SSM 16839 AND VERIFIED PROPER OPERATION
4play is offline
PowerItUp (03-09-2009)
post #3 of 3 (permalink) Old 03-09-2009, 04:28 PM Thread Starter
Thanks for the OASIS. You're right, that was the correct VIN.
Much appreciated!
Oasis Request 91rangerturbo Ford Oasis requests 5 06-21-2007 01:11 PM
Oasis Request superxcrewfx4 Ford Oasis requests 1 06-07-2007 03:36 AM
Another oasis request sbuck Ford Oasis requests 1 06-07-2007 03:26 AM
OASIS Request rdv350 Ford Oasis requests 1 06-06-2007 01:34 PM
Oasis Request Please G SQRD Ford Oasis requests 1 07-14-2006 09:35 AM
