OASIS Request Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SparkyLV, this thread has received 3 replies and been viewed 685 times.
post #1 of 4 (permalink) Old 03-10-2009, 06:16 AM Thread Starter
Indecisive
Send a message via AIM to SparkyLV
VIN-1FTNW21P54EC40388
2004 ford f-250
Thank you
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #2 of 4 (permalink) Old 03-10-2009, 03:55 PM
4play's Avatar
OASIS RESULT:
1FTNW21P54EC40388
03/10/2009
11:53:55
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL LEGAL CONTACT
Click here for CUDL
OTHER WTYS MAY APPLY/REACQUIRED VEH WTY EXP 12-26-2009
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/20/2004 BUILD DATE
02/04/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/16/2009
DEALER: Perry Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 257578 ODOMETER: 058092M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 18476BA CORE ASY HEATER 001 8005D 42 DOES NOT OPERATE PROPERLY
VC 5 001 18476A
PRESSURE TEST COOLING SYSTEM 15PSI, FOUND LEAK AT HEATER CORE. R&R HEATER CORE, RETEST ALL OK AFTER REPAIR DONE
08/05/2008
DEALER: Galpin Ford
WARRANTY CLAIM NUMBER: 414522 ODOMETER: 054836M
LABOR OP
CONDITION CODE
CONDITION DESC
RAV REACQUIRED VEHICLE 000 RAV 82 FREIGHT/POSTAGE/MAINTENANCE
CCB418 PERFORMED RAV INSPECTION
08/05/2008
DEALER: Galpin Ford
LABOR OP
CONDITION CODE
CONDITION DESC
F2UZ 14526N FUSE-ELECTRICAL CIRC 001 12651D45 33 LOOSE PART
7E453 MODULE ASY TRNS CASE 000 12651D
000 14526A
000 12651DX1
CCB418 CHK OUT 4X4 SYSTEM GEM DIAGNOSIS P1876. PPT 6-1 NO VOLTAGE TO SOL INS TALL MISSING FUSE #27. CHK NO DTCS. CLEAR CODES. NORMAL OPERATION
08/05/2008
DEALER: Galpin Ford
LABOR OP
CONDITION CODE
CONDITION DESC
4C2Z 12A690BA WIRING ASY EC SENSOR 001 MT12A690 D8 FAILED GASKET/SEAL
4C2Z 12A690AB WIRING ASY EC SENSOR 001 6007D
OSP 002
W302725 001
CCB418 DIAG OIL LEAKS ADD DYE BLACK LIGHT TRACE LEAKS TO BOTH GLOW PLUG HARN ESS. REPLACED BOTH GLOW PLUG HARNESS. RE-CHK, NO CODES
08/05/2008
DEALER: Galpin Ford
LABOR OP
CONDITION CODE
CONDITION DESC
1C3Z 2001BA KIT-BRAKE SHOE LININ 001 2001BT 30 CHAFED,EXCESSIVE WEAR,FRAYED
000 2001B1FA
CCB418 CHK OUT. BRAKES FTS BELOW 3MM, REARS AT 5MM. CHK ROTOR RUNOUT NO RUNO UT. REPLACE FRONT PADS. ROAD TEST. NORMAL OPERATION
08/05/2008
DEALER: Galpin Ford
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12B599AARM IDM MOD ASY-FUELINJ 001 10654CA 42 DOES NOT OPERATE PROPERLY
BXT 65750 MOTORCRAFT BATTERY 002 12650D55
000 12650D67
000 12650D
000 10654C1T
000 12650D80
000 12650DX1
000 12650D81
000 12650D84
000 12650D45
CCB418 CHECKED DEAD BATTERIES, BOTH FAILED BATT. TEST. REPLACED 2 BATTERIES. CHK EEC NO DTCS ROAD TEST. MISSES AT STOPS MONITOR PIDS NO FAULTS FOUND. IG NITION TEST LOOSES 3-4 CYLS 1,3,8,6 AT TIMES COING TO STOPS. PPT S-1 S-9 REP LACE FICM INT MISSFIRE.
08/05/2008
DEALER: Galpin Ford
LABOR OP
CONDITION CODE
CONDITION DESC
E35Y 13466A SMALL BULBS 001 13465A 46 BURNED OUT
CCB418 CK OUT NO THIRD BRAKE LIGHT. REPLACED BURNED OUT BULB
08/05/2008
DEALER: Galpin Ford
LABOR OP
CONDITION CODE
CONDITION DESC
2821410 GL&CHNL-FR DR WDO 000 MT21410 D4 FLAW IN MATERIAL
CCB418 REMOVED TINT FROM WINDOWS
08/05/2008
DEALER: Galpin Ford
LABOR OP
CONDITION CODE
CONDITION DESC
9OO4 87745 004 1007AT 42 DOES NOT OPERATE PROPERLY
TIRE TIRE THUMPERS 000
CCB418 CHK TREAD DEPTH LESS THAN 3/32" ALL TIRES. MOUNT AND BALANCED 4 TIRES
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 1 3A15 070102 3C3Z 7G383 AB P59 42 261
AWS Claim Key: 640830 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 05559 - * Name: VILLA FORD Ph: 714-6378222 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2004 Doc #:06376252
Cust Comments: CK TRANS DELEYED ENGAUGEMENT AS MUCH AS 5 10 SECONDS THEN SLAMS IN ALSO SHIFT GEARS GOING FROM 1 2 3 D WHEN NOT MOVING SEE JON FOR DETAILS
Tech Comments: TRANS DELAYS AUTOMATIC TRANSMISSION GASKET OR OIL PAN REMOVE AND INSTAL
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 1 2G05 031405 * RECAL * E29 42 261
AWS Claim Key: 640829 Trx Code: 1 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 05559 - * Name: VILLA FORD Ph: 714-6378222 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2004 Doc #:06376251
Cust Comments: CK SES LIGHT ON
Tech Comments: RETRIEVED AND CLEARED GLOW PLUG TEST PID MONITOR PINPOINT TEST REPAIR OPEN CKT AT CONNECTOR GLOW PLUG CONTROLLER RETEST REPRGRAM ROAD TEST
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 19 * * * * * * * 24515
AWS Claim Key: 7096785 Trx Code: 05S34 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 05520 - * Name: BOB WONDRIES FORD Ph: 626-2893591 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:309530B
Cust Comments: PERFORM RECALL 05S34 INJ CONTROL MOD
Tech Comments: 24515 05S34E 1.1 INSPECT WIRE HARNESS AND WAS CHAFING. REPLACE WIRE HARNESS.
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 19 2H01 * * * * * * 24515
AWS Claim Key: 7073662 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05520 - * Name: BOB WONDRIES FORD Ph: 626-2893591 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:309530A
Cust Comments: PERFORM RECALL 05B29 CHARGE AIR COOLER DUCT
Tech Comments: 24515 0529B .4 REPLACE CHARGE AIR COOLER AS PER RECALL
AWS Claim Key: 7073663 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 05520 - * Name: BOB WONDRIES FORD Ph: 626-2893591 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:309530C
Cust Comments: PERFORM RECALL 05E15 EXHAUST PRESSURE SENSOR
Tech Comments: 24515 05E15G 1.3 REPLACE EBP SENSOR AND EBP CONNECTOR AND REPROGRAM FICM,TCM AND PCM
AWS Claim Key: 7073664 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05520 - * Name: BOB WONDRIES FORD Ph: 626-2893591 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:309530D
Cust Comments: PERFORM RECALL 59B01 ONE TIME CUST ASSURANCE
Tech Comments: 24515 59B01A .3 ROAD TEST AFTER PERFORMING REPAIRS.
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 22 2G05 031405 * RECAL * D11 04 27309
AWS Claim Key: 8155517 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 05520 - * Name: BOB WONDRIES FORD Ph: 626-2893591 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-JAN-2006 Doc #:314189A
Cust Comments: CUST STATES VEH IDLE GOES HIGH,THEN COMES DOWN ADVISE
Tech Comments: 27309 12650D,D45,D84 .7 INSPECT IDLE GOES HIGH AND HOOK WDS TO RETRIEVE DTS CODE P0306 PERFORM DIAGNOSIS AND REPROGRAM NEW CALIBRATION UP DATE PCM AS PER TSB 03 20 12 AND RECHECK AFTER REPAIR IT,S OK.
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 23 2G01 031401 4C3Z 12A650 AUG D21 42 28081
AWS Claim Key: 8439689 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 05537 - * Name: STAR FORD Ph: 818-9560977 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2006 Doc #:67603701
Cust Comments: CUSTOMER STATES AT TIMES WHEN HE IS SLOWING DOWN TO MAKE LEF T TURN ENGINE WILL STALL AND ALSO RPM WILL JUMP HIGH AS IT S IDLING CHECK AND ADVISE
Tech Comments: INSPECT AND PERFORM SYSTEM DIAG TO FIND CUSTOMER S CONCERN TEST DROVE WITH NGS AND FOUND FAULTY PCM REPLACED FAULTY PCM RETEST ALL OK AT THIS TIME
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 25 2A01 031202 6C3Z 6C646 AA D50 33 30271
AWS Claim Key: 9021290 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05426 - * Name: ANTELOPE VALLEY FORD LINCOLN MERCURY Ph: 661-9493586 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:08571151
Cust Comments: CUSTOME REPORTS HOT HOSE ON TURO POPS OFF
Tech Comments: LOOSE AIR COOLER DUCT DUCT ENGINE CHARGE AIR COOLER
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 33 2H01 030407 4C3Z 6K682 ARM E29 42 35963
AWS Claim Key: 10810445 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 05537 - * Name: STAR FORD Ph: 818-9560977 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2006 Doc #:69306501
Cust Comments: DIAGNOSE DIESEL CHECK ENGINE LIGHT CHECK ENGINE LIGHT ON TURBO MAKES A LOUD HOWLING NOISE GOING UP HILL TOWING IDLES ROUGH FEELS LIKE ITS GOING STALL AND DIE
Tech Comments: TURBO FAULTY REPLACED TURBO CHARGER ASSY SEE DIESEL DIAGNOSIS SHEET REPAIR DIESEL
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 34 1H03 030008 * 9F452 * E29 55 36262
AWS Claim Key: 10863423 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 05520 - * Name: BOB WONDRIES FORD Ph: 626-2893591 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2006 Doc #:330068B
Cust Comments: CUSTOMER STATES: CHECK ENGINE LIGHT IS ON
Tech Comments: 36262 061906C 2.3 C.C. 55 9F452 EEC TEST RETRIEVE DTC P0401 RAN OASIS AND FOUND TSB#06 19 6 THAT ADVISE TO CLEAN EGR VALVE TO REMOVE CARBON BUILD UP. AND ADD INJECTOR CLEANER IN FUEL TANK. CLEAR DTC TEST DROVE OK
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 38 2B01 030008 3C3Z 12K073 AA E29 42 40007
AWS Claim Key: 11518740 Trx Code: E72 Labor Hrs: 7.3
Dlr Cd-Sub Cd: 05537 - * Name: STAR FORD Ph: 818-9560977 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2007 Doc #:70005101
Cust Comments: CUST STATES CHECK ENGINE LIGHT ON ADVISE ALSO NO POWER UNDER ANY LOAD IE TOWING TRAILOR BLOWS EXCESSIVE BLACK SMOKE POSS POSS FAN CLUTCH ENGAGING SOUND ADVISE
Tech Comments: TEST DLT CLEAR EGR CARBON BULID UP REPLACED CAM SENSOR OUT F OF SYNC NOTE: BATTERY CABLES ABNORMAL CORROSION RECOMMEND SERVICE NOTE:TO CUST OIL AERATION TEST BORDERLINE FAIL SUGGEST CHECK OIL QUALITY AND RATING RECOMMEND USE MOTORCRAFT DEISEL OIL E
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 38 2H01 030407 4C3Z 6K682 CBRM E29 42 40143
AWS Claim Key: 11576118 Trx Code: S07 Labor Hrs: 9.9
Dlr Cd-Sub Cd: 09914 - * Name: SUNRISE FORD OF NORTH HOLLYWOOD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2007 Doc #:284495A
Cust Comments: CHECK ENGINE LIGHT ON
Tech Comments: REPLACE TURBOCHARGER, EGR, REPGROGRAM PCM
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 38 2H01 031202 6C3Z 6C640 B E29 42 40143
AWS Claim Key: 11718538 Trx Code: E72 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 09914 - * Name: SUNRISE FORD OF NORTH HOLLYWOOD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2007 Doc #:286708A
Cust Comments: CHECK ENGINE LGIHT ON
Tech Comments: REPLACE HOSE CONNECTION AT COOLER END
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 54 2G02 180101 4C2Z 12A690 BA L65 D8 54836
AWS Claim Key: 12862966 Trx Code: P86 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 05373 - * Name: GALPIN FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:41452213
Cust Comments: ENGINE OIL LEAKS.
Tech Comments: CCB418 DIAG OIL LEAKS ADD DYE BLACK LIGHT TRACE LEAKS TO BOTH GLOW PLUG HARNESS. REPLACED BOTH GLOW PLUG HARNESS. RE CHK, NO CODES
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 54 5G05 040402 * TIRE * H62 42 54836
AWS Claim Key: 12862969 Trx Code: P86 Labor Hrs: 1
Dlr Cd-Sub Cd: 05373 - * Name: GALPIN FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:4145229
Cust Comments: MOUNT AND BALANCE 4 TIRES
Tech Comments: CCB418 CHK TREAD DEPTH LESS THAN 3/32 ALL TIRES. MOUNT AND BALANCED 4 TIRES
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 54 6H06 011103 * 2821410 * G07 D4 54836
AWS Claim Key: 12865293 Trx Code: P86 Labor Hrs: 2
Dlr Cd-Sub Cd: 05373 - * Name: GALPIN FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:4145227
Cust Comments: REMOVE AFTERMARKET WINDOW TINT
Tech Comments: CCB418 REMOVED TINT FROM WINDOWS
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 54 2G01 03XXXX 4C3Z 12B599 AARM E29 42 54836
AWS Claim Key: 12858042 Trx Code: E72 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 05373 - * Name: GALPIN FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:4145223
Cust Comments: E29...CUSTOMER STATES CK ENGINE LIGHT STAYS ON
Tech Comments: CCB418 CHECKED DEAD BATTERIES, BOTH FAILED BATT. TEST. REPLACED 2 BATTERIES. CHK EEC NO DTCS ROAD TEST. MISSES AT STOPS MONITOR PIDS NO FAULTS FOUND. IGNITION TEST LOOSES 3 4 CYLS 1,3,8,6 AT TIMES COING TO STOPS. PPT S 1 S 9 REPLACE FICM INT MISSFIRE.
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 54 7D07 170301 E35Y 13466 A L26 46 54836
AWS Claim Key: 12862968 Trx Code: P86 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05373 - * Name: GALPIN FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:4145225
Cust Comments: REPLACE INOP. 3RD BRAKE LIGHT BULB
Tech Comments: CCB418 CK OUT NO THIRD BRAKE LIGHT. REPLACED BURNED OUT BULB
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 54 3Y09 0707XX * 7E453 * P82 33 54836
AWS Claim Key: 12862965 Trx Code: P86 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05373 - * Name: GALPIN FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:41452211
Cust Comments: C/S 4X4 LIGHT IS ON. CHECK AND ADVISE WITH DIAGNOSIS
Tech Comments: CCB418 CHK OUT 4X4 SYSTEM GEM DIAGNOSIS P1876. PPT 6 1 NO VOLTAGE TO SOL INSTALL MISSING FUSE #27. CHK NO DTCS. CLEAR CODES. NORMAL OPERATION
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 54 6Y20 000079 * RAV * A99 82 54836
AWS Claim Key: 12842628 Trx Code: RAVIN Labor Hrs: 1
Cust Comments: RAV INSPECTION
Tech Comments: CCB418 PERFORMED RAV INSPECTION
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 54 5V02 060302 1C3Z 2001 BA H20 30 54836
AWS Claim Key: 12862967 Trx Code: P86 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 05373 - * Name: GALPIN FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2008 Doc #:41452215
Cust Comments: RELINE FRONT BRAKES
Tech Comments: CCB418 CHK OUT. BRAKES FTS BELOW 3MM, REARS AT 5MM. CHK ROTOR RUNOUT NO RUNOUT. REPLACE FRONT PADS. ROAD TEST. NORMAL OPERATION
1FTNW21P54EC40388 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-FEB-2004 20-MAR-2004 171053 USA 60 7G02 120202 4C3Z 18476 BA C09 42 58092
AWS Claim Key: 13073235 Trx Code: RAV Labor Hrs: 1.5
Dlr Cd-Sub Cd: 10059 - * Name: PERRY FORD LINCOLN MERCURY Ph: 805-6822411 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2009 Doc #:25757801
Cust Comments: CUST STATES DEFROSTER IS INOP SMOKE FROM DASH COOL LEAKS CHECK HEATER CORE
Tech Comments: PRESSURE TEST COOLING SYSTEM 15PSI, FOUND LEAK AT HEATER CORE. R&R HEATER CORE, RETEST ALL OK AFTER REPAIR DONE
4play is offline
post #3 of 4 (permalink) Old 03-10-2009, 08:02 PM Thread Starter
Indecisive
WOW!
It was for sale and said a ford buy back!
And now I know why.
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #4 of 4 (permalink) Old 03-11-2009, 04:30 AM
4play's Avatar
this veh is no less than most others but the history states reaquired veh. simply means someone powerfull enough didnt want it any longer. i agree.
4play is offline
OASIS Request please prosat Ford Oasis requests 1 06-15-2007 02:31 AM
Oasis request... coheaincolo Ford Oasis requests 1 06-07-2007 03:34 AM
Oasis Request dblue351 Ford Oasis requests 1 06-07-2007 03:30 AM
Oasis Request Please Bluemonster Ford Oasis requests 1 07-14-2006 09:06 AM
Oasis Request jrh1 Ford Oasis requests 1 07-06-2006 11:17 AM
