oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 86 1 tonhauler, this thread has received 2 replies and been viewed 629 times.
post #1 of 3 (permalink) Old 03-10-2009, 08:48 AM Thread Starter
2003 f-550 4x4
VIN
1fdaw57p53ed10330
thanks very much
i need to know what has all been done to this truck
86 1 tonhauler is offline
post #2 of 3 (permalink) Old 03-10-2009, 03:57 PM
4play's Avatar
OASIS RESULT:
1FDAW57P53ED10330
03/10/2009
11:55:56
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-550 CC CHASIS 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
K8 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/13/2003 BUILD DATE
04/26/2003 SALE MILEAGE
00028
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 5 2G04 031401 * 12A650 * E29 42 20636
AWS Claim Key: 3144888 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04809 - * Name: BARTOW FORD COMPANY Ph: 863-5330425 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2003 Doc #:32959001
Cust Comments: (E29) CHECK ENGINE LIGHT COMES ON
Tech Comments: REPROGRAMMED PCM FICM AND TCM WITH UPDATED CALIB PER SSM 16839
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 5 2G01 * * * * * * 20636
AWS Claim Key: 3144886 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04809 - * Name: BARTOW FORD COMPANY Ph: 863-5330425 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2003 Doc #:32959006
Cust Comments: FACTORY RECALL 03L12 EECI LABEL REPLACEMENT.E
Tech Comments: APLLY NEW LABEL
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 5 2E05 100103 * 9155 * G29 42 20636
AWS Claim Key: 3144887 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04809 - * Name: BARTOW FORD COMPANY Ph: 863-5330425 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2003 Doc #:32959002
Cust Comments: D50..WATER IN FUEL LIGHT ON.
Tech Comments: CHANGE FUEL FILTER PRDER NEW WATER FUEL SWITCH
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 9 2G01 030008 3C3Z 12B599 AARM D02 42 30703
AWS Claim Key: 4079608 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04807 - * Name: FREEDOM FORD, INC. Ph: 727-7972277 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2004 Doc #:08202801
Cust Comments: C S CRANKS BUT WONT START
Tech Comments: VERIFY COMPLAINT PERFORM 6.0 HARD START NO START DIAG PINPOINT TEST NO COMMUNICATION FROM PCM ATTEMPT TO REFLASH
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 27 2E06 030008 3C3Z 9F838 EA L65 42 67852
AWS Claim Key: 11460463 Trx Code: E72 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01257 - * Name: HOLMAN COMMERCIAL TRUCK CENTER Ph: 856-2355600 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2005 Doc #:101419A
Cust Comments: OIL LEAKING FROM THE REAR OF ENGINE,CK & REPORT
Tech Comments: 67852 CHECKED OUT THE OIL LEAK AND FOUND THE ICP SENSOR WAS LEAKING.REPLACED THE ICP SENSOR AND STEAM CLEANED THE BOTTUM OF THE ENG.AND MADE SURE THE OIL WAS TOPPED OFF.ALSO FOUND THE DIPSTICK WAS BUSTED.REPLACED THE DIPSICK. AND ALSO NOTICED THE WATER IN FUEL LIGHT IS ON AND TOOK A FUEL SAMPLE AND GOT ALOT OF WATER OUT OF THE MODULE.NEED TO REPLACE THE MODULE BECAUSE IT IS THE EARLY
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 27 2E06 100106 6C3Z 9G282 AA D02 42 67852
AWS Claim Key: 11432256 Trx Code: E72 Labor Hrs: 3
Dlr Cd-Sub Cd: 01257 - * Name: HOLMAN COMMERCIAL TRUCK CENTER Ph: 856-2355600 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2005 Doc #:101419C
Cust Comments: VEH WAS TOWED IN, NO START CONDITION
Tech Comments: 67852 CHECKED THE FUEL PRESSURE AND THERE WAS NO FUEL PRESSURE AND NOTICED THAT THE LAST TIME IT WAS HEAR THE DTRM WAS MISSING FORM THE FILTER HOUSEING.REPLACED THE WATER IN FUEL MODULE WITH AN OLDER MODLE WATER IN FUEL MODULE ASSEMBLEY TO MAKE THE PUMP WORK.ALSO FOUND THE 20 AMP FUSE WAS BLOWN FOR THE DLC.ALSO PERFORMED TSB 03 20 12 MODULE RECALIBRATION TO THE LATEST CALIBRATION.ROA
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 27 2E05 100106 3C3Z 9B249 AB G29 49 67852
AWS Claim Key: 11432255 Trx Code: E72 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 01257 - * Name: HOLMAN COMMERCIAL TRUCK CENTER Ph: 856-2355600 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2005 Doc #:101419B
Cust Comments: FUEL IN WATER LIGHT IS ON
Tech Comments: 67852 REMOVED THE WATER IN FUEL MODULE AND FOUND THAT IT WAS ALL CLOGGED FULL OF JUNK AND COULD NOT GET IT CLEAN.ALSO FOUND THE DTR WAS MISSING FROM THE HOUSEING,NEED TO REPLACE THE FILTER HOUSEING.
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 28 6Y20 000001 * MISC * D21 82 67852
AWS Claim Key: 11654845 Trx Code: PRM Labor Hrs: 0
Dlr Cd-Sub Cd: 04865 - * Name: DESOTO FORD-MERCURY, INC. Ph: 863-4944848 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-AUG-2005 Doc #:06629951
Cust Comments: CUSTOMER REFUND FOR REPAIRS WHILE TRAVELING FOR BUSINESS
Tech Comments: REFUND FOR MECH EXPENSES FOR BREAKDOWN WHILE TRAVELING FOR BUSINESS
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 33 2E06 030008 3C3Z 9E527 AE D50 01 80557
AWS Claim Key: 13030406 Trx Code: E72 Labor Hrs: 15.3
Dlr Cd-Sub Cd: 04963 - * Name: BRANDON FORD Ph: 813-2463673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2006 Doc #:05750851
Cust Comments: CUSTOMER STATES THE ENGINE LACKS POWER WHEN COLD ADVISE
Tech Comments: BROKEN COOLER OIL REMOVE AND INSTALL OR REPLACE
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 38 * * * * * * * 86703
AWS Claim Key: 13930360 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01167 - * Name: SARASOTA FORD Ph: 941-3663673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2006 Doc #:09860941
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: RECALIBRATE
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 38 2G01 03XXXX 4C3Z 12B599 AARM D21 42 86703
AWS Claim Key: 13930361 Trx Code: E72 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 01167 - * Name: SARASOTA FORD Ph: 941-3663673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2006 Doc #:09860951
Cust Comments: CUST STATES THAT VEH WILL CRANK BUT WILL NOT RUN
Tech Comments: ING TO STALL CKED FUEL PRESURE IT WAS LOW REPLACED FILTERS AND RETEST TRUCK WOULD NOT START REPLACED PUMP AND FLUSHED LINES AND PURGED AIR FROM UPPER HOUSEING CLEANED HOUSING AND TRUCK STARTED TEST DROVE AND VERIFY RUNS GOOD
AWS Claim Key: 13930359 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01167 - * Name: SARASOTA FORD Ph: 941-3663673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2006 Doc #:09860940
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: TEST DROVE
1FDAW57P53ED10330 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 26-APR-2003 13-MAY-2003 124408 USA 38 2E06 030008 3C3Z 9E527 AE D42 42 87159
AWS Claim Key: 13975583 Trx Code: E88 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 01167 - * Name: SARASOTA FORD Ph: 941-3663673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2006 Doc #:09917451
Cust Comments: CUST STATES THAT ON THRUSDAY LEFT US AND WAS GOING DOWN THE INTERSTATE VEH FELT LIKE IT DOWN AN INJ.
Tech Comments: VERIFY CONCERN PULLED CODES AND FOUND INJ #8 CODE INJ JUST REPLACED LAST WEEK REPLACED INJ SPW PART AND RETEST VERIFY OK NOW
4play is offline
post #3 of 3 (permalink) Old 03-10-2009, 04:44 PM Thread Starter
thanks very much !!!!!!! :P
OASIS request Hunting Labs Ford Oasis requests 1 06-15-2007 02:19 AM
OASIS Request Please cruiser2001 Ford Oasis requests 1 06-07-2007 03:40 AM
Oasis Request dblue351 Ford Oasis requests 1 06-07-2007 03:30 AM
Oasis Request Please Bluemonster Ford Oasis requests 1 07-14-2006 09:06 AM
Oasis Request jrh1 Ford Oasis requests 1 07-06-2006 11:17 AM
