Oasis requests - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sanjay, this thread has received 2 replies and been viewed 528 times.
post #1 of 3 (permalink) Old 03-10-2009, 11:33 AM Thread Starter
Oasis requests
Hello every body in this board
i am new in this forums .this is my first posting
2004 ford f 450 need oasis the vin # is 1fdxf46p24ec51695
i really appriciated and thanx in advance and thanx for the diesel garage for giving me oppertunity to ask any question
sanjay
sanjay is offline
post #2 of 3 (permalink) Old 03-10-2009, 04:01 PM
4play's Avatar
welcome to the diesel garage, lots of good people here and info too. here ya go,
OASIS RESULT:
1FDXF46P24EC51695
03/10/2009
12:00:23
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-450 CHASSIS CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
G3 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/13/2004 BUILD DATE
03/04/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 14 * * * * * * * 17810
AWS Claim Key: 7109304 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00086 - * Name: RON BORTNICK FORD, INC. Ph: 301-6275600 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2005 Doc #:11815504
Cust Comments: RECALL 05E15
Tech Comments: PERF RECALL 05E15
AWS Claim Key: 7109306 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00086 - * Name: RON BORTNICK FORD, INC. Ph: 301-6275600 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2005 Doc #:11815501
Cust Comments: CUST STATES DO RECALL #05S34
Tech Comments: PERF RECALL 05S34
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 14 2H01 * * * * * * 17810
AWS Claim Key: 7109305 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00086 - * Name: RON BORTNICK FORD, INC. Ph: 301-6275600 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2005 Doc #:11815502
Cust Comments: CUST STATES DO RECALL #05B29
Tech Comments: PERF RECALL 05B29
AWS Claim Key: 7109303 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00086 - * Name: RON BORTNICK FORD, INC. Ph: 301-6275600 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2005 Doc #:11815505
Cust Comments: RECALL 59B01
Tech Comments: CUST ASSURANCE TEST DRIVE
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 14 2G01 031401 4C3Z 12A650 AVG C05 42 17810
AWS Claim Key: 7171261 Trx Code: S07 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00086 - * Name: RON BORTNICK FORD, INC. Ph: 301-6275600 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2005 Doc #:11822501
Cust Comments: CUST STATES A C INOP INOP AFTER LAST RECALL
Tech Comments: VERIFIED A C IS INOP.PERF P P TEST J.REPL PCM PER PINPOINT TEST.RETEST OK
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 31 5O01 110201 2C3Z 3504 AARM H21 33 35902
AWS Claim Key: 11127799 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00143 - * Name: DARCARS FORD Ph: 301-4591100 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2007 Doc #:26311302
Cust Comments: CUSTOMER STATES VEHICLE WOBBLE ON THE ROAD WHEN DRIVING, AND ALSO PULLING TO THE LEFT AND RIGHT OVER BUMPS,CHECK AND ADVISE.
Tech Comments: DIAG.AND REPLACED STEERING GEAR BOX EXCESSIVE PLAY IN STEERING WHEEL,ROAD TEST RETEST PASSED.
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 31 1H03 030008 4C3Z 9F452 A D36 55 35902
AWS Claim Key: 11127800 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 00143 - * Name: DARCARS FORD Ph: 301-4591100 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2007 Doc #:26311301
Cust Comments: CUSTOMER STATES VEHICLE HESITATE AND LOOSE POWER AT HIGH SPEED SOUND LIKE TURBO IS NOT WORKING AND ALSO MAKING A LOUD NOISE,CHECK AND ADVISE.
Tech Comments: DIAG.AND REPLACED EGR VALVE,AS PER TSB 06 19 06,06 22 03
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 31 2G01 031401 4C3Z 12A650 AVG D02 46 37634
AWS Claim Key: 11211521 Trx Code: S07 Labor Hrs: 10.9
Dlr Cd-Sub Cd: 00143 - * Name: DARCARS FORD Ph: 301-4591100 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2007 Doc #:26382701
Cust Comments: CUSTOMER STATES VEHICLE CRANK NO START,CHECK AND ADVISE.
Tech Comments: DIAG.AND REPAIR WIRE IN CIRCUIT 878 WIRE SHORTED AND REPLACED PCM(SHORTED)AND REPROGRAMMED PCM REASSEMBLE, ROAD TEST RETEST PASSED.
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 31 2C01 030603 6C2Z 11002 AA D02 46 37634
AWS Claim Key: 11211520 Trx Code: P05 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00143 - * Name: DARCARS FORD Ph: 301-4591100 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2007 Doc #:26382702
Cust Comments: CUSTOMER REQUESTS CHECK CHARGING SYSYTEM WONT START STARTER FAILED.
Tech Comments: STARTER SHORTED OUT. CHECK CHARGING SYSTEM PERFORMED REPLACED STARTER MOTOR SHORTED.
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 33 2E06 030008 4C3Z 9F838 A D03 46 44021
AWS Claim Key: 11470026 Trx Code: S07 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 00143 - * Name: DARCARS FORD Ph: 301-4591100 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:17-APR-2007 Doc #:26723201
Cust Comments: CUSTOMER STATES VEHICLE CRANK NO START,CHECK AND ADVISE SEE HISTORY.
Tech Comments: DIAG.AND REPLACED INJECTOR PRESSURE SENSOR SHORTED,REWIRE CONNECTOR,ROAD TEST RETEST PASSED.
1FDXF46P24EC51695 T/F7 F T/BB T/DB T/B A1 T/BE T/YB 04-MAR-2004 13-AUG-2004 147312 USA 36 2H01 030407 4C3Z 6K682 CBRM L65 01 46392
AWS Claim Key: 11875025 Trx Code: S07 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 00143 - * Name: DARCARS FORD Ph: 301-4591100 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2007 Doc #:27335501
Cust Comments: CUSTOMER STATES VEHICLE LEAKING OIL LOOKS LIKE IS COMMING FROM THE TURBO,ENGINE NOISEY AND LOOSING POWER,CHECK AND ADVISE.
Tech Comments: DIAG.AND REPLACED TURBO CHARGER,SHAFT IN TURBO BROKE,DAMAGED INTERCOOLER AND ACTUATOR REPLACED.
4play is offline
post #3 of 3 (permalink) Old 03-10-2009, 04:28 PM Thread Starter
thanx very much 4play thanx for your help its help me because i have some issue in my truck its puking and dealer say its head gasket and egr cooler i just wanna check still i am in warranty
sanjay is offline
OASIS Requests USMCTop Ford Oasis requests 3 09-15-2007 05:03 PM
OASIS requests trac Ford Oasis requests 4 02-05-2007 03:31 PM
OASIS requests Scooters99PSD Ford Oasis requests 2 09-09-2006 11:07 AM
OASIS Requests NMU98 Site Information 8 02-02-2006 11:28 PM
