OASIS Request Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2008fx4diesel, this thread has received 2 replies and been viewed 483 times.
post #1 of 3 (permalink) Old 03-11-2009, 04:03 PM Thread Starter
2008fx4diesel's Avatar
2008 ford fx4
1FTSX21RX8EB57773
thanks mike
2008fx4diesel is offline
post #2 of 3 (permalink) Old 03-11-2009, 07:00 PM
4play's Avatar
OASIS RESULT:
1FTSX21RX8EB57773
03/11/2009
14:59:27
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
8F716A0A
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/07/2007 BUILD DATE
06/13/2007 SALE MILEAGE
00000
08B07
CERTAIN 2008 MODEL YEAR F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM) AND INSTRUMENT CLUSTER (IC)
08B06
6.4L DIESEL ENGINE COOLING SYSTEM VENTURI TEE INSTALLATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
08/28/2008
DEALER: Shanahan Ford Lincoln Sales
WARRANTY CLAIM NUMBER: 188951 ODOMETER: 054341K
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 081302A 04 SOFTWARE REVISION/FLASH MODULE
54341 081302A 0.5HRS MIL LIGHT ON CONT. CODE P2002CHECK OASIS NEW TSB RELEA SED JUNE 25-08 PERFORM TSB 08-13-2 REPROGRAM MODULES ROAD TEST OK
07/18/2008
WARRANTY CLAIM NUMBER: 187663 ODOMETER: 049194K
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 4635AB SPIDER & BRG ASY-U/J 001 4602A 69 FROZEN/SEIZED/BINDING
000 4602A3
VERIFY CONCERN. RE&RE REAR DRIVESHAFT REPLACE SIEZED REAR U JOINT. ALL OK NO W
06/02/2008
WARRANTY CLAIM NUMBER: 186223 ODOMETER: 043502K
LABOR OP
CONDITION CODE
CONDITION DESC
NPF NO PROBLEM FOUND (NR 000 NPF 82 FREIGHT/POSTAGE/MAINTENANCE
06/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
17906 BAR REAR BUMPER REIN 000 MT17906 07 IMPROPERLY ADJUSTED/FITS POORLY
REPOSITION & ALIGN REAR BUMPER AS TAIL GATE HITTING BUMPBER WHEN OPEN
06/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 3B396AA LOCKING HUB ASSEMBLY 002 1105AT D4 FLAW IN MATERIAL
INSPECT FRT HUBS CORRODED. REPLACE BOTH FRT HUBS
06/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z25600A58C KIT - SEAT FASTENERS 001 08C01B
43502 08C01B 0.3HRS INSPECT SEAT BACK FRAME & INSTALL CLAMP
06/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 2520758AA W/STRP FRT DR LOWER 002 20124AT 07 IMPROPERLY ADJUSTED/FITS POORLY
000 20708AT
INSPECT MUD COMING IN BOTTOM DOORS LOWER WEATHER STRIP NOT SEATING AGAINST B ODY & BUCKELED. CLEAN & REPL. BOTH LOWER DOOR WEATHER STRIPS RECHECK NOTTOU CHING BODY IN PLACES ALIGN BOTH FRT DOORS TO TIGHTEN PRESSURE ON LOWER WEAT HER STRIP RECHECK SEATS OK
06/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 MT070809 42 DOES NOT OPERATE PROPERLY
ROAD TEST VEHICLE FOR SMOKE, NOT SMOKINGH AT THIS TIME, FOLLOW TSB 07-8-9 NO CODES, OIL LEVEL CORRECT, NO LEAKS IN INAKE & EXHAUST MANIFOLDS EVIDENT RO AD TEST TO UPDATE PCM PRGRAM ROAD TEST OK FORD SAID TO CLAIM AS TSB, DELETE D LINE A AND CLAIMING HERE.
04/03/2008
WARRANTY CLAIM NUMBER: 184240 ODOMETER: 037025K
LABOR OP
CONDITION CODE
CONDITION DESC
DIAG DIAGNOSIS 000 6005F 82 FREIGHT/POSTAGE/MAINTENANCE
000 6005F1
000 6005F2
000 6005F6
000 6005F12
ROAD TEST NO DRIVABILITY CONCERNS KOEO,KOER, INJ. TESTS PASS ROAD TST BOOST. PRESS PER SSM 19679 OK TIRE TREAD FRT 12-32 REAR 8-32 VEHICLE OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 10 2G04 000615 * DIAG * D42 82 23006
AWS Claim Key: 648591 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:03-APR-2008 Doc #:184240A
Cust Comments: POOR FUEL ECONOMY. CHECK ENGINE LIGHT IS NOT ON. DIAG ONLY.CUST ALSO STATES THERE IS ALOT OF BLACK SMOKE COMING FROM EXHAUST.
Tech Comments: ROAD TEST NO DRIVABILITY CONCERNS KOEO,KOER, INJ. TESTS PASS ROAD TST BOOST. PRESS PER SSM 19679 OK TIRE TREAD FRT 12 32 REAR 8 32 VEHICLE OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 5V01 050306 6C3Z 3B396 AA P82 D4 27030
AWS Claim Key: 1439105 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223D
Cust Comments: CHECK FOR LEFT FRONT CENTERS ARE CORRODED (HUBS)
Tech Comments: INSPECT FRT HUBS CORRODED. REPLACE BOTH FRT HUBS
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 6Q06 011902 * 17906 * B69 07 27030
AWS Claim Key: 1439104 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223C
Cust Comments: CHECK FOR REAR TAIL GATE IS HITTING BUMPER AND WEARING PAINT
Tech Comments: REPOSITION & ALIGN REAR BUMPER AS TAIL GATE HITTING BUMPBER WHEN OPEN
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 2E03 03XXXX * 9E527 * E41 42 27030
AWS Claim Key: 1973751 Trx Code: S07 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223H
Cust Comments: CUST WAS PULLED OVER BY POLICE VEH. HAS EXCESSIVE SMOKE CANNOT SEE CARS BEHIND YOU CUST STATES USING ALOT OF FUEL AS WELL
Tech Comments: ROAD TEST VEHICLE FOR SMOKE, NOT SMOKINGH AT THIS TIME, FOLLOW TSB 07 8 9 NO CODES, OIL LEVEL CORRECT, NO LEAKS IN INAKE & EXHAUST MANIFOLDS EVIDENT ROAD TEST TO UPDATE PCM PRGRAM ROAD TEST OK FORD SAID TO CLAIM AS TSB, DELETED LINE A AND CLAIMING HERE.
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 2G88 000615 * NPF * E41 82 27030
AWS Claim Key: 1484910 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223A
Tech Comments: ROAD TEST VEHICLE FOR SMOKE, NOT SMOKINGH AT THIS , FOLLOW TSB 07 8 9 NO CODES, OIL LEVEL CORRECT, NO LEAKS IN INAKE & EXHAUST MANIFOLDS EVIDENT ROADTEST TO UPDATE PCM PRGRAM ROAD TEST OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 6E01 * * * * * * 27030
AWS Claim Key: 1439106 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223F
Cust Comments: CAMP 08C01 SEAT BACK WELDS
Tech Comments: 43502 08C01B 0.3HRS INSPECT SEAT BACK FRAME & INSTALL CLAMP
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 6F42 010702 F81Z 2520758 AA R02 07 27030
AWS Claim Key: 1439107 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223G
Cust Comments: CEHCK WEATHER STRIPPING AT BOTTOM OF DOORS , MUD SEEMS TO BE COMING IN SIDE
Tech Comments: INSPECT MUD COMING IN BOTTOM DOORS LOWER WEATHER STRIP NOT SEATING AGAINST BODY & BUCKELED. CLEAN & REPL. BOTH LOWER DOOR WEATHER STRIPS RECHECK NOTTOUCHING BODY IN PLACES ALIGN BOTH FRT DOORS TO TIGHTEN PRESSURE ON LOWER WEATHER STRIP RECHECK SEATS OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 13 5C02 050100 F81Z 4635 AB N51 69 30567
AWS Claim Key: 1190005 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:18-JUL-2008 Doc #:187663A
Cust Comments: SQUEAKING WHILE DRIVING. REPLACE U JOINT AND BEARINGS
Tech Comments: VERIFY CONCERN. RE&RE REAR DRIVESHAFT REPLACE SIEZED REAR U JOINT. ALL OK NOW
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 14 2G05 031405 * RECAL * E29 04 33765
AWS Claim Key: 1477211 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:28-AUG-2008 Doc #:188951A
Cust Comments: CHECK ENGINE LIGHT IS ON . VEHICLE IS REVING HIGH
Tech Comments: 54341 081302A 0.5HRS MIL LIGHT ON CONT. CODE P2002CHECK OASIS NEW TSB RELEASED JUNE 25 08 PERFORM TSB 08 13 2 REPROGRAM MODULES ROAD TEST OK
4play is offline
2008fx4diesel (03-15-2009)
post #3 of 3 (permalink) Old 03-11-2009, 08:01 PM Thread Starter
thank you for your time .
Oasis Request CMM7029 Ford Oasis requests 1 11-04-2007 11:25 PM
OASIS Request Please Zurler Ford Oasis requests 2 10-23-2007 01:35 PM
Oasis request please Fireguy Ford Oasis requests 1 10-23-2007 01:24 AM
OASIS Request midnight2004 Ford Oasis requests 1 10-23-2007 01:21 AM
OASIS request please? browns40 Ford Oasis requests 2 05-22-2007 01:22 AM
