oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JPscustoms, this thread has received 2 replies and been viewed 721 times.
post #1 of 3 (permalink) Old 03-12-2009, 12:49 AM Thread Starter
JPscustoms's Avatar
1ftnw21p94ea48004, thanks
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #2 of 3 (permalink) Old 03-12-2009, 04:18 PM
4play's Avatar
OASIS RESULT:
1FTNW21P94EA48004
03/12/2009
12:17:48
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
31 ENGINE CALIBRATION
WARNING MESSAGES
P05 MULTIPLE REPAIR VISIT POLICY DOES NOT APPLY TO CLP REPAIRS
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/28/2004 BUILD DATE
08/22/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/04/2009
DEALER: Zimmerman Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 015405 ODOMETER: 099498M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9P456AE COOLER - EGR 001 6005PA 42 DOES NOT OPERATE PROPERLY
6C3Z 8A080B COOLANT O/FLO BOTTLE 001 081103A
VC 7B 003 081103B
W302725 001 081103C
2L1Z 9F479AA MAP SENSOR 001 081103G
6C3Z 6K786EA CLAMP AIR COOLING 001 081613B
6051 GASKET CYL HEAD 000
VERIFIED CONCERNS PERFORMED DIAG HAD LACK OF POWER AND COOLANT LOSS WHITE SM OKE P132B P006A PERFORMED PSI TEST RADKIT TESTS FAILED AND FOUND EGR COOLER INTERNALLY LEAKING REMOVED AND REPLACED EGR COOLER REINSTALLED PERFORMED PRI OR APPROVAL CODE PAA1T REPLACED BOTTLE VENTED COOLANT FROM GLOW PLUGS RETEST ED STILL HAS POWER ISSUE PERFORMED PINPOIMNT TESTS KA AND FOUND TURBO CHARGE
06/23/2008
WARRANTY CLAIM NUMBER: 005545 ODOMETER: 086397M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6007D D1 POROSITY
8C3Z 12K073A TRNSDC ASY-C/SHT PSN 001 12650D60
000 9838A
DYE TESTED AND FOUND THE ICP AND CMP SENSORS LEAKING. REPLACED CMP AND ICP S ENSORS AND RECHECKED.
04/28/2008
WARRANTY CLAIM NUMBER: 003055 ODOMETER: 083790M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 072109A 55 PLUGGED/RESTRICTED
ROAD TEST VEHICLE AND VERIFIED CONCERN, EEC TEST AND CHEKCED FOR CODES,402,4 04 PRESENT,PERFORMED PIN-POINT TEST AND FOUND FAULTY EGR VALVE, INSTALLED NE W EGR VALVE PER TSB 7-21-9. REFLASHED MODULES TO LATEST CALIBRATION,ROAD TES T VEHICLE AND VERIFIED REPAIRS,OK.
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 0 2G05 031405 * RECAL * C50 79 3
AWS Claim Key: 50760 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2003 Doc #:01761050
Cust Comments: REPROGRAM MODULES PER PROGRAM 03T02
Tech Comments: RECALL PER SSM 03T02
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 24 * * * * * * * 35891
AWS Claim Key: 10230728 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05461 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: *-* St:IL Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:07249041
Cust Comments: RECALL 06E17
Tech Comments: PERFORMED RECALL
AWS Claim Key: 10201004 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05461 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: *-* St:IL Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:07249040
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: PERFORMED CUSTOMER ROAD TESTS
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 24 2H02 030008 5C3Z 6F089 A D42 41 35891
AWS Claim Key: 10201005 Trx Code: S07 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 05461 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: *-* St:IL Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:07249052
Cust Comments: C S THAT VEH VEH LACK POWER ONACCLEARTION
Tech Comments: VERIFIED COCNERN AND PERFORMED DIESEL PERFORMANCE DIAG P2283 PERFORMED PINPOINT TESTS ANS KA TESTS VGT TESTS AND FOUND VGT SOLENOID STICKING REMOVED AND REPLAECD VGT SOLENOID AND TEST DROVE RECHECKED OK NOW
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 24 2H01 031202 5C3Z 6C640 AA L65 D1 35891
AWS Claim Key: 10230729 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 05461 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: *-* St:IL Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:07249051
Cust Comments: C S THAT VEH LEAKKING OIL
Tech Comments: VERIFIED COCNERN AND PERFORMED DYE TESTS AND FOUND HOIT SIDE CAC TUBE LEAKING REMOVED AND CLEANED CAC TUBE AND REPLACED UPPER HOSE WITH NRE CLAMPS CLEANED OFF AND RETESTED OK NOW
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 25 6H08 011108 F81Z 2627000 BA G07 41 39419
AWS Claim Key: 10687040 Trx Code: P05 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 05461 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: *-* St:IL Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2006 Doc #:07445952
Cust Comments: C/S REAR PASS SIDE WINDOW BINDS AND CAN HEAR NOISE FROM DOOR
Tech Comments: INSTALL RT REAR WINDOW REGULATOR AND RECK WORKING PROPERLY NOW
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 25 5G03 050301 5C3Z 3050 A N59 30 39419
AWS Claim Key: 10636268 Trx Code: P05 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 05461 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: *-* St:IL Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2006 Doc #:07445951
Cust Comments: C/S THAT ON LFT OR RT TURNS THERES S SQUEEK NOISE FROM SUSPENSION
Tech Comments: INSPCT AND FOUND UPP AND LOW BALL JOINTS LOOSE,AND SQUEEKING REPL BALL JOINTS BOTH SIDES ALSO REPL VAC HUB SEALS AND O RINGS REASSEMBLE AND PERFORM ALIGNMENT SET TOW AND ROAD TEST OK NOW
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 28 6H01 011103 6C3Z 2523200 BA G09 42 47179
AWS Claim Key: 11049048 Trx Code: P05 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2007 Doc #:07988052
Cust Comments: RIGHT FRONT WINDOW MAKING A CLICKING NOISE WHEN WINDOW IS GOING UP
Tech Comments: VERIFIED CONCERN AND REPLACED RIGHT FRONT WINDOW REGULATOR RECHECKED OK NOW
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 29 2E06 100106 6C3Z 9G282 AA D42 42 48878
AWS Claim Key: 11117234 Trx Code: E72 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 05461 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: *-* St:IL Ctry Cd: USA Reg Cd: NA Repr Date:01-FEB-2007 Doc #:08090451
Cust Comments: LACKS POWER HESITATES ON ACCEL
Tech Comments: VERIFIED COCNERN PERFORMED DIESEL DIAG AS PER ATTCHED SHEET NO CODES PERFORMED KA TESTS VGT TESTS PASSED FOUND FUEL PSI 30 PSI LOW AND FUEL PUMP MAKING A WHINING NOISE REPLACED FUEL PUMP ASSEMBLY REINSTALLED CLEARED KAM AND RESET VGT STRATEGY TEST DROVE OK NOW
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 31 2H01 030008 3C3Z 6K854 DA E41 D1 51057
AWS Claim Key: 11390066 Trx Code: E72 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2007 Doc #:08338751
Cust Comments: EXHAUST LEAK
Tech Comments: REPLACE CRACKED TURBOCHARGER INLET PIPE.ALSO REPLACE CRACKED EGR SUPPLY PIPE.
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 44 1H03 030008 4C3Z 9F452 A N12 55 83790
AWS Claim Key: 12613780 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2008 Doc #:00305551
Cust Comments: LOUD NOISE FROM ENGINE WHEN TOWING SOUNDS LIKE TURBO OR WATER PUMP
Tech Comments: ROAD TEST VEHICLE AND VERIFIED CONCERN, EEC TEST AND CHEKCED FOR CODES,402,404 PRESENT,PERFORMED PIN POINT TEST AND FOUND FAULTY EGR VALVE, INSTALLED NEW EGR VALVE PER TSB 7 21 9. REFLASHED MODULES TO LATEST CALIBRATION,ROAD TEST VEHICLE AND VERIFIED REPAIRS,OK.
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 46 2E06 030008 3C3Z 9F838 EA L65 D1 86397
AWS Claim Key: 12721558 Trx Code: E72 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2008 Doc #:00554551
Cust Comments: C S EXCESSIVE ENGINE OIL LEAK
Tech Comments: DYE TESTED AND FOUND THE ICP AND CMP SENSORS LEAKING. REPLACED CMP AND ICP SENSORS AND RECHECKED.
1FTNW21P94EA48004 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-AUG-2003 28-SEP-2004 141422 USA 54 1A02 030102 * 6051 * D42 42 99498
AWS Claim Key: 13061522 Trx Code: E72 Labor Hrs: 17.4
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2009 Doc #:01540551
Cust Comments: C S ENGINE BOGS DOWN ON ACCEL AND BLOWS EXCESSIVE WHITE SMOKE OUT OF EXHAUST
Tech Comments: VERIFIED CONCERNS PERFORMED DIAG HAD LACK OF POWER AND COOLANT LOSS WHITE SMOKE P132B P006A PERFORMED PSI TEST RADKIT TESTS FAILED AND FOUND EGR COOLER INTERNALLY LEAKING REMOVED AND REPLACED EGR COOLER REINSTALLED PERFORMED PRIOR APPROVAL CODE PAA1T REPLACED BOTTLE VENTED COOLANT FROM GLOW PLUGS RETESTED STILL HAS POWER ISSUE PERFORMED PINPOIMNT TESTS KA AND FOUND TURBO CHARGER STICKING COKED UP
4play is offline
JPscustoms (03-12-2009)
post #3 of 3 (permalink) Old 03-12-2009, 07:13 PM Thread Starter
JPscustoms's Avatar
thanks man
Oasis Request mark1843 Ford Oasis requests 1 01-06-2008 01:09 AM
OASIS request please gregvw123 Ford Oasis requests 1 11-17-2007 02:37 AM
Oasis Request CMM7029 Ford Oasis requests 1 11-04-2007 11:25 PM
Oasis Request rthensley Ford Oasis requests 1 11-04-2007 11:22 PM
OASIS Request Please Zurler Ford Oasis requests 2 10-23-2007 01:35 PM
