oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JPscustoms, this thread has received 1 replies and been viewed 606 times.
post #1 of 2 (permalink) Old 03-14-2009, 01:05 AM Thread Starter
JPscustoms's Avatar
1ftnw21f31ec64028, thanks
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #2 of 2 (permalink) Old 03-15-2009, 07:03 AM
4play's Avatar
OASIS RESULT:
1FTNW21F31EC64028
03/15/2009
03:01:43
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
1F719S0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/24/2001 BUILD DATE
03/23/2001 SALE MILEAGE
00080
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
EXTENDED COVERAGES
0710 - EXPIRED
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: JEFFERY APPLEGATE
OPTIONS:
EXPIRATION DATE: 07/24/2005
DISTANCE: 75,000
RENTAL: 28 UP TO 5 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07278
ESP CONTRACT START DATE: 07/24/2001
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 6 6X04 010905 F65Z 17B676 AB M10 95 31614
AWS Claim Key: 6321189 Trx Code: E84 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2002 Doc #:00191401
Cust Comments: POWER MIRRORS INOPERATIVE ERRATIC
Tech Comments: WIRING HARNESS SHORTED FROM MIRROR SWITCH TO PASS. MIRROR PERFORMED DIA., REPAIRED WIRING HARNESS, RETESTED ALL OK.
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 6 7M81 150300 XW7Z 18808 AA A06 28 32677
AWS Claim Key: 6406953 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2002 Doc #:00197901
Cust Comments: SPEAKER IN DRIVER DOOR
Tech Comments: OPEN CIRCUT IN DRIVERS DOOR SPEAKER. PERFORMED DIA., REPLACED SPEAKER. RETESTED ALL OK.
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 9 3A11 070100 1C3Z 7000 FBRM P59 69 43232
AWS Claim Key: 8724182 Trx Code: 0710D Labor Hrs: 5
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2002 Doc #:00258701
Cust Comments: VEHICLE HAS NO SECOND GEAR WHILE DRIVING
Tech Comments: TRANSMISSION IS BURNT AND HAS LOW LINE PRESSURE REPLACE TRANSMISSION
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 10 5C02 050101 F81Z 4R602 LKE N22 13 43855
AWS Claim Key: 9099308 Trx Code: 0710D Labor Hrs: 3.6
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-APR-2002 Doc #:00265501
Cust Comments: VIBRATION IN VEHICLE WHILE TAKING OFF REPORT HAS SERVICE CONTRACT
Tech Comments: DRIVE SHAFT RUNOUT SPECS OUT OF BALANCE. TEST DROVE AND REPLACED DRIVE SHAFT
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 11 5O01 110201 YC3Z 3504 ABRM H21 30 49052
AWS Claim Key: 9279939 Trx Code: 0710D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2002 Doc #:00307101
Cust Comments: CUST STATS THAT FRONT END SOME TO HAVE SOME PLAY WHEN DRIVING
Tech Comments: ROAD TEST VEHICLE EXCESSIVE PLAY IN GEAR BOX TRIED TO ADJ SECTOR SHAFT WORN BADLY REPLACED GEAR BOX AND TEST DROVE
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 13 5N01 110301 F81Z 3304 BA H21 30 53074
AWS Claim Key: 9884916 Trx Code: 0710D Labor Hrs: 1.6
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2002 Doc #:00348001
Cust Comments: CUST STATS HAS SLACK IN FRONT END WHEN TURNING
Tech Comments: INNER DRAG LINK WORE OUT REPLACED LINK ***., CHECKED AND CORRECTED TOE.
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 17 2C01 030603 2C3Z 11002 AARM D02 42 66673
AWS Claim Key: 11874939 Trx Code: 0710D Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2002 Doc #:00487301
Cust Comments: VEHICLE STARTS AND DIES WILL NOT STAY RUNNING VEHICLE TOWED INTO SHOP
Tech Comments: STARTER INOP AT TIMES. PERFORMED DIA., REPLACED STARTER MOTOR.
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 17 * * * * * * * 66673
AWS Claim Key: 11825891 Trx Code: 01S21 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2002 Doc #:00487302
Cust Comments: RECALL #01S21 SEAT BELT BUCKLE
Tech Comments: PERFORMED RECALL 01S21 INSPECTION ONLY.
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 17 6H06 011103 YC3Z 7821537 AA G07 42 67844
AWS Claim Key: 12174660 Trx Code: 0710D Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2002 Doc #:00506002
Cust Comments: LEFT FRONT WINDOW WILL NOT GO DOWN ALL THE WAY
Tech Comments: TEST AND REPLACED LEFT FORNT DOOR WINDOW REGULATOR AND RUN
1FTNW21F31EC64028 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 23-MAR-2001 24-JUL-2001 152422 USA 18 3A06 07XXXX E7TZ 7086 A L72 D8 68863
AWS Claim Key: 12536768 Trx Code: 0710D Labor Hrs: 2.8
Dlr Cd-Sub Cd: 07278 - * Name: PITTSBURG FORD Ph: 903-8563322 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2003 Doc #:00535201
Cust Comments: CUSTOMER STATES TRANSMISSION FLUID LEAKING
Tech Comments: EXTENSION HOUSING GASKET LEAKING. OIL LEAK DIAG., REPLACED EXT. HOUSING GASKET AND PAN GASKET, ROAD TEST TO VERIFY REPAIR.
4play is offline
Request OASIS please Mustang50 Ford Oasis requests 1 06-15-2007 02:26 AM
Oasis request please Mustang50 Ford Oasis requests 2 06-15-2007 02:25 AM
Oasis Request Pandiger Ford Oasis requests 0 06-07-2007 05:09 AM
oasis request please 99stroke Ford Oasis requests 2 12-28-2006 12:23 AM
Oasis request please............ Motown Fire Ford Oasis requests 3 05-24-2006 03:19 AM
