oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jpna105, this thread has received 1 replies and been viewed 530 times.
post #1 of 2 (permalink) Old 03-14-2009, 11:35 AM Thread Starter
vin #1FTSW21P36EC62184
jpna105 is offline
post #2 of 2 (permalink) Old 03-15-2009, 07:05 AM
4play's Avatar
OASIS RESULT:
1FTSW21P36EC62184
03/15/2009
03:03:53
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/22/2006 BUILD DATE
01/27/2006 SALE MILEAGE
00250
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTSW21P36EC62184 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JAN-2006 22-MAR-2006 147406 USA 9 2E03 030402 4C3Z 9E527 AA D42 42 23105
AWS Claim Key: 2366105 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 02233 - * Name: DUTRO FORD-L/M INC Ph: 740-4526334 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2006 Doc #:18232502
Cust Comments: CUST STATES THAT TRUCK HAS HAD NO POWER SINCE TBC FAULT DISPLAYED ON DASH
Tech Comments: RAN EEC KOEC PO284 KOEO PO284 KOER PO284 KOEO INJECTOR ELECTRICAL SELF TEST PASS RAN CYL BALANCE FOUND #8 INJECTOR MECHANICALLY STUCK R&R FICM AND LEFT ROCKER COVER TO REPLACE #8 INJECTOR PUT LUBRICITY ADDITIVE IN FUEL CLEARED CODES ROAD TEST RERAN EEC KOEO PASS KOEC PASS KOER PASS PROBLEM REPAIRED
1FTSW21P36EC62184 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JAN-2006 22-MAR-2006 147406 USA 11 2E03 030402 4C3Z 9E527 AA D42 42 27617
AWS Claim Key: 2784492 Trx Code: S07 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 02233 - * Name: DUTRO FORD-L/M INC Ph: 740-4526334 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:18360801
Cust Comments: CUST STATES THAT TBC LIGHT IS ON AND ENGINE RUNS ROUGH
Tech Comments: RAN SELF TEST KOEC KOEO HAD CODE P0606 P0301 P0307 P0306 WOULD NOT START KOEO INJECTOR TEST PASSED PIN POINT TEST SAID TO CLEAR CODES RERUN SELF TEST CLEARED CODES RERAN SELF TEST KOEO PASSED CHE REPLACED NUMBER 1 7 INJECTOR STARTED RAN POWER BALLANCE MISSING ON NUMBER 6 REPLACED NUMBER 6 INJECTOR RESTARTED RERAN SELF TEST KOEC KOEO KOER KOEO INJECTOR TEST CODE P0305 P0303 RELACED NUMBER 3 AN 5 IN
1FTSW21P36EC62184 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JAN-2006 22-MAR-2006 147406 USA 17 2E03 030008 * 9E527 * D42 42 46751
AWS Claim Key: 4146968 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02233 - * Name: DUTRO FORD-L/M INC Ph: 740-4526334 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2007 Doc #:18904502
Cust Comments: ENGINE RUNS VERY ROUGH AND SMOKES WHEN COLD
Tech Comments: RAN EEC NO CODES REPROGRAMMED FICM PCM AND TCM PER TSB 07 5 4 ROAD TEST ALL OK
1FTSW21P36EC62184 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JAN-2006 22-MAR-2006 147406 USA 19 2E03 030402 4C3Z 9E527 AA D42 41 49564
AWS Claim Key: 4556695 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 02233 - * Name: DUTRO FORD-L/M INC Ph: 740-4526334 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2007 Doc #:19096801
Cust Comments: ENGINE IS RUNNIONG VERY BAD, LOOSES POWER UNDER LOAD
Tech Comments: RAN EEC KOEC PO266 PO272 KOEO P266 PO272 RAN CYL BALANCE TEST FOUND #2 #4 INJECTORS BAD FUEL PRESSURE 54 PSI KOEO INJECTOR ELECTRICAL ALL PASS R&R FICM AND LEFT ROCKER COVER AND OIL RAIL TO REPLACE #2 #4 INJECTORS CLEARED CODES ROAD TEST RERAN EEC ALL PASS RERAN POWER BALANCE ALL OK
1FTSW21P36EC62184 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JAN-2006 22-MAR-2006 147406 USA 22 2E03 03XXXX * 9E527 * D42 42 54037
AWS Claim Key: 5318519 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01920 - * Name: DON WOOD FORD, LINCOLN-MERCURY, INC. Ph: 740-5936641 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2008 Doc #:21559801
Cust Comments: VEHICLE MISSES AND RUNS POOR
Tech Comments: ROAD TEST, COMPLETED EEC TEST & PINPOINT TESTS, PASSES, REPROGRAMMED PCM, TCM & FICM MODULES, RETEST EEC, PASSES, ROAD TEST OKAY
4play is offline
jpna105 (03-18-2009)
Oasis Request 75867586 Ford Oasis requests 4 06-20-2007 10:42 PM
Oasis Request Pandiger Ford Oasis requests 0 06-07-2007 05:09 AM
Oasis Request superxcrewfx4 Ford Oasis requests 1 06-07-2007 03:36 AM
Another oasis request sbuck Ford Oasis requests 1 06-07-2007 03:26 AM
Oasis Request Please G SQRD Ford Oasis requests 1 07-14-2006 09:35 AM
