03' 250 SD Oasis Please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by firearson911, this thread has received 1 replies and been viewed 414 times.
post #1 of 2 (permalink) Old 03-14-2009, 01:53 PM Thread Starter
Vin 1FTNX20P23EC51426
Thanks!
firearson911 is offline
post #2 of 2 (permalink) Old 03-15-2009, 07:10 AM
4play's Avatar
OASIS RESULT:
1FTNX20P23EC51426
03/15/2009
03:09:49
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
31 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/29/2003 BUILD DATE
02/27/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/24/2008
DEALER: Ford of West Memphis
WARRANTY CLAIM NUMBER: 123178 ODOMETER: 109816M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 080407A 42 DOES NOT OPERATE PROPERLY
F81Z 8287EA CLAMP ASY-RAD HOSE 001
XO 15W405QSD 001
02/21/2008
DEALER: El Centro Motors
WARRANTY CLAIM NUMBER: 001132 ODOMETER: 107316M
LABOR OP
CONDITION CODE
CONDITION DESC
TAP5 RENTAL - LINC 000 82 FREIGHT/POSTAGE/MAINTENANCE
. RENTAL
1FTNX20P23EC51426 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-FEB-2003 29-MAY-2003 144577 USA 17 * * * * * * * 39729
AWS Claim Key: 7817188 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02176 - * Name: FORD OF MANSFIELD Ph: 419-5291800 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2004 Doc #:15513701
Cust Comments: 04S15 NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK.
Tech Comments: RECALL 04S15 INSPECT GROUND STRAP AND REPLACED GROUND STUD
1FTNX20P23EC51426 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-FEB-2003 29-MAY-2003 144577 USA 36 * * * * * * * 62275
AWS Claim Key: 13703005 Trx Code: 06E17 Labor Hrs: 0
Dlr Cd-Sub Cd: 02176 - * Name: FORD OF MANSFIELD Ph: 419-5291800 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:01-MAY-2006 Doc #:20339901
Cust Comments: 1 REIMBURSMENT AMOUNT OF 92.77 PER RECALL 06E17
Tech Comments: 1 PROGRAM CODE 06E17 MISC EXPENSE REFUND MIS EXPENSE ADMIN
1FTNX20P23EC51426 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-FEB-2003 29-MAY-2003 144577 USA 42 * * * * * * * 81497
AWS Claim Key: 14546622 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02176 - * Name: FORD OF MANSFIELD Ph: 419-5291800 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2006 Doc #:21821601
Cust Comments: RECALL 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: 1 PERFORM RECALL 06E17
AWS Claim Key: 14546621 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02176 - * Name: FORD OF MANSFIELD Ph: 419-5291800 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2006 Doc #:21821602
Cust Comments: 59B01 ONE TIME ASSURANCE TEST DRIVE.
Tech Comments: 1 ROAD TEST
1FTNX20P23EC51426 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-FEB-2003 29-MAY-2003 144577 USA 58 6Y20 000000 * TAP5 * A99 82 107316
AWS Claim Key: 15859598 Trx Code: TAP5 Labor Hrs: 0
Dlr Cd-Sub Cd: 05591 - * Name: EL CENTRO MOTORS Ph: 760-3528030 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2008 Doc #:00113252
Cust Comments: RENTAL TAP
Tech Comments: . RENTAL
1FTNX20P23EC51426 T/F7 F T/BD T/BD T/B A1 T/BE T/YB 27-FEB-2003 29-MAY-2003 144577 USA 59 2H01 030407 3C3Z 6K682 CBRM D42 42 109816
AWS Claim Key: 15924854 Trx Code: SPW Labor Hrs: 5.6
Dlr Cd-Sub Cd: 05805 - * Name: FORD OF WEST MEMPHIS Ph: 870-7359800 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:24-MAR-2008 Doc #:12317801
Cust Comments: CHECK FOR VEHICLE HAS NO POWER
Tech Comments: CHECKED CMDTCS PO299 REFERENCE TSB 08 4 7 REMOVE TURBO FOR INSPECTION PER TSB FOUND IMPELLAR WHEEL LOOSE & HOUSING DAMAGED REPLACED TURBO RETESTED
4play is offline
