Oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by w_huisman, this thread has received 1 replies and been viewed 425 times.
post #1 of 2 (permalink) Old 03-16-2009, 03:15 PM Thread Starter
w_huisman
w_huisman's Avatar
Oasis please
1fmsu45px5ed47903
w_huisman at yahoo dot com
Thanks!
http://thumb15.webshots.net/t/75/75/8/60/86/2734860860046140835zjSXvY_th.jpg
2006 F250 6.0 Lariat
cc sb 4x4 auto 70k, coolant filter, Insight + analog FP gauge. VXCF9H7 strategy
All else stock.
w_huisman is offline
post #2 of 2 (permalink) Old 03-16-2009, 07:00 PM
4play's Avatar
OASIS RESULT:
1FMSU45PX5ED47903
03/16/2009
14:59:30
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
31 ENGINE CALIBRATION
5L110M0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/21/2006 BUILD DATE
09/22/2005 SALE MILEAGE
00257
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/10/2008
DEALER: Boyer Ford Trucks Sioux Falls
WARRANTY CLAIM NUMBER: 339677 ODOMETER: 082189M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 004 6005F 42 DOES NOT OPERATE PROPERLY
W302725 001 6005F1
OSP 001 6005F2
5C3Z 12224A 3 WAY VACUUM CONNECT 001 6005F6
000 6005F33
000 6005F45
000 6005F1X1
000 9527AT
82189 CHECKED EEC FOR CODES, HAS CONTRIBUTION CODES FOR #1 & #3 CYLINDERS. COLD STARTED WHILE MONITOR POWER BALANCE , CYLINDERS #1, #2, #3, & #6 WERE MISSFIREING. RAN BUZZ TEST & RELATIVE COMPRESSION, OK. CHECKED FUEL PRESSU RE, OK. REMOVED BOTH VALVE COVERS TO REPLACE INJECTORS, 1,2,3, & 6. REPLAC ED CONNECTOR ON EBP SENSOR & REPOSITIONED EBP TUBE (CONNECTOR WAS RUBBING O
1FMSU45PX5ED47903 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-SEP-2005 21-JAN-2006 158590 USA 2 * * * * * * * 2711
AWS Claim Key: 3974846 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09400 - * Name: ELK RIVER FORD-MERCURY INC Ph: 763-4412300 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2006 Doc #:158460E
Cust Comments: DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT.
Tech Comments: 2711 INSTALLED COOLANT LABEL AND ADJUSTED COOLANT LEVEL.
1FMSU45PX5ED47903 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-SEP-2005 21-JAN-2006 158590 USA 2 1G04 0305XX * 6B209 * N11 42 2711
AWS Claim Key: 3974845 Trx Code: 2 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 09400 - * Name: ELK RIVER FORD-MERCURY INC Ph: 763-4412300 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2006 Doc #:158460D
Cust Comments: CUST STATES THE FAN BELT SQUEAKS
Tech Comments: 2711 INSPECTED FAN BELT AND FOUND THAT THE BELT HAD A SLIGHT GLAZE ON IT. I DEGLAZED THE BELT AND FOUND THAT THE SQUEAK IS NOW GONE.
AWS Claim Key: 3974844 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09400 - * Name: ELK RIVER FORD-MERCURY INC Ph: 763-4412300 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2006 Doc #:158460A
Cust Comments: EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTROL MODULE RECALIBRATIONS.
Tech Comments: 2711 PERFORMED RECALL. I REPROGRAMMED THE MODULES. LABOR OP. 05E16B
1FMSU45PX5ED47903 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-SEP-2005 21-JAN-2006 158590 USA 6 5G05 040001 * FRONT * H21 W6 6724
AWS Claim Key: 5366552 Trx Code: 2 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 09441 - * Name: BOYER FORD TRUCKS, INC. Ph: 612-3786000 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2006 Doc #:287302A
Cust Comments: WANDERS AT HWY SPEEDS
Tech Comments: 6724 PERFORMED ALIGNMENT, CHANGE CASTER CAMBER ON BOTH SIDES, SET TOE, CENTER WHEEL....
1FMSU45PX5ED47903 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-SEP-2005 21-JAN-2006 158590 USA 13 2E03 030402 4C3Z 9E527 AA D13 42 33436
AWS Claim Key: 7027950 Trx Code: S07 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 07237 - * Name: SCHOENHARD FORD Ph: 605-3526464 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:01876301
Cust Comments: ENGINE RUNS ROUGH AND LACKS POWER
Tech Comments: DIESEL ENGINE PERFORMANCE DIAGNOSTICS CK FUEL PRESSURE AND RAN COMPRESSION TEST REP LACE # 5 CYLINDER INJECTOR ON RIGHT BANK AND TEST DRIVE MILEAGE INCORRECTLY ENTERED CORRECT MILEAGE IS 34436
1FMSU45PX5ED47903 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-SEP-2005 21-JAN-2006 158590 USA 18 2E03 030402 4C3Z 9E527 AA D36 28 51904
AWS Claim Key: 8050551 Trx Code: S07 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 03540 - * Name: DEWEY FORD, INC. Ph: 515-2894949 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-2007 Doc #:43201601
Cust Comments: DIESEL ENGINE RUNNING POORLY
Tech Comments: PERFORMED DIESEL PERFORMANCE DIAGNOSTICS RAN IDS TEST. CODES P0263 P0269 P0281 P0299 PRESENT. CHECKED FUEL PRESSURE. REPLACED INJECTORS #1 AND #7. RE RAN. REPLACED #3 INJECTOR. TEST DROVE WITH FUEL PRESSURE GAUGE. FUEL PRESSURE WOULD DROP TO 40PSI. REPLACED PRESSURE REGULAT OR. RETEST. REPLACED FUEL PUMP ASSY. ROAD TEST AND RETEST OK
1FMSU45PX5ED47903 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 22-SEP-2005 21-JAN-2006 158590 USA 35 2E03 030402 4C3Z 9E527 BRM D42 42 82189
AWS Claim Key: 10587879 Trx Code: S07 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 01869 - * Name: BOYER FORD TRUCKS SIOUX FALLS Ph: 605-3366100 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2008 Doc #:339677A
Cust Comments: CHECK ENGINE RUNS ROUGH, LOST POWER
Tech Comments: 82189 CHECKED EEC FOR CODES, HAS CONTRIBUTION CODES FOR #1 & #3 CYLINDERS. COLD STARTED WHILE MONITOR POWER BALANCE , CYLINDERS #1, #2, #3, & #6 WERE MISSFIREING. RAN BUZZ TEST & RELATIVE COMPRESSION, OK. CHECKED FUEL PRESSURE, OK. REMOVED BOTH VALVE COVERS TO REPLACE INJECTORS, 1,2,3, & 6. REPLACED CONNECTOR ON EBP SENSOR & REPOSITIONED EBP TUBE (CONNECTOR WAS RUBBING ON
4play is offline
