might buy this one - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by munchie, this thread has received 1 replies and been viewed 653 times.
post #1 of 2 (permalink) Old 03-17-2009, 12:24 AM Thread Starter
might buy this one
1FTSX21PX5EA80266 thanks
munchie is offline
post #2 of 2 (permalink) Old 03-18-2009, 02:08 AM
4play's Avatar
OASIS RESULT:
1FTSX21PX5EA80266
03/17/2009
22:07:17
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/30/2005 BUILD DATE
09/20/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/10/2008
DEALER: Les Stumpf Ford
WARRANTY CLAIM NUMBER: 197393 ODOMETER: 035281M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 002 6007D D8 FAILED GASKET/SEAL
3C3Z 6C315AA SENSOR CRANK TIMING 001 12650D57
000 MT6007
CHECK OVER FOR LEAKS, ENGINE OIL DRAIN PLUG LOOSE, TIGHTEN P LUG AND CLEAN O FF OIL RESIDUE FROM UNDERSIDE OF ENGINE, ADDE D 2 BOTTLES OF DYE TO OIL, NEE D TO RECHECK IN APPROX. 400 MI COME BACK TO HAVE CHECKED IN 100 MILES CHECK OIL LEAK, REPLACE CRANK SENSOR, CLEAN OFF ENGINE CLOSED AT WPI
04/10/2008
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9P458AA KIT - VLV EGR 001 ADD 42 DOES NOT OPERATE PROPERLY
4C4Z 8592AA CONNECTION-CYL HD WA 001 8005D
000 8592A
CHECK COOLANT LEAK, PRESSUE TEST, REPLACE EGR COOLER COOLANT HOSE AND SEALS REFIL COOLANT WPI
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 0 2H02 030008 5C3Z 6F089 A D42 42 223
AWS Claim Key: 1826848 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2005 Doc #:06965101
Cust Comments: GUEST STATES VEHICLE HAS ABSOLUTELY NO POWER INSP ADVISE TECH VERIFIED THE CONCERN AND TECH FOUND VGT SELECTOR TO BE
Tech Comments: BAD TECH REPLACED THE VGT AND ALL RECHECKED GOOD
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 6 * * * * * * * 8469
AWS Claim Key: 3300273 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2006 Doc #:07925401
Cust Comments: RECALL 05E15 EXHAUST BACK PRESSURE SENSOR REPLCMENT
Tech Comments: RECALL 05E15 COMPLETE EXHAUST BACK PRESSURE SENSOR RE PLACED
AWS Claim Key: 3282574 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2006 Doc #:07925402
Cust Comments: RECALL 59B01 TEST DRIVE
Tech Comments: RECALL 59B01 TEST DRIVE COMPLETE
AWS Claim Key: 3300272 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2006 Doc #:07925403
Cust Comments: RECALL 05B23 DE GAS BOTTLE REFILL AND LABEL
Tech Comments: RECALL 05B23 DE GAS BOTTLE FILLED TO PROPER LEVEL
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 10 6B07 010809 4C3Z 16450 BAA B66 81 12058
AWS Claim Key: 5053848 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:08487501
Cust Comments: GUEST STATES THAT PASSANGER SIDE RUNNING BOARD IS STARTING PIT AND RUST.
Tech Comments: REPLACED PASS SIDE RUNNING BOARD PER AUTH FORD DIGITAL IMAGE # PAABK AND BUD M.
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 15 7P01 110501 4C3Z 13K359 AAA N33 42 17812
AWS Claim Key: 6159313 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:19-OCT-2006 Doc #:09187701
Cust Comments: GUEST HEARS A CLICKING NOISE UNDER DASH ABOUT EVERY 30 SEC
Tech Comments: TECH VERIFIED THE CONCERN AND TECH FOUND THE MULTI FUNCTION SWITCH TO BE SHORTING TECH REPLACED THE SWITCH AND ALL RECHECKED GOOD TECH FIRST CONTACTED HAOT LINE AND THEY RECOMENDED REPLACE IN RELAY,NO HELP,THEN USING EVTM ISOLATED TO MULTI FUNCTION SWITCH,WHEN DISCONNECTED TICKING GONE WHEN CONNECTED TICKIG PRESENT
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 22 6Q06 011902 * 17B807 * F07 P4 23911
AWS Claim Key: 8293293 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2007 Doc #:10048803
Cust Comments: GUEST STATES THE REAR BUMPER IS BUBBLING PAINT INSP ADVISE
Tech Comments: SUBLET TO BODYSHOP FOR PAINTING
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 22 5R14 000301 5C3Z 14A664 A G29 42 23911
AWS Claim Key: 8293294 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2007 Doc #:10048801
Cust Comments: GUEST STATES AFTER THE VEHICLE IS SHUT OFF KEY IS PULLED OUT THE KEY CHIME STILL GOES OFF ALSO THE DRIVERS DOOR LOCK WORK S ON ITS OWN IF THE STEERING WHEEL IS WORKING W THE TILT GUEST CAN
Tech Comments: DIAGNOSE AND REPLACE CLOCKSPRING
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 24 6Y20 000001 * MISC * A99 82 23910
AWS Claim Key: 8185211 Trx Code: P98 Labor Hrs: 0
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:16-JUL-2007 Doc #:10328501
Cust Comments: GUEST STATES THAT WINDSHIELD IS CHIPPED BOTH TOP CORNERS INSIDE OF GLASS
Tech Comments: VERIFIED AFTER DISCUSSIONS WITH MARILYN AT FORD CS 1 888 333 9115 XT 7442 REPLACE WIND SHIELD UNDER P98 434 PLUS TAX 455.70 AUTO GLASS SPECIALISTS TO WORK
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 25 6N07 010801 5C3Z 8213 AA B66 81 24105
AWS Claim Key: 8350137 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2007 Doc #:10382101
Cust Comments: FRONT FORD EMBLEM IS TURNING COLORS
Tech Comments: REPLACED FRONT GRILL EMBLEM
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 33 2F03 030706 3C3Z 6C315 AA L65 D8 35281
AWS Claim Key: 9717188 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 06249 - * Name: LES STUMPF FORD Ph: 920-7315211 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2008 Doc #:19739301
Cust Comments: ENGINE OIL LEAK POSSIBLE REAR MAIN SEAL OR OIL PAN GASKET
Tech Comments: CHECK OVER FOR LEAKS, ENGINE OIL DRAIN PLUG LOOSE, TIGHTEN P LUG AND CLEAN OFF OIL RESIDUE FROM UNDERSIDE OF ENGINE, ADDE D 2 BOTTLES OF DYE TO OIL, NEED TO RECHECK IN APPROX. 400 MI COME BACK TO HAVE CHECKED IN 100 MILES CHECK OIL LEAK, REPLACE CRANK SENSOR, CLEAN OFF ENGINE CLOSED AT WPI
1FTSX21PX5EA80266 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-SEP-2004 30-JUL-2005 141561 USA 33 1G01 03XXXX 4C4Z 8592 AA L87 42 35281
AWS Claim Key: 9717187 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 06249 - * Name: LES STUMPF FORD Ph: 920-7315211 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2008 Doc #:19739302
Cust Comments: COOLANT LEAK
Tech Comments: CHECK COOLANT LEAK, PRESSUE TEST, REPLACE EGR COOLER COOLANT HOSE AND SEALS REFIL COOLANT WPI
4play is offline
munchie (03-18-2009)
