Thanks! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by w_huisman, this thread has received 1 replies and been viewed 473 times.
post #1 of 2 (permalink) Old 03-17-2009, 10:59 PM Thread Starter
w_huisman
w_huisman's Avatar
Thanks!
1FTSW21P85EB75461
w_huisman at yahoo dot com!
Thanks again!
http://thumb15.webshots.net/t/75/75/8/60/86/2734860860046140835zjSXvY_th.jpg
2006 F250 6.0 Lariat
cc sb 4x4 auto 70k, coolant filter, Insight + analog FP gauge. VXCF9H7 strategy
All else stock.
w_huisman is offline
post #2 of 2 (permalink) Old 03-18-2009, 02:10 AM
4play's Avatar
OASIS RESULT:
1FTSW21P85EB75461
03/17/2009
22:09:42
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
ALL WARRANTY CANCELLED; TITLE BRANDED(CODE T1)
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/27/2005 BUILD DATE
12/15/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0701 - USA 2005 NEW 72/75,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: STEVE COLLIER
OPTIONS:
EXPIRATION DATE: 01/27/2011
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 20301
ESP CONTRACT START DATE: 01/27/2005
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
A T T E N T I O N *** ALL ESP REPAIRS REQUIRE PRIOR APPROVAL ***
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
12/27/2008
DEALER: Sioux City Ford Lincoln Mercur
WARRANTY CLAIM NUMBER: 290305 ODOMETER: 049320M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 004 6005F 42 DOES NOT OPERATE PROPERLY
6C3Z 6C640A CONNECTION A/C DUCT 001 6005F13
6C2Z 6K786AA CLAMP AIR COOLING 001 6005F1
000 6005F2
000 6005F14
000 6005F18A
000 9527AR
49320 VERIFY CONCERN, ENGINE RUNNING VERY ROUGH, AND MISSING , PERFORMED ST EPS 1-7, ON DIAG SHEET, REPLACED #1-#3#5#7 INJECTORS FOR CONCERN, DROVE TRU CK TO CLEAR OUT AIR AND EX.
1FTSW21P85EB75461 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2004 27-JAN-2005 171171 USA 13 * * * * * * * 16743
AWS Claim Key: 3675359 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2006 Doc #:32583702
Cust Comments: PROGRAM 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL
Tech Comments: CUSTOMER SATISFACTION PROGRAM CORRECT DE GAS BOTTLE FILL LEVEL AND ATTACH LABEL
AWS Claim Key: 3675360 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2006 Doc #:32583701
Cust Comments: PERFORM EMISSION RECALL 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT.
Tech Comments: REPLACED EP SENSOR AND UPDATED MODS AS PER 05E15 1
AWS Claim Key: 3675358 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2006 Doc #:32583703
Cust Comments: RECALL #59B01 CUST ASSURANCE TEST DRIVE
Tech Comments: RD TEST AS PER 59B01 IS OK 1
1FTSW21P85EB75461 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2004 27-JAN-2005 171171 USA 15 2H01 030008 * 6K682 * L65 D8 18759
AWS Claim Key: 4475256 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:33445701
Cust Comments: CUST STATES THERE IS OIL LEAKING FROM TURBO AREA....
Tech Comments: BLACK LIGHT.TURBO O RING LEAKING.REMOVED TURBO.REPLACED O RING. B
1FTSW21P85EB75461 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2004 27-JAN-2005 171171 USA 25 2E04 03XXXX 4C3Z 9B246 A D02 42 31597
AWS Claim Key: 7123053 Trx Code: E84 Labor Hrs: 8
Dlr Cd-Sub Cd: 20301 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: 623-8428600 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2007 Doc #:40165301
Cust Comments: CUSTOMER STATES CUSTOMER SHUT ENG OFF NOW IT WONT START ENG CRANKS NO START.......
Tech Comments: VERIFIED CRANK NO START.SCAN PCM P2291.RUN DATA LOGGER AND FOUND ICP PRESSURE LOW AT 285 PSI.AIR CHECK HIGH PSI OIL SYSTEM.FOUND PUMP DISCHARGE FITTING BROKEN. REPLACE FITTING AND INSTALL REINFORCING BRACKET PER TSB 06 17 06.ROAD TEST OK.ERASE CODES AND RETEST,ALL PASS.
1FTSW21P85EB75461 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 15-DEC-2004 27-JAN-2005 171171 USA 48 2E03 030402 4C3Z 9E527 BRM D13 42 49320
AWS Claim Key: 10678400 Trx Code: 0701D Labor Hrs: 3.2
Dlr Cd-Sub Cd: 03292 - * Name: SIOUX CITY FORD LINCOLN MERCURY Ph: 712-2778420 St:IA Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2008 Doc #:290305A
Cust Comments: RUNS ROUGH , DIAG CALL EST
Tech Comments: 49320 VERIFY CONCERN, ENGINE RUNNING VERY ROUGH, AND MISSING , PERFORMED STEPS 1 7, ON DIAG SHEET, REPLACED #1 #3#5#7 INJECTORS FOR CONCERN, DROVE TRUCK TO CLEAR OUT AIR AND EX.
4play is offline
