2004 OASIS Report Please. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by s20055, this thread has received 1 replies and been viewed 779 times.
post #1 of 2 (permalink) Old 03-19-2009, 12:17 PM Thread Starter
VIN# 1FTWW33P54EC23288
Thank you!
s20055 is offline
post #2 of 2 (permalink) Old 03-19-2009, 03:55 PM
4play's Avatar
OASIS RESULT:
1FTWW33P54EC23288
03/19/2009
11:54:30
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/12/2004 BUILD DATE
02/02/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
07/14/2008
DEALER: Courtesy Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 250242 ODOMETER: 080869M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 12224A 3 WAY VACUUM CONNECT 001 05S34H
RECALL COMPLETED RECALL 05S34 FOUND TO HAVE OLD HARNESS INSTALLED ICP CON NECTOR KIT AND REPAIRED HARNESS TO FICM
07/14/2008
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15G
RECALL COMPLETED RECALL 05E15 INSTALLED UPDATED EBP SENSOR AND RECALIBRAT ED PCM
07/14/2008
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
RECALL COMPLETED RECALL 59B01 ROAD TESTED POST REPAIRS ALL OK
07/14/2008
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6701A CRANKSHAFT REAR SEAL 001 6007D D8 FAILED GASKET/SEAL
OSP 001 6701A
VC 7B 002
VERIFIED CONCERN CLEANED ENGINE OFF INSTALLED DYE, ROAD TEST CLACK LIGHT FOU ND OIL LEAKING FROM REAR MAIN SEAL REMOVED TRANSMISSION AND FLYWHEEL REMOV ED AND REPLACED REAR AMIN SEAL RETEST OK
07/14/2008
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 9424A 42 DOES NOT OPERATE PROPERLY
4C3Z 9424C INTAKE MANIFOLD 001 9424A1
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 9424AZN
000 MT080407
VERIFIED CONCERN RAN KEOE FOUND P0299 ROAD TESTED VEHICLE NO POWER, RAN EGR TEST: FAILED: FOUND EGR VALVE STUCK OPEN, REMOVED EGR VALVE FOUND INTAKE F ULL OF CARBON AND VALVE STUC OPEN REMOVED TURBO PEDISTAL, ALTERNATORS, FAN A SSY, REMOVED AND REPLACED INTAKE MANIFOLD UNABLE TO CLEAN, TRANSFERED PORTS REINSTALLED COMPONENTS, INSTALLED NEW EGR VALVE RETEST FAILED TEST TURBOCHAR
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 1 3A15 070102 4C3Z 7G383 AA P67 42 4846
AWS Claim Key: 1270684 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUL-2004 Doc #:19798501
Cust Comments: CUSTOMER STATES THAT THE TRANSMISSION INTERMITTENTLY HAS A DELAY WHEN ENGAGING INTO REVERSE AND IT WILL SURGE
Tech Comments: LINE PRESSURE SOLEINOD A TESTD DROVE VERIFED CONCERN. RAN ELECTRONIC TRANS DIA PASS. CHECKED LINE PRESSURE FOUND SLOW TO COME UP AND OUT OF
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 1 5G05 050300 * 3001 * H21 42 4846
AWS Claim Key: 1270682 Trx Code: 2 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUL-2004 Doc #:19798503
Cust Comments: PLEASE CHECK AND ADVISE ON VEHICLE WNDERING AT HIGHWAY SPEEDS..
Tech Comments: TEST DROVE AT HIGHWAY SPEEDS AND FELT NO WANDING PROBLEM ON NORMAL ROAD SERFACE. TECH 292 PERFORMED ALIGNMENT CHECK AND FOUND ALIGNMENT TO BE WITH IN SPECIFICATIONS,RAN OASIS AND FOUND NO TSB SSM.PERFORMED
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 1 2G04 031401 * 12A650 * D36 42 4846
AWS Claim Key: 1270683 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUL-2004 Doc #:19798502
Cust Comments: PLEASE CHECK AND ADVISE ON ENGINE SURGING WHEN STARTED. HAS TO TAP THE THE THROTTLE AND IT WILL CLEAR OUT..
Tech Comments: UPDATED CALIBRATION SSM 17624 VERIFED CONCERN. CHECKED FOR UPDATED CALIBRATION FOUND. SSM ON CONCERN. REPROGRAMMED PCM TCM. TEST DROVE SURGING
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 5 2G04 031401 * 12A650 * D13 42 18113
AWS Claim Key: 2373543 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2004 Doc #:20281501
Cust Comments: PLEASE CHECK AND ADVISE ON ENGINE MISSING WHEN COLD STARTED....AND SURGING
Tech Comments: NO PROBLEM FOUND. TEST DROVE, COULD NOT DUPLICATE CONCERN. INSTALLED WDS, FOUND NO DTC S. RAN OASIS, FOUND NO SSM S OR
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 5 7S06 030008 4C3Z 12B637 CA D50 42 18551
AWS Claim Key: 2581926 Trx Code: S07 Labor Hrs: 7.4
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:01-NOV-2004 Doc #:20309801
Cust Comments: WILL BE DRIVING ALONG SAY 50MPH IN O DRIVE SLIGHT PULL .. WATER IN FULE LIGHT COMES ON... NO THROTTLE... LIGHT
Tech Comments: FAULTY ENGINE WIRE HARNESS. VERIFIED CONCERN, RAN PERFORMANCE DIAGNOSITICS, FOUND DTC P2614 AND P2617, FOUND FAULTY ENGINE HARNESS.
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 8 5V01 050306 1C3Z 3B396 CB P82 41 24065
AWS Claim Key: 3770295 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2005 Doc #:20628702
Cust Comments: CHECK. DRIVERS SIDE 4X4 HUB NOT DISENGAGING WANTS TO KEEP KICKING IN AND OUT
Tech Comments: VERIFIED CONCERN,CHECKED OASIS,PINPOINTED TO D S LOCKING HUB IS BAD. REPLACED D S LOCKING HUB ASSY.AND VERIFIED REPAIR OK AT THIS TIME..TECH 213.(WARRANTY)....
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 8 1H03 030008 3C3Z 9F452 AC D50 42 24065
AWS Claim Key: 3770294 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2005 Doc #:20628703
Cust Comments: COLD START ? RATTLE WHEN BACKING UP... ALSO.. IDLE SERGES UP AND DOWN REAL BAD.. LOPES
Tech Comments: FAULTY EGR VALVE. TEST DROVE, VERIFIED CONCERN. RAN PERFORMANCE DIAGNOSTICS, PERFORMED VISUAL INSPECTION, CHECKED FUEL AND OIL, ALL OK.
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 9 2H01 031202 5C3Z 6C640 AA D50 42 25980
AWS Claim Key: 4566653 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2005 Doc #:20746101
Cust Comments: INNER COOLER HOSE KEEPS BLOWING OFF.. NOW POWER ETC...
Tech Comments: FAULTY INTECOOLER TUBE. VERIFIED CONCERN, FOUND RUBBER TUBE ON TURBO FAULTY. REPLACED TUBE AND CLAMPS, TEST DROVE, OK. TECH 767
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 42 2E03 030008 * 9E527 * D50 42 55981
AWS Claim Key: 12271183 Trx Code: E72 Labor Hrs: 8
Dlr Cd-Sub Cd: 08503 - * Name: GUS JOHNSON FORD Ph: 509-9241000 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:14-NOV-2007 Doc #:25199401
Cust Comments: OIL HAS DIESEL FUEL IN IT..
Tech Comments: FAULTY INJECTOR ORINGS. VERIFIED CONCERN, INSTALLED DYE IN FUEL SYSTEM, PRESSURE TESTED FUEL SYSTEM. REMOVED VALVE COVERS AND FOUND FUEL INJECTOR LEAKING BETWEEN CYLINDER HEAD AND INJECTOR. REMOVED ALL INJECTORS AND REPLACED INJECTOR ORINGS. RETEST, ALL OK. TECH 767 6.0L 5R110W
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 50 1D01 03XXXX 3C3Z 6701 A L65 D8 80869
AWS Claim Key: 12774822 Trx Code: E72 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2008 Doc #:25024204
Cust Comments: CUSTOMER STATES ENGINE OIL LEAK
Tech Comments: VERIFIED CONCERN CLEANED ENGINE OFF INSTALLED DYE, ROAD TEST CLACK LIGHT FOUND OIL LEAKING FROM REAR MAIN SEAL REMOVED TRANSMISSION AND FLYWHEEL REMOVED AND REPLACED REAR AMIN SEAL RETEST OK
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 50 * * * * * * * 80869
AWS Claim Key: 12774825 Trx Code: 05S34 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2008 Doc #:25024201
Cust Comments: PERFORM RECALL 05S34
Tech Comments: RECALL COMPLETED RECALL 05S34 FOUND TO HAVE OLD HARNESS INSTALLED ICP CONNECTOR KIT AND REPAIRED HARNESS TO FICM
AWS Claim Key: 12774823 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2008 Doc #:25024203
Cust Comments: PERFORM RECALL 59B01
Tech Comments: RECALL COMPLETED RECALL 59B01 ROAD TESTED POST REPAIRS ALL OK
1FTWW33P54EC23288 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2004 12-JUN-2004 174447 USA 50 2H01 030407 4C3Z 6K682 CBRM E29 42 80869
AWS Claim Key: 12802538 Trx Code: E72 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2008 Doc #:25024205
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT ON
Tech Comments: VERIFIED CONCERN RAN KEOE FOUND P0299 ROAD TESTED VEHICLE NO POWER, RAN EGR TEST: FAILED: FOUND EGR VALVE STUCK OPEN, REMOVED EGR VALVE FOUND INTAKE FULL OF CARBON AND VALVE STUC OPEN REMOVED TURBO PEDISTAL, ALTERNATORS, FAN ASSY, REMOVED AND REPLACED INTAKE MANIFOLD UNABLE TO CLEAN, TRANSFERED PORTS REINSTALLED COMPONENTS, INSTALLED NEW EGR VALVE RETEST FAILED TEST TURBOCHARGER NOT RESPONDING.
AWS Claim Key: 12774824 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2008 Doc #:25024202
Cust Comments: PERFORM RECALL 05E15
Tech Comments: RECALL COMPLETED RECALL 05E15 INSTALLED UPDATED EBP SENSOR AND RECALIBRATED PCM
4play is offline
2004 F350 Report cjmair Ford Oasis requests 8 04-01-2009 03:35 PM
OASIS Report Please Cooper443irty Ford Oasis requests 1 01-06-2008 01:10 AM
Oasis Report Please - 2004 F-350 PSD 06jimmy Ford Oasis requests 1 12-01-2007 02:22 AM
Oasis Report for 2004 F350 AZAuto Ford Oasis requests 1 07-28-2007 03:12 AM
Oasis Report Please ajeight Ford Oasis requests 2 05-29-2007 11:09 PM
