Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Thnkfst, this thread has received 2 replies and been viewed 596 times.
post #1 of 3 (permalink) Old 03-19-2009, 04:28 PM Thread Starter
Thnkfst's Avatar
Images: 4
Oasis Please
Please run an Oasis report 1FTSW21P55EB18781
SOLD-2005 F250 Elite and Spartan tunes, EGR block, ARP studs, 4" Magnaflow no Cat
2008 F250 DPF delete and Spartan
Thnkfst is offline
post #2 of 3 (permalink) Old 03-19-2009, 04:34 PM
AmarilloSD's Avatar
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 18 5Y04 060402 * 2N712 * H04 42 30326
AWS Claim Key: 5597731 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2006 Doc #:09565005
Cust Comments: CHECK EBRAKE OPERATION. CUSTOMER STATES THAT GOES TO FLOOR ON OCCASION
Tech Comments: PERF DIAG HOIST END CK REAR BRAKES AND PARKING BRAKE.LUBED PARKNG BRAKE ASSEM.ROAD TSTED OK NOW.
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 18 * * * * * * * 30326
AWS Claim Key: 5597733 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2006 Doc #:09565003
Cust Comments: RECALL 59B01 FOR ONE TIME ASSURANCE TEST DRIVE
Tech Comments: PERFORMED RECALL PER RECALL INSTRUCTIONS
AWS Claim Key: 5597734 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2006 Doc #:09565002
Cust Comments: RECALL 05E15 FOR EBP SENSOR REPLACEMENT
AWS Claim Key: 5597732 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2006 Doc #:09565004
Cust Comments: RECALL 05B32 FOR DEGAS BOTTLE LABEL
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 22 2G04 000615 * NPF * P59 82 35824
AWS Claim Key: 6652099 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2006 Doc #:09759603
Cust Comments: TRANSMISSION SLIPS AT 1 2 SHIFT.CHECK AND ADVISE
Tech Comments: PERF ELECT TRANS DIAG.NO CODES.PERF ELECT BUZZ TST.NO CODES WIRING OK.TST DROVE WITH NO PROBLEM FOUND.TSTED ON SEVERAL DIFFERENT RAOD CONDITIONS.NO PROBLEM FOUND
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 22 6D01 011001 5C3Z 2562901 HAA S52 D4 35824
AWS Claim Key: 6652098 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2006 Doc #:09759604
Cust Comments: DRIVERS SIDE SEAT COVER WORN. CHECK AND ADVISE
Tech Comments: PERF DIAG SUBLET AND REPLACE DRIVERS BOTTOM SEAT CVR.OK NOW.
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 22 1D05 03XXXX 5C4Z 9448 A E42 D8 35824
AWS Claim Key: 6652101 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2006 Doc #:09759601
Cust Comments: EXHAUST LEAK CHECK AND ADVISE
Tech Comments: PERF DIAG FND BOTH EXH MANIFOLD GASKETS BAD.R,R BOTH EXH MAN GSKTS OK NOW
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 22 5U88 000615 * NPF * N25 82 35824
AWS Claim Key: 6652100 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2006 Doc #:09759602
Cust Comments: VIBRATION FELT AT 60 PLUS MILES PER HOUR CUSTOMER STATES FEELS LIKE DRIVELINE
Tech Comments: PERF DIAG CK TIRE RUN OUT AND WEAR PATTERN OK.TST DROVE WITH NO VIBRATION.HOIST AND INSPECT DRIVESHAFT.ALL OK NO PROBLEM FOUND.
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 26 2E03 030008 * 9E527 * D11 42 42176
AWS Claim Key: 7576484 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2007 Doc #:09974902
Cust Comments: DRIVEABILITY CONCERN PERFORM COMPREHENSIVE TEST FOR IDLE ROLLS AFTER ENGINE WARM TACH JUMPS
Tech Comments: PERFORM DIAG AND REFER TO TSB 7 5 04 REPROGRAM PCM PER TSB 1
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 27 1A02 030102 * 6051 * L87 42 43252
AWS Claim Key: 7741842 Trx Code: E72 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2007 Doc #:20161901
Cust Comments: CHECK AND REPORT LOSS OF COOLANT UNDER LOAD
Tech Comments: PERFORMED DIAG,PERFORMED T.S.B.06 21 02 REPLACED EGR COOLER AND EGR VALVE,REPLACED DIPSTICK AND RETEST PASS
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 28 1A02 030102 * 6051 * L87 42 44732
AWS Claim Key: 8120604 Trx Code: E72 Labor Hrs: 16.4
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2007 Doc #:20301501
Cust Comments: CHECK AND REPORT COOLANT LEAKS OUT OF OVERFLOW
Tech Comments: TSB 06 21 02 PERFORMED DIAG MGP AT 26.3 PSI ON ACELL UP GRADE.AS PER HOT LINE,REMOVE AND REPLACED HEADGASKETS AND RETEST HEADGASKETS WERE NOT REPLACED OR NEEDED ON PREVIOUS REPAIR
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 29 2A01 031202 6C3Z 6C646 BA D50 42 45156
AWS Claim Key: 8147653 Trx Code: E72 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:02-JUL-2007 Doc #:20375801
Cust Comments: CHECK FOR TURBO TUBE POPPED OFF AND DENTED HOOD
Tech Comments: PERFORMED DIAG CODE PO401.REPLACED COLD SIDE DUCT AND MAP SENSOR RETEST PASS,SENT TO BODYSHOP FOR HOOD REPAIR
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 29 2A01 031202 * 6C646 * B01 01 45156
AWS Claim Key: 8281190 Trx Code: E72 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2007 Doc #:20385201
Cust Comments: TURBO HOSE BLEW OFF DENTING HOOD REFER TO RO 203758, HOSE WAS REPLACED ON THAT RO
Tech Comments: INSIDE OUT DENT R&I HOOD,REPAIR DENT AND REFINISH. THIS CLAIM IS FOR PAINT REPAIR
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 32 1A02 030102 * 6051 * L87 42 48168
AWS Claim Key: 8770292 Trx Code: E88 Labor Hrs: 16.8
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-SEP-2007 Doc #:20644701
Cust Comments: CHECK FOR COOLANT LEAKS WHEN PULLING TRAILER UPHILL
Tech Comments: PERFORMED DIAG CODE PO401.FOLLOW TSB 07 14 5.RETEST WITH TRAILER UP GRADE UNDERLOAD FAILED TEST,AS PER HOTLINE RECOMMEND REPLACING HEADGASKET,OIL COOLER AND EGR COOLER. TEARDOWN CYL HEAD CHECK FOR WARPAGE NONE FOUND REASSEMBLE REPLACED OIL COOLER AND EGR COOLER ALSO REPLACED TURBO DUE TO STICKING VANES
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 32 2H01 030407 4C3Z 6K682 CBRM D42 42 48168
AWS Claim Key: 8770293 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-SEP-2007 Doc #:20644703
Cust Comments: CHECK FOR LOSS OF POWER WHEN GOING UP HILLS OR GRADES. D42
Tech Comments: PERFORMED TSB 07 16 01
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 36 6Y20 000000 * TAP1 * A99 82 54820
AWS Claim Key: 9507548 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2008 Doc #:21065102
Tech Comments: 1 25 TAP DAYS WARRANTY REPAIR
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 36 1A02 030102 * 6051 * L87 42 54820
AWS Claim Key: 9501344 Trx Code: E72 Labor Hrs: 21.4
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2008 Doc #:21065101
Cust Comments: CHECK FOR COOLANT LEAKS WHEN TOWING L66
Tech Comments: VERIFY CONCERN TEST DRIVE WITH CUSTOMER TOWING.REPLACED DEGA S BOTTLE AND CAP.TEST EGR COOLER PASS.REPLACED FAN CLUTCH.RE MOVE CYL HEADS FOR INSPECTION WARPED,REPLACED BOTH CYL HEADS ROAD TEST PASS
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 36 2H01 030407 4C3Z 6K682 CBRM D50 42 54820
AWS Claim Key: 9501345 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2008 Doc #:21065103
Cust Comments: CHECK FOR FLUTTER NOISE D50
Tech Comments: PERFORMED DIAG AND REPLACED TURBO
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 44 2G01 03XXXX 4C3Z 12B599 AARM D42 42 69397
AWS Claim Key: 10414237 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2008 Doc #:21838301
Cust Comments: CHECK FOR ENGINE RUNS ROUGH IN AM HARD TO START D42
Tech Comments: PERFROMED DIAG INJECTOR CODES PRESENT.REPLACED FICM MODULE AND PROGRAM.RETEST PASS
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 48 2H01 031202 6C3Z 6C640 A L65 42 78644
AWS Claim Key: 10716215 Trx Code: E72 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2009 Doc #:22169702
Cust Comments: CHECK FOR OIL LEAKS L65
Tech Comments: REPLACED CAC BOOT AS PER TSB 7 5 15
1FTSW21P55EB18781 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-OCT-2004 26-FEB-2005 172433 USA 48 1A02 030102 * 6051 * L87 42 78644
AWS Claim Key: 10716214 Trx Code: E72 Labor Hrs: 9.1
Dlr Cd-Sub Cd: 07889 - * Name: PERRY FORD LINCOLN MERCURY OF SAN LUIS OBISPO Ph: 805-5445200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2009 Doc #:22169701
Cust Comments: CHECK FOR COOLANT LEAKS L66
Tech Comments: VERIFY CONCERN PERFORMED TSB 8 11 3.PRESSURE TEST CAP FAILED REPLACED CAP.VAC TEST COOLING SYSTEM AND DROPPED 5%.REMOVE INTAKE,TURBO,EGR COOLER,PRESSURE EGR COOLER PASS,TEST OIL COOLER FAILED REPLACED OIL COOLER AND FLUSH COOLANT RETEST
2006 f350 C.C.SB Amarillo Edition- Afe Stage 2 intake, SCT, mbrp 5" turbo back with 6" tip, 7" icon lift,325/50/22 dynapro atms on 22x11 black XD diesels, keystone heat extractor hood, 4.30 gears, 03 turbo DR/icon traction bars, Hd Heads, Painted front and rear bumpers, arp head studs, Welded EGR
wish list/coming soon-banks ic, regulated return fuel system, Tuned FICM, but not if i do a CR cummins first!
AmarilloSD is offline
post #3 of 3 (permalink) Old 03-19-2009, 06:39 PM
4play's Avatar
OASIS RESULT:
1FTSW21P55EB18781
03/19/2009
14:38:19
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710N0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS AN OPEN CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/26/2005 BUILD DATE
10/28/2004 SALE MILEAGE
00050
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/13/2009
DEALER: Perry Ford Lincoln Mercury of
WARRANTY CLAIM NUMBER: 221697 ODOMETER: 078644M
LABOR OP
CONDITION CODE
CONDITION DESC
6051 GASKET CYL HEAD 000 081103A 42 DOES NOT OPERATE PROPERLY
3C3Z 6A642AA COOLER CRANKCASE OI 001 081103B
3C3Z 6C683AA FLTER-ENG OIL 001 6005PA
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
VC 7B 003
VC 9 002
W302725 001
W705589S 004
3C3Z 9433BE GASKET SET-MANIFOLD 001
8C3Z 8101A CAP ASY - PRESSURE R 001
3C3Z 8260AG HOSE RADIATOR-UPPER 001
VERIFY CONCERN PERFORMED TSB 8-11-3.PRESSURE TEST CAP FAILED REPLACED CAP.VA C TEST COOLING SYSTEM AND DROPPED 5%.REMOVE INTAKE,TURBO,EGR COOLER,PRESSU RE EGR COOLER PASS,TEST OIL COOLER FAILED REPLACED OIL COOLER AND FLUSH COOL ANT RETEST
01/13/2009
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640A CONNECTION A/C DUCT 001 6646AH 42 DOES NOT OPERATE PROPERLY
6C2Z 6K786AA CLAMP AIR COOLING 002
REPLACED CAC BOOT AS PER TSB 7-5-15
09/22/2008
WARRANTY CLAIM NUMBER: 218383 ODOMETER: 069397M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12B599AARM IDM MOD ASY-FUELINJ 001 6005E2 42 DOES NOT OPERATE PROPERLY
000 6005E7A
000 6005E3
000 6005E4
000 6005E5
000 12650D67
PERFROMED DIAG-INJECTOR CODES PRESENT.REPLACED FICM MODULE AND PROGRAM.RETES T PASS
02/04/2008
WARRANTY CLAIM NUMBER: 210651 ODOMETER: 054820M
LABOR OP
CONDITION CODE
CONDITION DESC
6051 GASKET CYL HEAD 000 080307A 42 DOES NOT OPERATE PROPERLY
F6DZ 8100A CAP ASY RADIATOR 001 080307D
VC 7B 003 080307E
3C3Z 6731AA ELEMENT ASY OIL FILT 001 MT6049
XO 15W40QSD 015 OSL
VC 8 MOTORCRAFT BATTERY 001
4C3Z 8A616SA CLUTCH ASY-FAN A/C 001
W300020 001
3C3Z 6049CARM CYLINDER HEAD 002
3C3Z 8287AA CLAMP ASY-RAD HOSE 001
W300051 006
W302352 004
W300006 002
6C2Z 6K786AA CLAMP AIR COOLING 001
02/04/2008
LABOR OP
CONDITION CODE
CONDITION DESC
TAP1 MISC 000 82 FREIGHT/POSTAGE/MAINTENANCE
02/04/2008
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 080407D 42 DOES NOT OPERATE PROPERLY
3C3Z 6N640AA GASKET TURBO TO MANI 001
4play is offline
