Oasis Please - Thanks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlueCake, this thread has received 3 replies and been viewed 452 times.
post #1 of 4 (permalink) Old 03-19-2009, 06:22 PM Thread Starter
Thanks in advance, I'm looking into buying an 06/07.
1FTSW20P06EC07094
BlueCake is offline
post #2 of 4 (permalink) Old 03-19-2009, 06:37 PM
4play's Avatar
OASIS RESULT:
1FTSW20P06EC07094
03/19/2009
14:36:26
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/23/2005 BUILD DATE
11/21/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
10/02/2008
DEALER: Rivertown Ford, Inc.
WARRANTY CLAIM NUMBER: 090097 ODOMETER: 013291M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 7C155A GSKT CONTROL VALVE 001 7000F 42 DOES NOT OPERATE PROPERLY
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7000F45
4C3Z 7G383AA EPC SOLENOID 001 7000A
3C3Z 7J136BA SOL ASY-TRANS DIR EL 001 7000AXQ
4C3Z 7G276AA BULKHEAD ASSY (WIRIN 001 7000A2
XT 6QSP 010 7000AZJ
3C3Z 7153AD GASKET TRANSMISSION 001 7000A4
000 7000A11
000 7000A13
DELAYED AUTOMATIC TRANSMISSION ELECTRONIC DIAGNOSIS - DIAGNOSIS
09/16/2008
WARRANTY CLAIM NUMBER: 089467 ODOMETER: 013256M
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 002 10654CA 42 DOES NOT OPERATE PROPERLY
000 10654C1T
BATTERIES FAILED TEST REPLACED BATTERIES
1FTSW20P06EC07094 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 21-NOV-2005 23-DEC-2005 121024 USA 34 7A01 140101 BXT 65 750 D50 42 13256
AWS Claim Key: 7134711 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04110 - * Name: RIVERTOWN FORD, INC. Ph: 706-6537420 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2008 Doc #:08946750
Cust Comments: CUSTOMER STATES VEHICLE WILL NOT START
Tech Comments: BATTERIES FAILED TEST REPLACED BATTERIES
1FTSW20P06EC07094 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 21-NOV-2005 23-DEC-2005 121024 USA 34 3A11 070101 3C3Z 7153 AD P67 42 13291
AWS Claim Key: 7256050 Trx Code: E84 Labor Hrs: 12.3
Dlr Cd-Sub Cd: 04110 - * Name: RIVERTOWN FORD, INC. Ph: 706-6537420 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2008 Doc #:09009751
Cust Comments: CK TRANS HESITATES BEFORE ENGAGES,JERKS INTO GEAR
Tech Comments: DELAYED AUTOMATIC TRANSMISSION ELECTRONIC DIAGNOSIS DIAGNOSIS
4play is offline
BlueCake (03-19-2009)
post #3 of 4 (permalink) Old 03-19-2009, 07:37 PM Thread Starter
Thanks again,
Any major concerns here with the tranny as it will be used for towing?
They have an 07 here too, Can you run this one as well- Sorry for being such a pain.
1FTSW20P97EB09876
BlueCake is offline
post #4 of 4 (permalink) Old 03-19-2009, 10:45 PM
4play's Avatar
no major issues with the trans, keep them cool, add bigger cooler if you tow heavy. change fluid and filters regularly. here is the next oasis.
OASIS RESULT:
1FTSW20P97EB09876
03/19/2009
18:44:03
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2007 F-SERIES BODY STYLE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
6F710H0A
ARN MESSAGES
WARRANTY START DATE
11/08/2006 BUILD DATE
09/29/2006 SALE MILEAGE
EXTENDED COVERAGES
02/11/2009
WARRANTY CLAIM NUMBER: 095289 ODOMETER: 015840M
LABOR OP
CONDITION CODE
CONDITION DESC
000 10654C1T
NO START BATTERY - TEST, CHARGE, AND RE-TEST
12/17/2008
WARRANTY CLAIM NUMBER: 093037 ODOMETER: 015799M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 3A674BRM PUMP ASY P/STRG 001 3504A9P 42 DOES NOT OPERATE PROPERLY
5C3Z 3A717CA TUBE-CONTROL VALVE 001 3674A5P
XT 5QM 001
POWER STEERING REPLACED P-S PRESSURE LINE
12/02/2008
WARRANTY CLAIM NUMBER: 092343 ODOMETER: 015795M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001 081806H 42 DOES NOT OPERATE PROPERLY
000 081806C
000 081806B
000 081806G
SKIP TEST SYSTEM PER TSB 081806
08/12/2008
WARRANTY CLAIM NUMBER: 088036 ODOMETER: 015794M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7153AD GASKET TRANSMISSION 001 7000F 42 DOES NOT OPERATE PROPERLY
3C3Z 7B164AA PLT ASY-CLTCH IN SPL 003 7000A
3C3Z 7B164BA PLT ASY-CLTCH IN SPL 001 7000AXQ
XT 5QM 015 7000AZJ
000 7000A2
000 7000A11
A AUTOMATIC TRANSMISSION ELECTRONIC DIAGNOSIS - DIAGNOSIS
1FTSW20P97EB09876 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 29-SEP-2006 08-NOV-2006 121205 USA 22 3A02 0701XX 3C3Z 7B164 BA P59 42 15794
AWS Claim Key: 3149667 Trx Code: E84 Labor Hrs: 11.2
Dlr Cd-Sub Cd: 04110 - * Name: RIVERTOWN FORD, INC. Ph: 706-6537420 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2008 Doc #:08803651
Cust Comments: AUTO TRANS JUMPS IN AND OUT OF GEAR WHLILE DRIVING
Tech Comments: A AUTOMATIC TRANSMISSION ELECTRONIC DIAGNOSIS DIAGNOSIS
1FTSW20P97EB09876 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 29-SEP-2006 08-NOV-2006 121205 USA 26 2E03 030402 4C3Z 9E527 BRM D50 42 15795
AWS Claim Key: 3762585 Trx Code: S07 Labor Hrs: 7.7
Dlr Cd-Sub Cd: 04110 - * Name: RIVERTOWN FORD, INC. Ph: 706-6537420 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2008 Doc #:09234351
Cust Comments: ENG SKIPPING HARD TO START
Tech Comments: SKIP TEST SYSTEM PER TSB 081806
1FTSW20P97EB09876 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 29-SEP-2006 08-NOV-2006 121205 USA 26 6Y06 110204 5C3Z 3A674 BRM F99 42 15799
AWS Claim Key: 3869081 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 04110 - * Name: RIVERTOWN FORD, INC. Ph: 706-6537420 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:17-DEC-2008 Doc #:09303751
Cust Comments: CK P S FLUID LEAKING
Tech Comments: POWER STEERING REPLACED P S PRESSURE LINE
1FTSW20P97EB09876 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 29-SEP-2006 08-NOV-2006 121205 USA 28 7A01 140101 BXT 65 750 C25 42 15840
AWS Claim Key: 4136898 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04110 - * Name: RIVERTOWN FORD, INC. Ph: 706-6537420 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:11-FEB-2009 Doc #:09528951
Cust Comments: CK WILL NOT STAY RUNNING WHEN JUMP STARTS
Tech Comments: NO START BATTERY TEST, CHARGE, AND RE TEST
4play is offline
