OASIS Please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ofc. Garcia, this thread has received 1 replies and been viewed 384 times.
post #1 of 2 (permalink) Old 03-20-2009, 07:57 PM Thread Starter
OASIS Please!
1FTSW21PX6EA63083
Appreciate it guys! Thanks in advance!
Tom
Ofc. Garcia is offline
post #2 of 2 (permalink) Old 03-20-2009, 10:19 PM
4play's Avatar
OASIS RESULT:
1FTSW21PX6EA63083
03/20/2009
18:18:50
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/06/2005 BUILD DATE
07/20/2005 SALE MILEAGE
00010
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/31/2008
DEALER: Bo Lovein Ford Mercury
WARRANTY CLAIM NUMBER: 029648 ODOMETER: 056691M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 081103A 42 DOES NOT OPERATE PROPERLY
3C3Z 6A642AA COOLER CRANKCASE OI 001 081103B
3C3Z 6C683AA FLTER-ENG OIL 001 081103G
VC 1 BATTERY ASY 002
3C3Z 6731AA ELEMENT ASY OIL FILT 001
VC 4B BATTERY ASY 002
XO 15W40QSD 015
3C3Z 8287CB CLAMP ASY-RAD HOSE 001
CK VEHICLE FOR LOSS OF COOLANT & WHITE EXHAUST SMOKE PERFORMED TSB 08-11-03 FOUND NECESSARY TO REPLACE EGR COOLER & OIL COOLER REPLACED OIL COOLER DUE T O A TEMPERATURE DIFFERENCE OF 39 BETWEEN EOT & ECT HOTLINE INDICATED THAT TH E OIL COOLER COULD HAVE BEEN THE CAUSE OF THE 1ST EGR COOLER FAILURE CHANGED OIL FLUSHED RADIATOR & FILLED WITH NEW COOLANT REMOVED GLOW PLUGS & ATTEMPT
10/27/2008
WARRANTY CLAIM NUMBER: 029010 ODOMETER: 051253M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 5A231AA CLAMP-MUFFLER 001 081103B
3C3Z 9J469AA SEAL EGR TUBE 001
4C3Z 9601AA ELEMENT ASY-AIR CLEA 001
3C3Z 9N693KA RING-SEALING 001
VC 7B 002
6051 GASKET CYL HEAD 000
PERFORMED KOEO SELF TEST NO DTC'S PRESSURE TE STEDDEGAS BOTTLE CHECKED OK TE STED EGR COOLE R ON VEH ICLE TWICE COOLANT LEAKED OUT OF EXHA UST FOUND NECE SSARY TO REPLACE EGR COOLER REP LACED AIR FILTERDUE TO COOLANT CONTAMINATION ALSO REPROGRAMMED PC M AND PERFORMED TURBO BOO ST TEST PASSED TEST TESTED O LD EGR COOLER TWI CE WHEN REMOVED FROM VEHICLEFOUND LEAK ROAD TESTED & RECHE
10/27/2008
LABOR OP
CONDITION CODE
CONDITION DESC
000 05E16B
1FTSW21PX6EA63083 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-JUL-2005 06-AUG-2005 124461 USA 28 7A01 140101 BXT 65 750 D02 42 31495
AWS Claim Key: 5051133 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04878 - * Name: BO LOVEIN FORD MERCURY Ph: 229-6862058 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2007 Doc #:02563801
Cust Comments: VEHICLE WILL NOT CRANK
Tech Comments: TEST CHARGE AND RETEST BOTH BATTERIES AND FOU ND NECESSARY TO REPLACE BOTH BATTERIES AND RE CHECKED OK DTC 180JSQKKSO986 17WJSQKKSO989
1FTSW21PX6EA63083 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-JUL-2005 06-AUG-2005 124461 USA 28 2E04 03XXXX 4C3Z 9B246 A D03 42 31495
AWS Claim Key: 5051135 Trx Code: E84 Labor Hrs: 8
Dlr Cd-Sub Cd: 04878 - * Name: BO LOVEIN FORD MERCURY Ph: 229-6862058 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2007 Doc #:02563803
Cust Comments: CHECK VEHICLE HARD TO START
Tech Comments: CK FOR CODES CK HIGH PRESSURE OIL SYSTEM FOUN D NECESSARY TO REPLACE STC BRACKET KIT AND IP R VALVE PER TSB 06 17 06 AND RECHECKED OK
1FTSW21PX6EA63083 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-JUL-2005 06-AUG-2005 124461 USA 28 5A02 050201 2C3Z 1177 AB L88 42 31495
AWS Claim Key: 5051134 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 04878 - * Name: BO LOVEIN FORD MERCURY Ph: 229-6862058 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2007 Doc #:02563802
Cust Comments: CHECK REAR END FOR LEAK
Tech Comments: CHECKED REAR END FOR LEAK AND FOUND NECESSARY TO REPLACE 2 HUB SEALS AND GASKETS AND REFILL ED WITH FLUID AND RECHECKED OK
1FTSW21PX6EA63083 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-JUL-2005 06-AUG-2005 124461 USA 40 1A02 030102 * 6051 * E23 42 51253
AWS Claim Key: 7402603 Trx Code: E72 Labor Hrs: 8.8
Dlr Cd-Sub Cd: 04878 - * Name: BO LOVEIN FORD MERCURY Ph: 229-6862058 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2008 Doc #:02901001
Cust Comments: CK FOR RUNNING HOT AND COOLANT LEAK
Tech Comments: PERFORMED KOEO SELF TEST NO DTC'S PRESSURE TE STEDDEGAS BOTTLE CHECKED OK TESTED EGR COOLE R ON VEH ICLE TWICE COOLANT LEAKED OUT OF EXHA UST FOUND NECESSARY TO REPLACE EGR COOLER REP LACED AIR FILTERDUE TO COOLANT CONTAMINATION ALSO REPROGRAMMED PC M AND PERFORMED TURBO BOO ST TEST PASSED TEST TESTED OLD EGR COOLER TWI CE WHEN REMOVED FROM VEHICLEFOUND LEAK ROAD TESTED & RECHECKED OK APPROVAL CO
1FTSW21PX6EA63083 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-JUL-2005 06-AUG-2005 124461 USA 40 * * * * * * * 51253
AWS Claim Key: 7409709 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04878 - * Name: BO LOVEIN FORD MERCURY Ph: 229-6862058 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2008 Doc #:02901004
Cust Comments: RECALL 05E16 ENGINE CONTROL MODULE RECALIBRAT
1FTSW21PX6EA63083 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 20-JUL-2005 06-AUG-2005 124461 USA 42 1H03 030804 4C3Z 9P456 AF E23 42 56691
AWS Claim Key: 7690478 Trx Code: E88 Labor Hrs: 10.2
Dlr Cd-Sub Cd: 04878 - * Name: BO LOVEIN FORD MERCURY Ph: 229-6862058 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:31-DEC-2008 Doc #:02964801
Cust Comments: CHECK FOR LOSING WATER
Tech Comments: CK VEHICLE FOR LOSS OF COOLANT & WHITE EXHAUST SMOKE PERFORMED TSB 08 11 03 FOUND NECESSARY TO REPLACE EGR COOLER & OIL COOLER REPLACED OIL COOLER DUE TO A TEMPERATURE DIFFERENCE OF 39 BETWEEN EOT & ECT HOTLINE INDICATED THAT THE OIL COOLER COULD HAVE BEEN THE CAUSE OF THE 1ST EGR COOLER FAILURE CHANGED OIL FLUSHED RADIATOR & FILLED WITH NEW COOLANT REMOVED GLOW PLUGS & ATTEMPTED TO CRANK ENGINE T
4play is offline
Ofc. Garcia (03-20-2009)
