need oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlueCake, this thread has received 1 replies and been viewed 439 times.
post #1 of 2 (permalink) Old 03-20-2009, 09:35 PM Thread Starter
need oasis please
1ftsw20p86ed05435
BlueCake is offline
post #2 of 2 (permalink) Old 03-20-2009, 10:21 PM
4play's Avatar
OASIS RESULT:
1FTSW20P86ED05435
03/20/2009
18:20:17
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/07/2006 BUILD DATE
02/25/2006 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTSW20P86ED05435 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 25-FEB-2006 07-APR-2006 124007 USA 16 7A01 140101 BXT 65 750 D02 42 27935
AWS Claim Key: 4196623 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2007 Doc #:408098A
Cust Comments: CHECK NO CRANK
Tech Comments: 27935 CHARGE AND TEST DUAL BATTERIES TESTER READS BAD BATTERY LH SIDE 12.37 VOLTS 3 CCA (XE00L) (100JSXJBW5Q02) RH SIDE (XE00L) (100JS7BTS300) REPLCE DUAL BATTERIES CHECK CHARGING SYSTEM 13.4 VOLTS...409
1FTSW20P86ED05435 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 25-FEB-2006 07-APR-2006 124007 USA 18 1H03 030008 * 9F452 * D50 55 31520
AWS Claim Key: 4698358 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-SEP-2007 Doc #:411750A
Cust Comments: CHECK FOR WHITE SMOKE FROM TAIL PIPE
Tech Comments: 31535 TSB PERFORM DIESEL ENGINE PERFORMANCE DIAGNOSTICS IDS HOOK UP EEC TEST P0404 R AND R EGR VALVCE TO PERFORM EGR VALVE CLEANING PROCEDURE TO ELIMINATE P0404 PER TSB 06 19 06 REPROGRAM PCM FICM AND TCM TO LATEST CALIBRATION PER TSB 07 05 04 ROAD TEST RETEST P1000...409
1FTSW20P86ED05435 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 25-FEB-2006 07-APR-2006 124007 USA 19 2G05 031405 * RECAL * P66 04 32214
AWS Claim Key: 4824504 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-OCT-2007 Doc #:413206D
Cust Comments: CHECK DELAYS IN SHIFTING
Tech Comments: 32221 IDS HOOK UP EEC TEST PASS ROAD TEST TO CHECK TRANS OPERATION PERFORM TSB 07 14 08 ROAD TEST RETEST PASS...409
1FTSW20P86ED05435 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 25-FEB-2006 07-APR-2006 124007 USA 22 1H03 030008 5C3Z 9F452 AA D42 55 32233
AWS Claim Key: 5300745 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-2007 Doc #:416398A
Cust Comments: CUST STATES LACK OF POWER
Tech Comments: 32239 PERFORM DIESEL ENGINE PERFORMANCDE DIAGNOSITCSD IDS HOOK UP EEC TEST P0404 P0299 PO2263 PERFORM EGR TEST FAIL REPLACE EGR VALVE PER TSB 07 21 09 TO ELIMINATE P0404 PERFORM TURBO CLEANING PROCEDURE AS OUTLINED IN TSB 07 16 01 TO ELIMINATE P0299 P2263 REPROGRAM PCM TCM AND FICM TO LATEST CALIBRATION PER TSB 07 05 04 ROAD TEST RETEST P1000...409
4play is offline
BlueCake (03-22-2009)
