Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mr_kebo, this thread has received 1 replies and been viewed 665 times.
post #1 of 2 (permalink) Old 03-22-2009, 05:43 AM Thread Starter
Oasis Report Please
2003 Ford F350
mr_kebo AT hotmail.com
Vin# 1FTSX31P33EB38446
Thanks
mr_kebo is offline
post #2 of 2 (permalink) Old 03-23-2009, 05:08 AM
4play's Avatar
OASIS RESULT:
1FTSX31P33EB38446
03/23/2009
01:07:40
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/11/2002 BUILD DATE
12/05/2002 SALE MILEAGE
00011
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
| On-line 1878
END OF OASIS REPORT FOR 1FTSX31P33EB38446
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 12 2G05 * * * * * * 14078
AWS Claim Key: 3543485 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02205 - * Name: ARTINO FORD Ph: 419-4334404 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2003 Doc #:0095782
Cust Comments: 03B06 RECALL
Tech Comments: 03B06 RECALL
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 12 * * * * * * * 14078
AWS Claim Key: 3543486 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02205 - * Name: ARTINO FORD Ph: 419-4334404 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2003 Doc #:0095783
Cust Comments: 57B98 RECALL
Tech Comments: 57B98 RECALL
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 12 2E01 * * * * * * 14078
AWS Claim Key: 3543484 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02205 - * Name: ARTINO FORD Ph: 419-4334404 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2003 Doc #:0095781
Cust Comments: 03B05 RECALL
Tech Comments: 03B05 RECALL
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 18 2G05 031405 * RECAL * D36 42 19030
AWS Claim Key: 6638418 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02205 - * Name: ARTINO FORD Ph: 419-4334404 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2004 Doc #:00203901
Cust Comments: RUNS BAD NO POWER SES LAMP ON
Tech Comments: REPROGRAMMED PCM RUNS BAD SHIFTS ERRATIC
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 32 2H02 030008 5C3Z 6F089 A D13 42 32722
AWS Claim Key: 11394108 Trx Code: S07 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:01973852
Cust Comments: CUST STATES RUNS ROUGH COLD
Tech Comments: 3U7A 12A650 FTF
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 32 * * * * * * * 32722
AWS Claim Key: 11394109 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:01973853
Cust Comments: PERFROM RECALL 04S15 NEG BATTERY TERMINAL
Tech Comments: PERFORMED RECALL 04S15, CLEANED NEGATIVE CABLE AND REPLACED GROUND BOLT.
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 38 2E06 030008 3C3Z 9E527 AE D50 42 51274
AWS Claim Key: 12967122 Trx Code: E72 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2006 Doc #:04371051
Cust Comments: CUST STATES HARD TO START COLD , BLOWS WHITE SMOKE, WATER IN FUEL LIGHT COMES ON,RUNS ROUGH COLD START , OK WARM
Tech Comments: COLD STARTED VEHICLE AND VERIFIED THE CONCERN, INSPECTED FUEL, AIR, AND OIL SYSTEMS OK. RUN KOEO AND KOER FOUND CODE P2269, RUN INJECTOR ELECTRICAL TEST OK, TESTED EGR SYSTEM, EXHAUST RESTRICTION, FUEL PRESSURE, FUEL AERATION, ICP ADN IPR TESTS AND BOOST, RUN POWER BALANCE AND REPALCED THE #4 INJECTOR(LH SIDE) ALSO REPLACED THE HFCM MANIFOLD AND UP DATED HARNESS. REASSEMBLED AND RETESTED OK.
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 45 5C02 050101 3C3Z 4R602 CU N25 42 64765
AWS Claim Key: 14218657 Trx Code: 0701D Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-JUL-2006 Doc #:06972752
Cust Comments: CUST STATES BAD VIB 55 60 MPH WHOLE TRUCK
Tech Comments: VERIFLY TRUCK VIBRATES DIRVING, REPLACE DRIVESHAFT ASSEMBLY. ROAD TESTTECH.136. CC42. M O 64768.
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 45 2E06 030008 3C3Z 9E527 AE D03 42 64765
AWS Claim Key: 14255728 Trx Code: E72 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-JUL-2006 Doc #:06972755
Cust Comments: CUST STATES NO POWER COLD START UP BLOWS WHITE SMOKE
Tech Comments: ROAD TESTED AND VERIFIED THE CONCERN RUN KOEO AND KOER FOUND CODES P2263. RUN DIESEL DIAG SHEET AND FOUND LOW BOOST, RUN POWER BALANCE TEST AND PINPOINT TEST. REPLACED INJECTORS #3 AND #6 REPLACED BOTH INJECTORS (#3RH SIDE #6LH SIDE) ALS0 REPLACED THE CAC TUBE ELBOW ON THE RH SIDE. ROAD TESTED AND RETESTED, REPRGROGRAMED THE PCM TCM AND FICM(3U7A 12A650 FTG)
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 45 2H01 030008 3C3Z 6K682 BARM D42 42 65237
AWS Claim Key: 14268184 Trx Code: E72 Labor Hrs: 7.8
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2006 Doc #:07119051
Cust Comments: CUST STATES ENGINE MISSING ,SPUTTERS DRIVING ,NO POWER DRIVING NO POWER ALSO RUNS ROUGH COLD START UP
Tech Comments: ROAD TESTED AND VERIFIED THE CONCERN FOUND THE TURBO FLUTERING AT CRUISE CAUSING A BUCK CONCERN. RUN KOEO AND KOER FOUND CODES P132B P0401 P2263. RUN DIESEL DIAG AND PINPOINT TESTS AND REPLACED THE STICKING EGRVALVE, THE OUT OF RANGE MAF SENSOR AND PERFORMED A TURBO VGT TEST. FOUND THE VANES STUCK IN THE TURBO, REMOVED AND REPALCED THE TURBO ASSEMBLY AND ROAD TESTED AND RETESTED OK..TECH 104 C.C.
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 55 2E06 030008 3C3Z 9F838 EA L65 42 86225
AWS Claim Key: 15307725 Trx Code: E72 Labor Hrs: 8.6
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2007 Doc #:00496751
Cust Comments: CUST STATES BAD OIL LEAK REAR OF ENGINE
Tech Comments: BOTH GLOW PLUG HARNESSES ARE LEAKING, COULD NOT REMOVE WITHOUT BREAKING THEM, REPLACED BOTH HARNESSES. CLEANED OFF ENGINE, ROADTEST AND RECHECKED, ENGINE STILL HAS OIL LEAK, ADDED DYE AND BLACK LIGHT TEST, LEAK COMING FROM REAR ENGINE COVER, TRANS NEEDS TO BE REMOVED, CUSTOMER NEEDS TRUCK AND WILL RETURN FOR REAR COVER GASKET AND REAR MAIN OIL SEAL.
1FTSX31P33EB38446 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 05-DEC-2002 11-DEC-2002 144601 USA 55 * * * * * * * 86225
AWS Claim Key: 15304116 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2007 Doc #:00496755
Cust Comments: CUST STS PERFORM 06E17 RECALL
Tech Comments: REPROGRAMED PCM TCM AND FICM PER RECALL TECH 002 SKILL 09
AWS Claim Key: 15304115 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04999 - * Name: ERNIE HAIRE FORD, INC. Ph: 813-9336571 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2007 Doc #:00496754
Cust Comments: CUST STS PERFORM 59B01 RECALL
Tech Comments: ROADTEST PER RECALL OK. TECH 002 SKILL 09
4play is offline
OASIS Report Please HP9K Ford Oasis requests 2 01-07-2008 11:26 AM
Oasis report mustang Ford Oasis requests 1 01-06-2008 12:40 AM
oasis report getusummm Ford Oasis requests 2 12-26-2007 08:13 AM
Oasis Report Please SmokingIDI_7.3L Ford Oasis requests 2 01-08-2007 11:00 PM
Oasis Report Please jamesb18cjdm Ford Oasis requests 1 12-19-2006 01:32 AM
