Oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlueCake, this thread has received 1 replies and been viewed 427 times.
post #1 of 2 (permalink) Old 03-23-2009, 10:56 PM Thread Starter
I'm sorry for being a PITA- I'm narrowing it down to a couple trucks in GA. I use the dealer when I can but this is a private seller. Thanks again.
1FTSW21P36EA87306
BlueCake is offline
post #2 of 2 (permalink) Old 03-24-2009, 07:07 AM
4play's Avatar
OASIS RESULT:
1FTSW21P36EA87306
03/24/2009
03:06:11
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/24/2005 BUILD DATE
08/12/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTSW21P36EA87306 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-AUG-2005 24-OCT-2005 121004 USA 2 2E06 030008 4C3Z 9E527 AA D50 42 5400
AWS Claim Key: 181996 Trx Code: S07 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 00478 - * Name: WADE FORD, INC. Ph: 770-4361200 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2005 Doc #:223460A
Cust Comments: VEH STARTED SHAKING WHILE DRIVING, RUNNING REAL ROUGH, NO POWER
Tech Comments: 5400 W VERIFY CONCERN. PERFORM 6.0L DIESEL DIAG STEPS 1 13. FOUND PO264. USE INJECTOR INTERRUPT AND VERIFY 60. REPLACED #2 INJECTOR AND RETEST. NO OTHER PROBLEMS DETECTED AT THIS TIME.
1FTSW21P36EA87306 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-AUG-2005 24-OCT-2005 121004 USA 10 5O01 110201 6C3Z 3504 A N58 D8 15147
AWS Claim Key: 1378588 Trx Code: E84 Labor Hrs: 5
Dlr Cd-Sub Cd: 00487 - * Name: JOHN BLEAKLEY FORD INC Ph: 770-9419000 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:25-JUL-2006 Doc #:03227351
Cust Comments: POWER STEERING LEAK APP NEEDS ASAP
Tech Comments: POWER STEERING LEAK INSTALLED LEAK DETECTOR REMOVED AIR CLEANER AIR CLEAR BOX BATTERY & BATTERY TRAY STEERING DRAG LINK STEERING STABLIZER & SWAY BAR TO REMOVE & REPLACE THE STEERING GEAR ASSY CLEAN AREA RECHECKED FOR LEAK LEAKING AT SECTOR SHAFT
1FTSW21P36EA87306 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-AUG-2005 24-OCT-2005 121004 USA 16 5O01 110200 * 3504 * C50 42 19979
AWS Claim Key: 2849587 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 00478 - * Name: WADE FORD, INC. Ph: 770-4361200 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2007 Doc #:246624A
Cust Comments: WHEN STEERING WHEEL TURNED NO MOVING FEEL CLICKING IN WHEEL
Tech Comments: 19979 W VERIFY CONCERN.FOUND STEERING LINKAGE WAS LOOSE . TIGHTEND UP ALL STEERING COMPONENTS AND RETES T. ALL OK AT THIS TIME.
4play is offline
oasis request tman945 Ford Oasis requests 1 01-06-2008 12:56 AM
Request For Oasis volwing Ford Oasis requests 1 01-05-2008 02:49 AM
Oasis request please jusmakinit Ford Oasis requests 0 12-19-2007 08:38 PM
OASIS request Expedish Ford Oasis requests 2 07-29-2007 01:51 AM
OASIS Request Please Diesel Dave 04 Ford Oasis requests 1 07-19-2007 03:01 AM
