Oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdeere5105, this thread has received 1 replies and been viewed 455 times.
post #1 of 2 (permalink) Old 03-24-2009, 02:21 AM Thread Starter
Oasis please
Here is the VIN. Father is looking at buying this truck.
1FTNX21P73EB78049
Thanks
Jason
1997 Crew Cab F250 4x4 5spd XLT PSD
Way too many miles on it!
230xxx and counting!
Starting over again since I sold the 6.0!
MBRP exhaust
Bully Dog Power Pup
S&B Intake
Dieselsite Coolant Filter
jdeere5105 is offline
post #2 of 2 (permalink) Old 03-24-2009, 07:13 AM
4play's Avatar
OASIS RESULT:
1FTNX21P73EB78049
03/24/2009
03:12:14
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/30/2003 BUILD DATE
12/17/2002 SALE MILEAGE
00411
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 2 2E01 * * * * * * 3062
AWS Claim Key: 1712512 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2003 Doc #:165043E
Cust Comments: 03B05 INJECTION CONTROL PRESSURE SENSOR
Tech Comments: 3062 RECALL PREFORMED INSTALLNEW ICP SENSOR
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 2 * * * * * * * 3062
AWS Claim Key: 1712511 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2003 Doc #:165043D
Cust Comments: REFER TO RECALL FOR OIL CHANGE
Tech Comments: 3062 PERFORM OIL CHANGE PER RECALL
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 2 2G05 * * * * * * 3062
AWS Claim Key: 1712513 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2003 Doc #:165043F
Cust Comments: 03B06 COLD OPERATION CALIBRATION RECALL
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 6 2E05 100106 3C3Z 9B249 AB G29 42 8933
AWS Claim Key: 3160141 Trx Code: 2 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2003 Doc #:169869D
Cust Comments: WATER IN FUEL LIGHT KEEPS COMING ON AFTER WATER DRAINED
Tech Comments: 8933 DIAG KOEO KOER FOUND WATER IN FUEL SENOR SHORTE REPLACE SENSOR AND RETEST VERIFY REPAIR
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 6 1D01 030008 3C3Z 6701 AA L65 D8 8933
AWS Claim Key: 3160140 Trx Code: 2 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2003 Doc #:169869A
Cust Comments: CUST STATES VEH LEAKING OIL LOOKS LIKE 6 DIFFERENT PLACES
Tech Comments: 8933 REOMVE TRANSMISSION , REMOVE FLEX PLATE FOR ACCESS TO REAR MAIN OIL SEAL. REPLACE FLEX PLATE, TRANS CHECK FOR LEAKS AT REAR MAIN OK ADD FOR SKID PLATE, 4X4. COND CODE D8 TECH 26 REPLACE REAR MAIN AND TECH 24 R&R TRANS
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 6 2G05 031405 * RECAL * D13 42 8933
AWS Claim Key: 3160142 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2003 Doc #:169869E
Cust Comments: CUST STATES 50% TIME VEH RUNS VERY ROUGH ON START UP SHAKES AND SPUTTERS TILL WARM
Tech Comments: 8933 REPROGRAM PCM FICM AND TCM
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 11 6J14 0114XX 3L3Z 25218A42 AA L15 42 15134
AWS Claim Key: 5418080 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2004 Doc #:175577B
Cust Comments: CUST STATES THE PASS SIDE DOOR LOCK MAKES A BUZZING SOUND
Tech Comments: 15134 DIAG FOUND LOK ACK FP 218A42 CC 42 NOT UNLOCKIN DOOR R&R PAS DOOR PANEL TRIM AND R&R LOCK ACK AND INSTALL NEW LOCK ACK. AND RETEST VERIFY REPAIR
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 11 2E05 100106 3C3Z 9B249 AB G29 42 15134
AWS Claim Key: 5418081 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2004 Doc #:175577D
Cust Comments: CUST STATES THE WATER IN THE FUEL LIGHT COMES ON
Tech Comments: 15134 DIAG FOUND CODE P2269 DRIAN WATER FROM FUEL AND RETEST AND LIGHT STILL ON REPLACE WATER IN FUEL MOD AND CLEAN AND RETEST VERIFY REPAIR
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 16 7P01 110501 * 13K359 * L30 B4 23075
AWS Claim Key: 7715199 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2004 Doc #:180879A
Cust Comments: C S BRAKE LIGHT S AND TURN SIGNALS ARE BOTH INOP, EVERY NOW AND THEN THE TURN SIGNALS WORK.
Tech Comments: 23075 TURN SIG AND BRAKE LIGHTS ARE INOP RAN NGS TEST CHECKED FUSES, OK RAN PIDS TEST ON MULTI SWITCH RAN PIDS TEST ON WIRRING REPAIRED PIN 16 LG 511 CONNECTOR C 202A RECHECK, OK CODE B4
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 16 * * * * * * * 23075
AWS Claim Key: 7715200 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2004 Doc #:180879B
Cust Comments: 04S15, NEG BOLT RECALL.
Tech Comments: 23075 PERFORMED RECALL 04S15C
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 17 2E05 100106 3C3Z 9B249 AB G29 42 23244
AWS Claim Key: 7815453 Trx Code: E84 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2004 Doc #:181076B
Cust Comments: C S WATER IN FUEL LIGHT HAS BEEN COMING ON.
Tech Comments: 23244 WATER IN FUEL MODUAL PERFORMED VISUAL INSPECTION FOUND WATER IN FUEL LIGHT TO BE ON TESTED FOR SUFFICIENT CLEAN FUEL FOUND GOOD FUEL CHECKED ENGINE OIL LEVEL IT WAS GOOD RAN KOEO TEST FOUND CODES P 1139 FOR WATER IN FUEL MODUAL AND ALSO FOUND P 2317 FOR CRANKSHAFT POSITION SENSOR CICUIT FAILURE REPLACED WATER IN FUEL MODUAL AND CRANKSHAFT PASITION SENSOR CLEARED
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 17 5S01 100106 3C3Z 9G270 BA E68 42 23244
AWS Claim Key: 7774867 Trx Code: S07 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2004 Doc #:181076A
Cust Comments: C S DIESEL FUEL IS LEAKING FROM UNDER DRIVERS SEAT AREA, WE REPLACED FUEL FILTER LAST WEEK, RAGS ARE STUCK UNDER TRUCK WHERE LEAK IS. TRUCK IS SLOW TO START AS IF FUEL PRESSURE IS BLEED
Tech Comments: 23244 CAP NOT SEALING VISUAL CHECK FOUND FUEL FILTER CAP TO BE LEAKING ON FRAME REPLACED CAP CLEANED TEST DROVE NO LEAKS PRESENT
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 42 * * * * * * * 78612
AWS Claim Key: 14600333 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01078 - * Name: BEN SATCHER MOTORS, INC. Ph: 803-3594114 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2006 Doc #:02847152
Cust Comments: RECALL #59B01
Tech Comments: 59B01 RECALL
AWS Claim Key: 14600334 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01078 - * Name: BEN SATCHER MOTORS, INC. Ph: 803-3594114 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2006 Doc #:02847153
Cust Comments: RECALL #06E17
Tech Comments: 06E17 RECALL
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 43 2B01 030707 3C3Z 12K073 AA L65 D1 78672
AWS Claim Key: 14676361 Trx Code: E72 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 01078 - * Name: BEN SATCHER MOTORS, INC. Ph: 803-3594114 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2006 Doc #:02923052
Cust Comments: CHECK FOR A OIL LEAK...ADVISE
Tech Comments: 12K073 ENGINE OIL LEAKS DIAGNOSIS
1FTNX21P73EB78049 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 17-DEC-2002 30-MAY-2003 121692 USA 50 2E06 030008 3C3Z 9F838 EA L65 42 96559
AWS Claim Key: 15346018 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01078 - * Name: BEN SATCHER MOTORS, INC. Ph: 803-3594114 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-2007 Doc #:03718751
Tech Comments: 9F838 SENSOR INJECTION CONTROL PRESSURE (ICP) REMOVE AND INSTA
4play is offline
