Oasis Report, Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by djbaines, this thread has received 1 replies and been viewed 628 times.
post #1 of 2 (permalink) Old 03-24-2009, 07:36 PM Thread Starter
VIN: 1FTNX21P43ED47623
Thanks!
Dan
djbaines is offline
post #2 of 2 (permalink) Old 03-24-2009, 07:44 PM
4play's Avatar
OASIS RESULT:
1FTNX21P43ED47623
03/24/2009
15:43:40
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/22/2003 BUILD DATE
05/16/2003 SALE MILEAGE
00156
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 0 2G01 * * * * * * 8
AWS Claim Key: 2385961 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00989 - * Name: HILBISH MOTOR CO Ph: 704-9383121 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2003 Doc #:09398601
Cust Comments: 03L12 ENGINE EMISSION CONTROL
Tech Comments: REMOVED LABEL AND REPLACED WITH NEW LABEL
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 0 2G05 031405 * RECAL * D50 42 9
AWS Claim Key: 2953016 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00989 - * Name: HILBISH MOTOR CO Ph: 704-9383121 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2003 Doc #:09635501
Cust Comments: 03T02 CALIBRAATION UPDATE
Tech Comments: REPROGRAMMED PCM TCM AND FICM
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 1 6F18 010702 F81Z 2851222 AA R31 33 1404
AWS Claim Key: 4033209 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00989 - * Name: HILBISH MOTOR CO Ph: 704-9383121 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:12-JAN-2004 Doc #:10238401
Cust Comments: CK WEATHERSTRIP ON RT FT DOOR
Tech Comments: REPLACED WEATHERSTRIP ON RT SIDE DOOR
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 4 6O07 011901 1C3Z 17626 AAC B19 33 5506
AWS Claim Key: 5985164 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00989 - * Name: HILBISH MOTOR CO Ph: 704-9383121 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2004 Doc #:10815802
Cust Comments: CK TRIM ON FRONT BUMPER LOOSE
Tech Comments: M TIME TO REPL LOWER TRIM ON BUMPER
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 4 7C01 170501 * 11654 * L29 42 5506
AWS Claim Key: 5985165 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00989 - * Name: HILBISH MOTOR CO Ph: 704-9383121 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2004 Doc #:10815801
Cust Comments: CK HEADLIGHTS FLICKER
Tech Comments: REPLACED HEADLAMP SWITCH
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 38 2E06 030008 3C3Z 9F838 EA E29 42 88130
AWS Claim Key: 14805431 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 04180 - * Name: MOORESVILLE FORD MERCURY, INC. Ph: 704-6641300 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2007 Doc #:019726D
Cust Comments: CUST STATES CK ENG LITE ON
Tech Comments: REPLACE SENSOR
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 38 * * * * * * * 88130
AWS Claim Key: 14797495 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04180 - * Name: MOORESVILLE FORD MERCURY, INC. Ph: 704-6641300 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2007 Doc #:019726A
Cust Comments: RECALL 06E17 RECALIBRATION
Tech Comments: 06E17 RECALL
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 38 2E05 100106 6C3Z 9B249 A G29 42 88130
AWS Claim Key: 14797497 Trx Code: E72 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 04180 - * Name: MOORESVILLE FORD MERCURY, INC. Ph: 704-6641300 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2007 Doc #:019726C
Cust Comments: CUST STATES W.I.F. LITE ON
Tech Comments: REPLACE MODULE
AWS Claim Key: 14797496 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04180 - * Name: MOORESVILLE FORD MERCURY, INC. Ph: 704-6641300 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2007 Doc #:019726B
Cust Comments: 59B01 TEST DRIVE
Tech Comments: 59B01 RECALL
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 48 2G01 03XXXX 4C3Z 12B599 AARM D02 42 95713
AWS Claim Key: 15670881 Trx Code: E72 Labor Hrs: 0
Dlr Cd-Sub Cd: 04180 - * Name: MOORESVILLE FORD MERCURY, INC. Ph: 704-6641300 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2007 Doc #:033148A
Cust Comments: CUST STATES ON COLD START GLOW PLUG LIGHT DOES NOT COME ON ENGINE IS HARD TO START HAS WHITE SMOKE FROM EXHAUST ADVISE
Tech Comments: NEC TO REPLACE MODULE, M TIME IS TO TRACE ALL EEC WIRING AND GROUNDS, CALL FSE, SPEND TIME WITH FSE CHECKING ALL GROUNDS, PCM AND FICM
1FTNX21P43ED47623 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 16-MAY-2003 22-DEC-2003 121656 USA 48 2G01 03XXXX 4C3Z 12B599 AARM D02 42 95714
AWS Claim Key: 15680305 Trx Code: E88 Labor Hrs: 3
Dlr Cd-Sub Cd: 04180 - * Name: MOORESVILLE FORD MERCURY, INC. Ph: 704-6641300 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2007 Doc #:033391A
Cust Comments: SPW FICM MODULE
Tech Comments: REPLACE FICM
4play is offline
djbaines (03-25-2009)
OASIS report please NotaVegetarian Ford Oasis requests 1 08-31-2006 12:11 PM
OASIS Report Please DSL4x4x4 Ford Oasis requests 2 08-30-2006 10:09 AM
oasis report jd87 Ford Oasis requests 2 08-28-2006 08:57 PM
Oasis Report Please imported_shayne74 Ford Oasis requests 1 08-28-2006 02:48 PM
Oasis Report Please OBAF Ford Oasis requests 1 08-11-2006 02:17 AM
