Oasis request please... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Leroy, this thread has received 1 replies and been viewed 543 times.
post #1 of 2 (permalink) Old 03-27-2009, 02:32 AM Thread Starter
Diesel Dreamin
Looking at a used truck at a local dealer.
VIN: 1FTWW32P14EB89528
Any help would be greatly appreciated. Thanks
Leroy is offline
post #2 of 2 (permalink) Old 03-27-2009, 04:18 AM
4play's Avatar
OASIS RESULT:
1FTWW32P14EB89528
03/27/2009
00:17:25
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
61 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/30/2004 BUILD DATE
12/18/2003 SALE MILEAGE
00228
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW32P14EB89528 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 18-DEC-2003 30-SEP-2004 152581 USA 14 * * * * * * * 14268
AWS Claim Key: 7816006 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00840 - * Name: LINDSAY FORD Ph: 405-7563124 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2005 Doc #:16503404
Cust Comments: 59B01 CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: TEST DROVE AFTER RECALLS PER 59B01
AWS Claim Key: 7816005 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00840 - * Name: LINDSAY FORD Ph: 405-7563124 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2005 Doc #:16503403
Cust Comments: EXHAUST PRESSURE SENSOR REPLACEMENT 05E15
Tech Comments: REPLACED EBP SENSOR AND CONNECTOR AND REPROGRAMMED PCM TCM FICM PER RECALL 05E15
1FTWW32P14EB89528 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 18-DEC-2003 30-SEP-2004 152581 USA 14 2H01 * * * * * * 14268
AWS Claim Key: 7816008 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00840 - * Name: LINDSAY FORD Ph: 405-7563124 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2005 Doc #:16503401
Cust Comments: 05B29 CHARGE AIR COOLER DUCT REPLACEMENT
Tech Comments: REPLACED CAC DUCT PER RECALL 05B29
AWS Claim Key: 7816007 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00840 - * Name: LINDSAY FORD Ph: 405-7563124 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2005 Doc #:16503402
Cust Comments: 05S34 FICM WIRING HARNESS REPAIR
Tech Comments: INSTALLED FICM HARNESS PROTECTION KIT AND ICP CONNECTOR PER RECALL 05S34
1FTWW32P14EB89528 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 18-DEC-2003 30-SEP-2004 152581 USA 36 5U05 110301 F81Z 3E650 AA N24 42 35425
AWS Claim Key: 12184200 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01826 - * Name: NORTH POINT FORD LINC-MERC Ph: 918-8257373 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:07-SEP-2007 Doc #:14345901
Cust Comments: WHEN HIT BUMP WHILE DRIVEING FRONT END VIBERATES
Tech Comments: VERIFY CONCERN CHECKED OASIS FOUND AND PERFORMED TSB 03.17.04 ADDED DAMPER PER TSB ON FRAME
4play is offline
Leroy (03-28-2009)
OASIS Request Please p38guy Ford Oasis requests 1 09-26-2007 09:27 PM
OASIS Request Please imported_My427stang Ford Oasis requests 2 09-15-2007 10:31 PM
OASIS Request Wildland Ford Oasis requests 3 09-15-2007 06:31 PM
Oasis Request.. 91rangerturbo Ford Oasis requests 2 09-06-2007 11:45 AM
Oasis request Iron Jaw Ford Oasis requests 1 10-20-2006 04:21 PM
