Oasis request, please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by djbaines, this thread has received 1 replies and been viewed 614 times.
post #1 of 2 (permalink) Old 03-30-2009, 08:45 PM Thread Starter
Could I get a report for this F250:
1FTNX21P24ED30708
Thanks in advance!
Dan
djbaines is offline
post #2 of 2 (permalink) Old 03-30-2009, 09:05 PM
4play's Avatar
OASIS RESULT:
1FTNX21P24ED30708
03/30/2009
17:04:59
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/11/2004 BUILD DATE
04/30/2004 SALE MILEAGE
00029
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/07/2009
DEALER: Akins Ford Corporation
WARRANTY CLAIM NUMBER: 090442 ODOMETER: 076848M
LABOR OP
CONDITION CODE
CONDITION DESC
3C2Z 6B209AA TENSIONER FEAD ASSY 001 6209A 69 FROZEN/SEIZED/BINDING
3C3Z 8620DB BELT-W/PUMP FAN&GENE 001
BELT TENSIONER LOCKED UP, DAMAGED BELT TENSIONER ASSEMBLY & DRIVE BELT - REP LACE
1FTNX21P24ED30708 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 30-APR-2004 11-MAY-2004 121441 USA 11 1H03 030008 4C3Z 9F452 A D50 42 16034
AWS Claim Key: 4278309 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 07997 - * Name: MALL OF GEORGIA FORD Ph: 770-9324060 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:11-MAR-2005 Doc #:04929101
Cust Comments: CUSTOMER STATES TRK IS RUNNING ROUGH AND HAS LOSS OF POWER
Tech Comments: 42 9J460 DIESEL DIAG, CODES P0404, P0299, PINPOINT TEST, REPLACED EP SENSOR, EGR VALVE AND VGT CONTROLLER, REFLASHED PCM, TCM
1FTNX21P24ED30708 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 30-APR-2004 11-MAY-2004 121441 USA 13 3A03 * * * * * * 20424
AWS Claim Key: 5491135 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 07997 - * Name: MALL OF GEORGIA FORD Ph: 770-9324060 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2005 Doc #:05438502
Cust Comments: TRANSMISSION RECALL 04B24
Tech Comments: PLANETARY GEARSET REPLACEMENT 42 R AND R TRANS.OVERHAUL TRANS AND VALVEBODY.FLUSH CONV AND COOLER LINES.INSTALL INLINE FILTERS.POST ROAD TEST.
1FTNX21P24ED30708 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 30-APR-2004 11-MAY-2004 121441 USA 13 2G01 03XXXX * 12B599 * D50 42 20424
AWS Claim Key: 5491134 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 07997 - * Name: MALL OF GEORGIA FORD Ph: 770-9324060 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2005 Doc #:05438501
Cust Comments: CUSTOMER REPORTS CHECK ENGINE WHILE DRIVING WILL SHUT DOWN (NOT OFF) BUT LOOSES POWER , ACCELERATE AND MAY NOT GO OVER 40 MPH.
Tech Comments: 30 9C891 DIESEL DIAG, NO CODES WIGGLE TEST ENGINE HARNESS AND INJECTO R HARNESS AND FOUND WIRE CHAFED BELOW FICM ON INTAKE BOLT REPAIRED HARNESS AND REROUTED AROUND BOLT, REFLASH PCM,FICM AND TCM, ROADTEST
1FTNX21P24ED30708 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 30-APR-2004 11-MAY-2004 121441 USA 19 * * * * * * * 29410
AWS Claim Key: 7684727 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07997 - * Name: MALL OF GEORGIA FORD Ph: 770-9324060 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2005 Doc #:014014F
Cust Comments: 59B01 TEST DRIVE
Tech Comments: 29410 ROADTEST PER RECALL
AWS Claim Key: 7684725 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07997 - * Name: MALL OF GEORGIA FORD Ph: 770-9324060 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2005 Doc #:014014A
Cust Comments: 05E15 EP SENSOR RECALL
Tech Comments: 29410 RECALL 05E15 REPLACED EBP SENSOR AND CONNECTOR, ALSO REFLASHED PCM,FICM,TCM
AWS Claim Key: 7684726 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07997 - * Name: MALL OF GEORGIA FORD Ph: 770-9324060 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2005 Doc #:014014E
Cust Comments: 05S34 FICM RECALL
Tech Comments: 29410 RECALL 05S34 INSPECT AND INSTALLED FICM WIRING HARNESS SHIEL D, ALSO REPLACED ICP CONNECTOR
1FTNX21P24ED30708 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 30-APR-2004 11-MAY-2004 121441 USA 32 1H03 030804 4C3Z 9P456 AF D50 42 56977
AWS Claim Key: 10881397 Trx Code: E72 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 07997 - * Name: MALL OF GEORGIA FORD Ph: 770-9324060 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:18-DEC-2006 Doc #:107873A
Cust Comments: CHECK ENGINE RUNNING ROUGH BLOWING BLCAK SMOKE.
Tech Comments: 56977 01 9P456 DIESEL DIAG, FOUND CODE P0401, P0404, P1335. REMOVE EGR VALVE AND FOUND COVERED IN COOLANT AND SOOT. NECC TO REMOVE FAN CLUTCH, TURBO TO REMOVE INTAKE AND REPLACE EGR COOLER. REINST ALL ALL PARTS AND ROADTEST. 6.0L DIT
1FTNX21P24ED30708 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 30-APR-2004 11-MAY-2004 121441 USA 59 1G04 030509 3C2Z 6B209 AA E19 69 76848
AWS Claim Key: 13097285 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2009 Doc #:09044251
Cust Comments: CUSTOMER STATES AT TIMES BAD NOISE FROM BELT
Tech Comments: BELT TENSIONER LOCKED UP, DAMAGED BELT TENSIONER ASSEMBLY & DRIVE BELT REPLACE
4play is offline
djbaines (03-31-2009)
OASIS Request Please p38guy Ford Oasis requests 1 09-26-2007 09:27 PM
OASIS Request Please imported_My427stang Ford Oasis requests 2 09-15-2007 10:31 PM
OASIS Request Wildland Ford Oasis requests 3 09-15-2007 06:31 PM
Oasis request hhgro Ford Oasis requests 1 09-15-2007 01:21 PM
Oasis Request.. 91rangerturbo Ford Oasis requests 2 09-06-2007 11:45 AM
