Oasis request, please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AegidiusAK, this thread has received 1 replies and been viewed 606 times.
post #1 of 2 (permalink) Old 03-30-2009, 11:40 PM Thread Starter
1ftsw21r48eb59294
Thank You!
AegidiusAK is offline
post #2 of 2 (permalink) Old 03-31-2009, 03:54 PM
4play's Avatar
OASIS RESULT:
1FTSW21R48EB59294
03/31/2009
11:53:24
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
8F716A0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/09/2008 BUILD DATE
06/08/2007 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/18/2009
DEALER: Cal Worthington Ford
WARRANTY CLAIM NUMBER: 397703 ODOMETER: 008830M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8B379B GASKET SET RAD TANK 001 08B06B
THIS CONDITION COULD LEAD TO THE FORMATION OF CRACKS IN THE RADIATOR AND THU S THE POTENTIAL FOR COOLANT LOSS. TO CORRECT THIS CONDITION,A VENTURI TEE WILL BE INSTALLED AT THE DEGAS BOTTLE TO MITIGATE THE FLOW OF COOLANT. INST ALLED TEE AS PER RECALL
03/18/2009
LABOR OP
CONDITION CODE
CONDITION DESC
000 08B07B
THE PREVIOUS PROGRAMING LEVEL ALLOWED CERTAIN DRIVABILITY AND TRANSMISSION S HIFT CONCERNS. TO CORRECT THIS SITUATION, THE PCM AND IC WILL BE REFLASHED TO 57.6 OR HIGHER LEVELS. THIS IS GOOD UNTIL 01-31-09 REGARD REPROGRAMMED PCM,TCM AND IC AS PER RECALL
07/07/2008
DEALER: Kendall Ford of Wasilla
WARRANTY CLAIM NUMBER: 002235 ODOMETER: 002469M
LABOR OP
CONDITION CODE
CONDITION DESC
E6DZ 13466B SMALL BULBS 001 13465A 46 BURNED OUT
INSP.FOUND BLUB BLOWN,TESTED SOCKET OK, RR LEFT REAR TAIL LAMP,REMOVED BL OWN BLUB,INSTALLED NEW BLUB RETESTED OK.
05/06/2008
WARRANTY CLAIM NUMBER: 102953 ODOMETER: 000008M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 5D090A PLT FR RL BK FUL TNK 001 08C04B
FUEL TANK STOPPER RECALL INSTALLED FUEL TANK STOPPER AS PER RECALL
03/18/2008
WARRANTY CLAIM NUMBER: 101047 ODOMETER: 000004M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z25600A58C KIT - SEAT FASTENERS 001 08C01B
COMPLETED INSP DRIVERS SEAT BACK FRAME.PASS.INSTALL CLAMP
1FTSW21R48EB59294 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 08-JUN-2007 09-MAY-2008 174548 USA 0 6E01 * * * * * * 4
AWS Claim Key: 673901 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01009 - * Name: KENDALL FORD OF WASILLA Ph: 907-3765656 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2008 Doc #:10104701
Cust Comments: RECALL 08C01
Tech Comments: COMPLETED INSP DRIVERS SEAT BACK FRAME.PASS.INSTALL CLAMP
1FTSW21R48EB59294 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 08-JUN-2007 09-MAY-2008 174548 USA 0 2E02 * * * * * * 8
AWS Claim Key: 803440 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 01009 - * Name: KENDALL FORD OF WASILLA Ph: 907-3765656 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:06-MAY-2008 Doc #:10295301
Cust Comments: C S PERFORM RECALL 08C04
Tech Comments: FUEL TANK STOPPER RECALL INSTALLED FUEL TANK STOPPER AS PER RECALL
1FTSW21R48EB59294 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 08-JUN-2007 09-MAY-2008 174548 USA 2 7D07 170000 E6DZ 13466 B L26 46 2469
AWS Claim Key: 1122867 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01009 - * Name: KENDALL FORD OF WASILLA Ph: 907-3765656 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2008 Doc #:00223502
Tech Comments: INSP.FOUND BLUB BLOWN,TESTED SOCKET OK, RR LEFT REAR TAIL LAMP,REMOVED BLOWN BLUB,INSTALLED NEW BLUB RETESTED OK.
1FTSW21R48EB59294 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 08-JUN-2007 09-MAY-2008 174548 USA 11 2G01 * * * * * * 8830
AWS Claim Key: 3083012 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08619 - * Name: CAL WORTHINGTON FORD Ph: 907-2765300 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2009 Doc #:39770302
Cust Comments: CERTAIN 2008 MODEL YEAR F SUPER DUTY BUILT WITH 6.4L DIESEL ENGINE FROM JOB 1 TO 09 15 08 AT THE KENTUCKY PLANT MAY EX
Tech Comments: THE PREVIOUS PROGRAMING LEVEL ALLOWED CERTAIN DRIVABILITY AND TRANSMISSION SHIFT CONCERNS. TO CORRECT THIS SITUATION, THE PCM AND IC WILL BE REFLASHED TO 57.6 OR HIGHER LEVELS. THIS IS GOOD UNTIL 01 31 09 REGARD REPROGRAMMED PCM,TCM AND IC AS PER RECALL
1FTSW21R48EB59294 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 08-JUN-2007 09-MAY-2008 174548 USA 11 1F01 * * * * * * 8830
AWS Claim Key: 3083013 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08619 - * Name: CAL WORTHINGTON FORD Ph: 907-2765300 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2009 Doc #:39770301
Cust Comments: CERTAIN 2008 MODEL YEAR F SUPER DUTY VEHICLES BUILT WITH A 6.4L DIESEL ENGINE MAY HAVE A REVERSE FLOW OF COOLER COOLANT
Tech Comments: THIS CONDITION COULD LEAD TO THE FORMATION OF CRACKS IN THE RADIATOR AND THUS THE POTENTIAL FOR COOLANT LOSS. TO CORRECT THIS CONDITION,A VENTURI TEE WILL BE INSTALLED AT THE DEGAS BOTTLE TO MITIGATE THE FLOW OF COOLANT. INSTALLED TEE AS PER RECALL
4play is offline
OASIS Request RallyGTI Ford Oasis requests 1 08-30-2007 07:42 PM
OASIS Request 02Powerstroke Ford Oasis requests 2 08-20-2007 03:18 AM
Oasis request please jschall Ford Oasis requests 2 08-18-2007 02:52 AM
oasis request 04ebex Ford Oasis requests 2 08-03-2007 02:28 PM
OASIS Request please Mustang50 Ford Oasis requests 1 08-03-2007 01:27 PM
