Oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by R33615, this thread has received 1 replies and been viewed 580 times.
post #1 of 2 (permalink) Old 03-31-2009, 05:00 PM Thread Starter
VIN# 1FTNW21P23ED31536
Thanks a bunch
'03 F250 CCSB SRW, SCT, K&N, MBRP STRAIGHT PIPED, SNOW STG 3, LIFTED 6" ON 37'S, RCD's EGR DELETE, AP HD200, TP STG 1 FUEL SYSTEM, HYPERMAX STG 1 INJECTORS, ARP'S, ID TUNED, VARIOUS LITTLE GOODIES...
R33615 is offline
post #2 of 2 (permalink) Old 03-31-2009, 08:16 PM
4play's Avatar
OASIS RESULT:
1FTNW21P23ED31536
03/31/2009
16:15:52
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/16/2003 BUILD DATE
05/22/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNW21P23ED31536 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-MAY-2003 16-SEP-2003 156002 USA 0 2G01 030008 3C3Z 12B599 AARM D02 42 5
AWS Claim Key: 1517859 Trx Code: S07 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 03142 - * Name: LAKEWOOD FORDLAND, INC. Ph: 303-2322200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:16-JUN-2003 Doc #:09784251
Cust Comments: REPAIR TO START, CRANKS BUT NO FIRE.
Tech Comments: NO START DIAGNOSIS FOR 6.0 DIESEL. PIN POINT TEST U0105 DIAGNOSIS PER FCS 1210603E LED TO REPLACEMENT OF PCM. STILL NO START. WITH U0105 CODE. VERIFIED POWER AND GROUND TO FICM O.K.. NOTED ON DATA LOGO THAT NO PID INFO FROM FICM. REPLACED FICM AND ENGINE STARTS. DID ABA AND SYSPTOM RETURNED WITH OLD FICM.
1FTNW21P23ED31536 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-MAY-2003 16-SEP-2003 156002 USA 0 2G01 030008 3C3Z 12B599 AARM D02 42 15
AWS Claim Key: 1579271 Trx Code: E91 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 03142 - * Name: LAKEWOOD FORDLAND, INC. Ph: 303-2322200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2003 Doc #:09831651
Cust Comments: ENGINE WILL NOT START, REFFERENCE TO WRO # 97842.
Tech Comments: DIAGNOSIS. REPLACED FICM. RETESTED O.K.
1FTNW21P23ED31536 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-MAY-2003 16-SEP-2003 156002 USA 0 2G01 * * * * * * 196
AWS Claim Key: 2389222 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03156 - * Name: FREEDOM FORD, INC. Ph: 719-5450192 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:03-SEP-2003 Doc #:06732050
Cust Comments: PERFORM PROG #03L12
Tech Comments: 03L12 INSTALL LABEL
1FTNW21P23ED31536 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-MAY-2003 16-SEP-2003 156002 USA 3 5V01 050306 1C3Z 3B396 CB P82 69 4102
AWS Claim Key: 3700066 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09921 - * Name: BURT FORD ON ARAPAHOE, INC. Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:10-DEC-2003 Doc #:070690A
Cust Comments: CUSTOMER STATES, LF HUB MAKES NOISE AT 75 MPH
Tech Comments: LEFT FRONT 4X4 HUB IS STICKING AND WILL NOT UNLOCK, REPLACED LEFT FRONT 4X4 HUB.
1FTNW21P23ED31536 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-MAY-2003 16-SEP-2003 156002 USA 32 2H01 030008 3C3Z 6K854 DA D50 42 25341
AWS Claim Key: 13661081 Trx Code: E84 Labor Hrs: 8.8
Dlr Cd-Sub Cd: 03170 - * Name: GO COURTESY FORD Ph: 303-7944343 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2006 Doc #:645133C
Cust Comments: CUSTOMER STATES THAT THEY HAVE NOTICED A MAJOR LOSS OF POWER, CHECK AND ADVISE
Tech Comments: 25341 RAN DEISEL PERFORMANCE TEST, KEY ON ENGINE OFF TEST, KEY ON ENGINE RUNNING TEST. FOUND CODE P0404 FOR EGR VALVE. TEST DROVE AND FOUND BOOST PRESSURE TO BE AT 22PSI WHICH IS WITHIN SPEC. MONITERED PIDS AND FOUND NO CONCERNS PRESENT. LET SET OVER NIGHT AND COLD STARTED. FOUND TRUCK TO START RIGHT UP AND RUN SMOOTH. RAN POWER BALANCE AND FOUND ALL CYLINDER TO BE EVEN. LET SET OVER
1FTNW21P23ED31536 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-MAY-2003 16-SEP-2003 156002 USA 47 2E03 03XXXX 3C3Z 9229 B L65 D8 32480
AWS Claim Key: 15346757 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2007 Doc #:75352102
Cust Comments: THE VEHICLE IS LEAKING OIL.APPEARS TO BE FROM THE REAR OF THE ENGINE.
Tech Comments: ENGINE OIL LEAK DIAG. REPLACE LEAKING ORINGS ON CAM SENSOR REPLACE LEAKING CAC HOSE AT TURBO. STEAM CLEAN ENGINE ROAD TEST
1FTNW21P23ED31536 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-MAY-2003 16-SEP-2003 156002 USA 47 * * * * * * * 32480
AWS Claim Key: 15346756 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2007 Doc #:75352104
Cust Comments: RECALL 06E17
Tech Comments: PERFORM RECALL REPROGRAM PCM
1FTNW21P23ED31536 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-MAY-2003 16-SEP-2003 156002 USA 47 2H02 030407 5C3Z 6F089 BA D42 42 32480
AWS Claim Key: 15346758 Trx Code: E72 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2007 Doc #:75352101
Cust Comments: WHILE DRIVING THE ENGINE STARTED TO CUT OUT,SPUTTER.WHEN THIS HAPPENS THE BOOST GAUGE DROPS.IF THE CUSTOMER TURNS THE ENGINE OFF AND RESTARTS IT THE ENGINE WILL RUN NORMALLY FOR A WHILE BU
Tech Comments: 6.0L PERFORMANCE DIAG,KOEO TEST,KOER TEST,INJECTOR SELF TEST ROAD MONITOR TEST,FUEL PRESSURE TESTS,BOOST TEST,VGT TEST, ICP IPR TESTS,EP TEST,INTAKE AND EXHAUST TEST,EGR TEST CODE P0046.WILL LOOSE POWER AT TIMES ENGINE HOT.PERFORM PINPOINT TEST. PERFORM VGT TEST. REPLACE VGT. ROAD TEST RETEST EEC PASS
AWS Claim Key: 15346755 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03130 - * Name: PHIL LONG FORD OF DENVER, LLC Ph: 303-9323673 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2007 Doc #:75352105
Cust Comments: RECALL 59B01
Tech Comments: WE PERFORMED RECALL ROAD TEST
4play is offline
R33615 (03-31-2009)
Oasis Request austin1972 Ford Oasis requests 2 01-25-2008 06:21 AM
OASIS Request blk99 Ford Oasis requests 3 08-31-2007 11:39 PM
OASIS Request 02Powerstroke Ford Oasis requests 2 08-20-2007 03:18 AM
Oasis request please jschall Ford Oasis requests 2 08-18-2007 02:52 AM
OASIS Request please Mustang50 Ford Oasis requests 1 08-03-2007 01:27 PM
