2003 f-350 report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mxracer201, this thread has received 6 replies and been viewed 585 times.
post #1 of 7 (permalink) Old 04-01-2009, 11:53 PM Thread Starter
2003 f-350 report
VIN:IFTSHP33ED44840
Thanks alot guys
mxracer201 is offline
post #2 of 7 (permalink) Old 04-02-2009, 04:51 PM
4play's Avatar
check vin, needs 17 characters
4play is offline
post #3 of 7 (permalink) Old 04-02-2009, 09:07 PM Thread Starter
1FTSW31P33ED44840
Sorry wrote it down incorrectly
post #4 of 7 (permalink) Old 04-02-2009, 10:33 PM
4play's Avatar
OASIS RESULT:
1FTSW31P33ED44840
USA
EN
04/02/2009
18:33:22
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/17/2003 BUILD DATE
05/22/2003 SALE MILEAGE
00002
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
4play is offline
post #5 of 7 (permalink) Old 04-02-2009, 11:53 PM Thread Starter
Hey thank you very much..is there anymore information on the report?
post #6 of 7 (permalink) Old 04-04-2009, 04:04 PM
4play's Avatar
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 2 5A09 0502XX * 4676 * N50 49 3719
AWS Claim Key: 2007184 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2003 Doc #:16286004
Cust Comments: SQUEAL IN FRONT WHEN GOING SLOW WITH WINDOW DOWN
Tech Comments: ROADTESTED TO VERIFY CONCERNS FOUND SQUEAL COMING FROM THE FRONT AXLE HOUSING SEALS LUBED LEFDT AND RIGHT AXLE HOUSING SEALS AND ROADTEST OK
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 6 2G05 031405 * RECAL * D36 42 9531
AWS Claim Key: 3412117 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:19-NOV-2003 Doc #:16908704
Cust Comments: CUST NOTES VEHICLE FEELS TO HAVE LOST SOME POWER ALSO IDLE WILL SURGE AT TIMES
Tech Comments: VERIFIED CONCERN REPROGRAMMED PCM TRANSMISSION CONTROL MODULE AND FUEL INJECTOR CONTROL MODULE TO THE LATEST CALIBRATIONS RETESTED OK
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 8 * * * * * * * 13451
AWS Claim Key: 4181871 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2004 Doc #:17212801
Cust Comments: RECALL 03E03
Tech Comments: REPROGRAM MULTIPLE MODULES TOBALIBRATION LEVEL B24 6 OR LATER
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 8 7G03 120102 * ODOR * C30 42 13451
AWS Claim Key: 4181873 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2004 Doc #:17212803
Cust Comments: CHECK FOR MUSTY OR BURNING SMELL INSIDE CAB AT TIMES
Tech Comments: DEODORIZED A C SYSTEM
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 8 5C02 050100 E4TZ 4800 A N51 49 13451
AWS Claim Key: 4181872 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2004 Doc #:17212802
Cust Comments: ROTATIONAL SQUEEK NOISE FROM REAR OF TRUCK CUSTOMER PINPOINTED TO DRIVESHAFT AREA INSTALL S O P CENTER BEARINGAND ASSOCIATED PIECES PER TSB 03 22 02
Tech Comments: REMOVED REAR DRIVESHAFT DISSASEMBLED R REPLACED CARRIER BEARING PER TSB03 22 02 REINDEXED DRIVESHAFT AND INSTALLED ROAD TESTED OK
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 17 2G05 031405 * RECAL * D36 42 30021
AWS Claim Key: 8187427 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2004 Doc #:18749007
Cust Comments: SLIGHT HESITATION ON LIGHT ACCEL VEHICLE BLOWS BLACK SMOKE AT TIMES ON AC CELERATION FROM 40
Tech Comments: ROAD TESTED VERIFIED CONCERN REPROGRAMMED PCM TO LATEST CALIBRATION REROAD TESTED OK SOME SMOKE IS NORMAL WITH DIE SEL
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 17 5V01 050306 1C3Z 3B396 CB P82 41 30021
AWS Claim Key: 8187426 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2004 Doc #:18749002
Cust Comments: HUBS TURN HARD
Tech Comments: VERIFIED CONCERN REMOVED AND REPLACED BOTH FRONT AUTO HUBS RETESTED OK
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 20 5G02 040103 4C3Z 3049 DA N50 30 35820
AWS Claim Key: 9494559 Trx Code: E84 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2005 Doc #:19208902
Cust Comments: BANGING NOISE IN FRONT END WHEN DRIVING
Tech Comments: ROAD TESTED AND HEARD NOISE FOUND EXCESSIVE LOOSNES IN FRONT STABLIZE BAR AND BUSHINGS
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 20 2E05 100106 3C3Z 9B249 AB G29 42 35820
AWS Claim Key: 9494560 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2005 Doc #:19208905
Cust Comments: DRAIN WATER SEPERATOR
Tech Comments: ATTEMPTED TO DRAIN FOUND SEPERATOR PLUG UNABLE TO REMOVE REPLACED FUEL MANIFOLD PER BB INSTRUCTIONS
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 58 1G01 03XXXX 4C4Z 8592 AA L87 D8 92644
AWS Claim Key: 15837944 Trx Code: E72 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2008 Doc #:24763401
Cust Comments: COOLANT LEAK AT REAR OF ENGINE CUSTOMER HAS TO ADD FLUID
Tech Comments: PRESSURE TEST VERIFIED LEAK COMING FROM HOSE ON EGR COOLER REMOVED INTAKE R REPLACED HOSE ASSY REASSEMBLED FILLED WITH COOLANT RECHECKED OK
1FTSW31P33ED44840 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-MAY-2003 17-JUN-2003 111458 USA 58 * * * * * * * 92644
AWS Claim Key: 15837946 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2008 Doc #:24763405
Cust Comments: 2004 SUPER DUTY AND EXCURSION
Tech Comments: CUSTOMER ASSURANCE TEST DRIVE
AWS Claim Key: 15837945 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2008 Doc #:24763402
Cust Comments: RECALL 06E17
Tech Comments: RECALIBRATE CONTROL MODULES
4play is offline
post #7 of 7 (permalink) Old 04-04-2009, 06:56 PM Thread Starter
hey thanks again...doesnt look bad at all
Oasis Report - 2003 F250 Fighting Irish Ford Oasis requests 3 02-22-2008 04:35 AM
Hate to ask, but I need a Oasis report for my "new" used 2003 F250 6.0 PSD delta dooler Ford Oasis requests 2 02-11-2008 01:41 AM
Oasis Report Please....2003 Excursion 6.0L Rays98GoVols Ford Oasis requests 0 11-30-2007 12:54 PM
Oasis report 2003 6.0L snerdle Ford Oasis requests 1 09-03-2007 10:48 PM
Oasis Report - 2003 Ecursion Joe's Towtruck Ford Oasis requests 1 07-28-2007 03:11 AM
