Oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by deek1963, this thread has received 4 replies and been viewed 537 times.
post #1 of 5 (permalink) Old 04-02-2009, 10:42 PM Thread Starter
Oasis please
I would like an Oasis report for the following:
1FTNW21P94EC28728
Thank you in advance.
deek
deek1963 is offline
post #2 of 5 (permalink) Old 04-02-2009, 10:50 PM
********* and Mafia #90
Bcarriveau's Avatar
Moved to the Oasis forum...
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 5 (permalink) Old 04-02-2009, 10:50 PM Thread Starter
sorry... I posted in the wrong place...
deek1963 is offline
post #4 of 5 (permalink) Old 04-03-2009, 02:34 AM
4play's Avatar
OASIS RESULT:
1FTNW21P94EC28728
USA
EN
04/02/2009
22:33:47
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/03/2004 BUILD DATE
01/28/2004 SALE MILEAGE
00062
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/24/2009
DEALER: Sunnyvale Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 584467 ODOMETER: 024465M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D9 42 DOES NOT OPERATE PROPERLY
4C3Z 9J460A SENSOR ASY EGR PR VL 001 12650D30
3C3Z 9433AA GASKET SET-MANIFOLD 001 9424A
VC 7B 003 MT9424CLEAN
3C3Z 9A375AA GSKT F/P DISC HOS RE 004 6005F6
3C3Z 6691AA GSKT-OIL FLTR RTN PI 001 6005F2
3C3Z 9C165AA KIT-FU/FLTR SE 001 6005F1X1
000 6005F1
INSPECTED FOR CONCERN AND FOUND EGR VALVE STUCK AND EBP SENSOR ALSO CAUSING CONCERN AND INTAKES COAKED REPLACED WITH NEW UPDATES EGR VALVE AND DPFE SE NSOR, DECOAKED INTAKE MANIFOLD CLEARED ALL CODES RECHECKED OK
11/14/2008
DEALER: Walnut Creek Ford
WARRANTY CLAIM NUMBER: 580975 ODOMETER: 020397M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 081613F 42 DOES NOT OPERATE PROPERLY
4C3Z 9G489AARM KIT TRBCH CTR HSG RO 001 12650D9
PM 22A MOTORCRAFT BATTERY 001 12650D84
PM 2 MOTORCRAFT BATTERY 001
6K682 TURBO CHG-EXH DRIVE 000
20404 INSPECT FOR CONCERN VERIFIED CONCERN EEC TEST FOUND CODES P0470 AND P 0299 PINPOINT TEST FOR P0470 WIGGLE TEST AHRNESS AT EBP SENSOR OK RECC REP LACE EBP AND RETEST REMOVED AND REPLACED EBP SENSOR CLEANED EBP TUBE AND RE TEST PASS ROADTEST VEHICLE FOUND CODE P0299 CAME BACK AND VEHICLE LACKS PO WER SUSPECT STICKING TURBO VANES REMOVED TURBO AND INSPECT CASE HALF FOUND
4play is offline
post #5 of 5 (permalink) Old 04-04-2009, 04:05 PM
4play's Avatar
1FTNW21P94EC28728 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-JAN-2004 03-SEP-2004 172016 USA 16 2H01 * * * * * * 8435
AWS Claim Key: 7807392 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07820 - * Name: WALNUT CREEK FORD Ph: 925-9322900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2005 Doc #:484227A
Cust Comments: CERTAIN 2004 MODEL YEAR F250 350 450 550 & EXCURSION VEHICLES CHARGE AIR COOLER DUCT REPLACEMENT
Tech Comments: 8435 REPLACED CAC TUBE
1FTNW21P94EC28728 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-JAN-2004 03-SEP-2004 172016 USA 16 * * * * * * * 8435
AWS Claim Key: 7807394 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07820 - * Name: WALNUT CREEK FORD Ph: 925-9322900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2005 Doc #:484227C
Cust Comments: 05E15 CERTAIN 2004 MODEL YEAR F250 350 450 550,EXCURSION,& E350 450 VEHICLES EXHAUST PRESSURE SENSOR REPLACEMENT,ON BOARD DIAGNOSTIC SYSTEM & ENGINE CONTROL MODULE REPLACEMENT.
Tech Comments: 8435 REPLACED EBP SENSOR AND CONNECTOR
AWS Claim Key: 7807395 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07820 - * Name: WALNUT CREEK FORD Ph: 925-9322900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2005 Doc #:484227D
Cust Comments: ONE TIME TEST DRIVE AFTER PERFORMANCE OF 04S34 05E15.
Tech Comments: 8435 ROAD TESTED GOOD
AWS Claim Key: 7807393 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07820 - * Name: WALNUT CREEK FORD Ph: 925-9322900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2005 Doc #:484227B
Cust Comments: 05S34 CERTAIN 2004 F250 350 450 550,EXCURSION,& E350 450 VEHICLES FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
Tech Comments: 8435 INSTALLED LOOM REPAIR KIT REPLACED ICP CONNECTOR REFLASH PCM TCM FICM
1FTNW21P94EC28728 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-JAN-2004 03-SEP-2004 172016 USA 33 2H02 030008 * 6F089 * E29 42 14934
AWS Claim Key: 11519683 Trx Code: S07 Labor Hrs: 9.3
Dlr Cd-Sub Cd: 07820 - * Name: WALNUT CREEK FORD Ph: 925-9322900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2007 Doc #:531579D
Cust Comments: CHECK ENGINE LIGHT ON CHECK AND ADVISE
Tech Comments: 14936 TURBO AND EGR VALVE STICKING WARR PERFORM DIESEL DIAGNOSIS CHECK OIL AND FUEL OK CHECK AND PERFORM KOEO TEST PASS RETRIEVE CONTINUOUS CODES P0299 P0404 PERFORM KOER TEST PASS TEST EGR USING IDS TEST FAILED OPEN TEST REMOVE EGR AND CLEAN VALVE RETEST STILL FAIL PER TSB 061906C REPLACE EGR VALVE RETEST EGR PASS TEST VGT USING IDS TEST TURBO NOT FULLY OPERATING PER TSB 062302B REMOVE
1FTNW21P94EC28728 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-JAN-2004 03-SEP-2004 172016 USA 52 2H01 0300XX * 6K682 * E29 42 20397
AWS Claim Key: 12965399 Trx Code: S07 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 07820 - * Name: WALNUT CREEK FORD Ph: 925-9322900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-NOV-2008 Doc #:580975A
Cust Comments: (K)CUST STATES CK ENGINE LIGHT WAS ON VEHICLE HAD NO THROTTLE RESPONSE AT LOWER SPEEDS AT TIMES
Tech Comments: 20404 INSPECT FOR CONCERN VERIFIED CONCERN EEC TEST FOUND CODES P0470 AND P0299 PINPOINT TEST FOR P0470 WIGGLE TEST AHRNESS AT EBP SENSOR OK RECC REPLACE EBP AND RETEST REMOVED AND REPLACED EBP SENSOR CLEANED EBP TUBE AND RETEST PASS ROADTEST VEHICLE FOUND CODE P0299 CAME BACK AND VEHICLE LACKS POWER SUSPECT STICKING TURBO VANES REMOVED TURBO AND INSPECT CASE HALF FOUND RUST IN
1FTNW21P94EC28728 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 28-JAN-2004 03-SEP-2004 172016 USA 55 1H03 030008 4C3Z 9F452 A D50 42 24465
AWS Claim Key: 13083164 Trx Code: S07 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 07934 - * Name: SUNNYVALE FORD LINCOLN MERCURY Ph: 408-7381800 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2009 Doc #:58446701
Cust Comments: CUSTOMER STATES IN AM WHEN COLD VEH BLOWS WHITE SMOKE AND RUNS ROUGH,ALSO CHECK ENGINE LIGHT IS ON,AFTER VEH WARMS UP VEH RUNS NORMAL,CHECK AND ADVISE
Tech Comments: INSPECTED FOR CONCERN AND FOUND EGR VALVE STUCK AND EBP SENSOR ALSO CAUSING CONCERN AND INTAKES COAKED REPLACED WITH NEW UPDATES EGR VALVE AND DPFE SENSOR, DECOAKED INTAKE MANIFOLD CLEARED ALL CODES RECHECKED OK
4play is offline
