Oasis Needed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 03RescueDiesel, this thread has received 2 replies and been viewed 727 times.
post #1 of 3 (permalink) Old 04-03-2009, 02:44 AM Thread Starter
9/11/01 343
03RescueDiesel's Avatar
Send a message via AIM to 03RescueDiesel
Oasis Needed
Need an Oasis again Thanks again for the help.
1FTWW31P55EA08367
03 F250 PSD CC LB Fx4 Wouldnt you like to know whats going
TDG Singles club #228
TDG RIDIN' DIRTY #43
TDG Member Feb 2006
Qauntico Fire Dept, Dale City Volunteer Fire Dept
9/11/01 All Gave Some Some Gave All 343.
03RescueDiesel is offline
post #2 of 3 (permalink) Old 04-03-2009, 03:15 AM
4play's Avatar
OASIS RESULT:
1FTWW31P55EA08367
USA
EN
04/02/2009
23:15:17
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/17/2004 BUILD DATE
07/27/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
4play is offline
post #3 of 3 (permalink) Old 04-04-2009, 04:06 PM
4play's Avatar
1FTWW31P55EA08367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-JUL-2004 17-SEP-2004 123189 USA 2 2G05 031405 * RECALEM * G29 42 3114
AWS Claim Key: 138533 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05029 - * Name: RON BLACKWELL FORD, INC. Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2004 Doc #:02587751
Cust Comments: WATER IN FUEL LIGHT WILL NOT GO OFF EVEN AFTER DRAINING
Tech Comments: VERIFY CONCERN RUN OASIS RECALIBRATE PCM AND RECHECK
1FTWW31P55EA08367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-JUL-2004 17-SEP-2004 123189 USA 2 6U03 011705 5C3Z 78519A02 AAA J04 01 3114
AWS Claim Key: 231641 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05029 - * Name: RON BLACKWELL FORD, INC. Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2004 Doc #:63838152
Tech Comments: CHECK SUNROOF HANDLE FELL OFF RR ASSY COVER
1FTWW31P55EA08367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-JUL-2004 17-SEP-2004 123189 USA 2 6H08 011105 5C3Z 28422B30 AA G07 42 3114
AWS Claim Key: 231640 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 05029 - * Name: RON BLACKWELL FORD, INC. Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2004 Doc #:63838151
Tech Comments: CHECK REAR WINDOW SLOW OR WONT OPERATE AT ALL INOP RR REAR POWER WINDOW ASSY
1FTWW31P55EA08367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-JUL-2004 17-SEP-2004 123189 USA 13 6A06 010104 * 38280A58 * F06 P2 34781
AWS Claim Key: 1957102 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 05227 - * Name: BOB MALONEY FORD-MERCURY INC Ph: 479-6364321 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2005 Doc #:01989701
Cust Comments: PAINT ON CAB CORNER PEELING
Tech Comments: REPAINTED CAB CORNER
1FTWW31P55EA08367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-JUL-2004 17-SEP-2004 123189 USA 14 2H02 030008 5C3Z 6F089 A D41 28 40754
AWS Claim Key: 2438492 Trx Code: S07 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 04275 - * Name: LANDERS-MCLARTY FORD Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:04-NOV-2005 Doc #:02123802
Cust Comments: CUSTOMER STATES SURGES WHEN DRIVING CAN HEAR AT 30 MPH
Tech Comments: PERFORM DIAG VGT TEST EBP PRESSURE 16 PSI KOEO SHOULD BE 14 EGR VALVE STICKING BETWEEN 15 AND 40 REPLACE VGT ACTUATOR EGR VALVE AND EBP SENS ROAD TEST RECHEC EEC SYSTEM
1FTWW31P55EA08367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-JUL-2004 17-SEP-2004 123189 USA 28 * * * * * * * 69510
AWS Claim Key: 6699689 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04275 - * Name: LANDERS-MCLARTY FORD Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2006 Doc #:04556702
Cust Comments: 59B01 RECALL
Tech Comments: PERFORM RECALL PER BULLETIN
AWS Claim Key: 6699690 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04275 - * Name: LANDERS-MCLARTY FORD Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2006 Doc #:04556701
Cust Comments: 05E15 RECALL
AWS Claim Key: 6699688 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04275 - * Name: LANDERS-MCLARTY FORD Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2006 Doc #:04556703
Cust Comments: 05B32 RECALL
1FTWW31P55EA08367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-JUL-2004 17-SEP-2004 123189 USA 31 1A02 030008 4C3Z 6051 DA L87 42 75365
AWS Claim Key: 7480441 Trx Code: E72 Labor Hrs: 16.8
Dlr Cd-Sub Cd: 04275 - * Name: LANDERS-MCLARTY FORD Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:05099501
Cust Comments: VEHICLE LOSING COOLANT BLOWS WHITE SMOKE FROM EXHAUST
Tech Comments: VERIFIED CONCERN FOUND EGR COOLER LEAKING REMOVED GLOW PLUGS FOUND COOLANT ROAD TESTED WITH PRESSURE GAUGE 21 PSI FOUND HEAD GASKET FAULTY ENGINE HARNESS OIL S REMOVED CAB REPLACED HEAD GASKETS AND EGR COOLER ENGINE OIL HARNES WAS OIL SOAKED AND DAMAGED ALSO REPLACED
1FTWW31P55EA08367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 27-JUL-2004 17-SEP-2004 123189 USA 31 2A01 031202 6C3Z 6C646 BA L65 42 75365
AWS Claim Key: 7457966 Trx Code: E72 Labor Hrs: 3
Dlr Cd-Sub Cd: 04275 - * Name: LANDERS-MCLARTY FORD Ph: 479-2739022 St:AR Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:05099502
Cust Comments: OIL LEAK AT TOP OF ENGINE
Tech Comments: INSPECTED FOUND FRONT CRANK SEAL LEAKING AND CAC TUBE COLD SIDE LEAKING REPLACED FRONT CRANK SEAL AND COLD SIDE CAC TUBE
4play is offline
Oasis needed........ roadster383 Ford Oasis requests 1 04-05-2007 01:02 AM
Oasis needed...... roadster383 Ford Oasis requests 1 03-24-2007 09:53 PM
OASIS needed blktruk Ford Oasis requests 2 03-15-2007 07:46 AM
OASIS Needed, Appreciate Your Help ... DemonicF350 Ford Oasis requests 1 12-04-2006 12:20 PM
Oasis Needed please. F350CCFX4 Ford Oasis requests 1 03-08-2006 01:52 AM
