iwould apprediate an oasis report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by albert bryans, this thread has received 1 replies and been viewed 858 times.
post #1 of 2 (permalink) Old 04-03-2009, 11:21 AM Thread Starter
i have asked a dealer for this but they say not available.when you get time please run an oasis report for me . 1FTWW32P03EB90071 i appreciate this info
albert bryans is offline
post #2 of 2 (permalink) Old 04-04-2009, 03:59 PM
4play's Avatar
OASIS RESULT:
1FTWW32P03EB90071
USA
EN
04/04/2009
11:57:54
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
61 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/31/2003 BUILD DATE
01/13/2003 SALE MILEAGE
00650
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 1 2G02 031201 3L3Z 12B579 AB D42 42 4965
AWS Claim Key: 1114940 Trx Code: S07 Labor Hrs: 6.3
Dlr Cd-Sub Cd: 01969 - * Name: EMPIRE FORD LINCOLN MERCURY Ph: 276-6282127 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:29-APR-2003 Doc #:140819A
Cust Comments: CUSTOMER STATES VEH HAS LOSS OF POWER
Tech Comments: TEST DRV VEH VERIFIED LOSS OF POWER PERFORMED DIESEL DIAG TEST FOUND MASS AIR FLOW SENSOR FAULTY REPLACED MASS AIR FLOW SENSOR CLEARED CODES AND TEST DRV VEH PERFORMANCE IS SATISFACTORY
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 1 2E01 * * * * * * 4965
AWS Claim Key: 1102841 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01969 - * Name: EMPIRE FORD LINCOLN MERCURY Ph: 276-6282127 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:29-APR-2003 Doc #:140819E
Cust Comments: RECALL 03B05
Tech Comments: PERFORMED RECALL 03B05
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 1 2G05 * * * * * * 4965
AWS Claim Key: 1102840 Trx Code: 03B06 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01969 - * Name: EMPIRE FORD LINCOLN MERCURY Ph: 276-6282127 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:29-APR-2003 Doc #:140819D
Cust Comments: RECALL 03B06
Tech Comments: PERFORMED RECALL 03B06 AND 57B98
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 2 2G04 031401 * 12A650 * D13 42 7624
AWS Claim Key: 1409726 Trx Code: S07 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02863 - * Name: HUFF FORD , INC. Ph: 276-2283108 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2003 Doc #:02372101
Cust Comments: CUST STATES VEHICLE IDLES ROUGH
Tech Comments: RAN DIESEL DIAG FOR ROUGH FOR ICP REPLACEMENT REPROGRAMED PCM WITH LATEST CAL 3ESBZ010
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 2 2E06 030008 3C3Z 9F838 EA D13 42 7624
AWS Claim Key: 1409727 Trx Code: E93 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02863 - * Name: HUFF FORD , INC. Ph: 276-2283108 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2003 Doc #:02372102
Cust Comments: CUST STATES ROUGHT IDLE RECALL 03B05 HAS BEEN COMPLETED
Tech Comments: DONE ICP TEST REF SERVICE MESSAGE ICP PASS BORDER LINE AT .18 VOLTS REENW ICP FOR BORDERLINE REF VOLTAGE RETEST AT .2 VOLTS OK
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 2 2H02 030008 3C3Z 6F089 AA D42 42 9696
AWS Claim Key: 1314665 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 02863 - * Name: HUFF FORD , INC. Ph: 276-2283108 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:28-MAY-2003 Doc #:02386701
Cust Comments: CUST STATES LACK OF POWER AND RUNS ROUGH
Tech Comments: SEE ATTACHED SHEET KOEO KOER PID MONITOR PERFORMED TEST CODE P0046 SSM 16774 REPLACED VGT RETESTED OK ROAD TESTED OK PID VALUES NOT CHANING NO FAULT WITH WIRING WHEN RAISING VGT PERCENTAGE REPLACED VGT VGT CAME APART
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 6 1A03 030008 * 6012 * A99 82 52106
AWS Claim Key: 2647358 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 02863 - * Name: HUFF FORD , INC. Ph: 276-2283108 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2003 Doc #:02557901
Cust Comments: PER JAISON LEE 1 MONTH PAYMENT REIMBURSMENT
Tech Comments: APPROVAL K08GS
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 7 2H01 030008 3C3Z 6K854 DA L66 D1 66691
AWS Claim Key: 3386286 Trx Code: E72 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 02863 - * Name: HUFF FORD , INC. Ph: 276-2283108 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:24-OCT-2003 Doc #:02608502
Cust Comments: CUST STATES CHECK FOR EXHAUST LEAK
Tech Comments: CKD WITH SMOKE MACHINE FOUND CROSSOVER PIPE LEAKING LEFT SID E DISASSEMBLED AND REMOVED TURBOCHARGER ASSY TO GAIN ACCESS REMOVED AND REPLACED TURBO INLET YPIPE FROM MANIFOLDS TO TURBO HAD TO RI EXTENSION PIPE ON RH REAR TO GAIN ACCESS TO ALLOW REMOVAL OF INLET Y PIPE RR 3 BROKEN BOLTS AND REASSEMBLE REINSTALL TURBOCHARGER AND REASSEMBLE ROAD TESTED RECK VERIFYY REPAIR OK
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 7 2G04 031401 * 12A650 * D13 42 66691
AWS Claim Key: 3386287 Trx Code: E72 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02863 - * Name: HUFF FORD , INC. Ph: 276-2283108 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:24-OCT-2003 Doc #:02608501
Cust Comments: CUST STATES ROUGH IDLE
Tech Comments: 1 REPROGRAMMED PCM FICM TCM PER TSB
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 8 * * * * * * * 72530
AWS Claim Key: 3325320 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2003 Doc #:05207652
Cust Comments: 57B98 RECALL OIL CHANGE
Tech Comments: 57B98 RECALL OIL CHANGE
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 8 2H01 030008 3C3Z 6K682 AARM D42 42 72530
AWS Claim Key: 3325321 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 00960 - * Name: LAFAYETTE FORD Ph: 910-4240281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2003 Doc #:05207653
Cust Comments: CHECK FORBLOWN TURBO
Tech Comments: LEAKING SENSOR INJECTION CONTROL PRESSURE (ICP) REMOVE AND INSTA
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 8 2E06 030008 3C3Z 9F838 EA D42 42 75518
AWS Claim Key: 3544545 Trx Code: E72 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 02863 - * Name: HUFF FORD , INC. Ph: 276-2283108 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:24-NOV-2003 Doc #:02649602
Cust Comments: CUST STATES LOSS OF POWER BLOWING BLUE SMOKE
Tech Comments: PERFORMED DIAGNOSIS PER DIESEL 6.0 WOORKSHEET PINPOINT TEST KA1 Y KA2 Y KA4 N REPLACED ICP SENSOR CLEAR CODES OK
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 54 * * * * * * * 85169
AWS Claim Key: 15446298 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01071 - * Name: HARRELSON FORD, INC. Ph: 704-5522760 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2007 Doc #:07509142
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: RECALL PERFORMED RECALL 06E17, REPROGRAMMED PCM
AWS Claim Key: 15446297 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01071 - * Name: HARRELSON FORD, INC. Ph: 704-5522760 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2007 Doc #:07509141
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: TEST DRIVE PERFORMED 59B01, QUALITY ASSURANCE TEST DRIVE
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 54 * * * * * * * 84296
AWS Claim Key: 15539315 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05137 - * Name: APPLE FORD OF LYNCHBURG, INC. Ph: 434-3855012 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:20-AUG-2007 Doc #:02065503
Cust Comments: RECALL 04S15
Tech Comments: REPLACED GROUND STRAP BOLT PER RECALL 04S15C
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 54 2E06 030008 3C3Z 9A543 AARM D02 42 84296
AWS Claim Key: 15539316 Trx Code: E72 Labor Hrs: 16.4
Dlr Cd-Sub Cd: 05137 - * Name: APPLE FORD OF LYNCHBURG, INC. Ph: 434-3855012 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:20-AUG-2007 Doc #:02065501
Cust Comments: CUSTOMER STATES LOSS OF POWER AND NOW IT WONT START VEHICLE HAD TO BE TOWED TO DEALER FOR REPAIR
Tech Comments: CD42 9A543 PUMP NOT OPERATING PROPERLY ENGINE PERF DIAG, KOEO, KOER, P2291 P2290 P2623, CHECK FOR CLEAN FUEL AND GOOD FUEL PSI, CHECK FOR RESTRICTED INTAKE AND EXHAUST, EGR VGT ICP IPR TESTS, FUEL AND OIL AERATION TEST, BOOST PSI TEST, CRANKCASE PSI TEST, PINPOINT TEST, FOUND ICP SENSOR OPEN CKT, IPR VALVE STUCK DUE TO METAL CONTAMINATION, AND HI PSI PUMP LOW FLOW MAKING METAL, R&I
1FTWW32P03EB90071 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 13-JAN-2003 31-MAR-2003 127503 USA 57 1G02 030008 3C3Z 8501 A D50 42 95256
AWS Claim Key: 15653684 Trx Code: E72 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01071 - * Name: HARRELSON FORD, INC. Ph: 704-5522760 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2007 Doc #:08008851
Cust Comments: C S VEH HAS NOISE COMING FROM ENGINE AREA LOOKS LIKE WATER PUMP PULLEY BENT CK AND ADVISE
Tech Comments: WATER PUMP BAD, NOISE COOLING SYSTEM PRESSURE TEST DIAGNOSIS
4play is offline
Oasis report please ff3813 Ford Oasis requests 4 09-27-2007 09:13 PM
OASIS Report Please. mulcrkjim Ford Oasis requests 2 02-16-2007 05:13 PM
Please Please OASIS Report Snowaholic Ford Oasis requests 3 08-04-2006 05:47 PM
OASIS report please firefighter56 Ford Oasis requests 2 08-03-2006 09:46 PM
Oasis Report Please Tarman30 Ford Oasis requests 1 08-03-2006 03:07 AM
