Oasis request, please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by djbaines, this thread has received 1 replies and been viewed 1222 times.
post #1 of 2 (permalink) Old 04-03-2009, 01:27 PM Thread Starter
Thanks again for the asistance:
1FTNX21FX2EB33239
Dan
djbaines is offline
post #2 of 2 (permalink) Old 04-04-2009, 04:07 PM
4play's Avatar
OASIS RESULT:
1FTNX21FX2EB33239
USA
EN
04/04/2009
12:07:12
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/21/2001 BUILD DATE
11/24/2001 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 5 7S02 180102 * 14401 * C20 X2 1849
AWS Claim Key: 1337501 Trx Code: 1 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 02347 - * Name: FAIRWAY FORD OF ANDERSON Ph: 864-2254151 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2002 Doc #:133788A
Cust Comments: CUSTOMER STATES THE AC IS NOT BLOWING OUT COLD AIR
Tech Comments: AC DIAGNOSIS,R AND R INSTRUMENT PANEL AND REPAI RED WIRING,AND VERIFIED REPAIR.
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 8 5G05 040001 * FRONT * H24 W6 6166
AWS Claim Key: 1991695 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02347 - * Name: FAIRWAY FORD OF ANDERSON Ph: 864-2254151 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:20-JUL-2002 Doc #:139715E
Cust Comments: CUST STATES VEH DOES NOT TRACK STRAIGHT WONDERS
Tech Comments: CHECK AND CORRECT TOE
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 10 2G04 000615 * DIAG * D03 07 10178
AWS Claim Key: 2891929 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00977 - * Name: FAIRWAY FORD, INC. Ph: 864-2425060 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2002 Doc #:224680C
Cust Comments: CHECK ENGINE FOR HARD TO START AT TIMES
Tech Comments: ROAD TEST, CK EEC SYS AND GLOW PLUGS, PERFORMED PPTEST, CLEARED AND RECHECKED, NO PROBLEM FOUND
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 10 7S02 130301 YF1Z 14A069 AA D42 07 10178
AWS Claim Key: 3398152 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00977 - * Name: FAIRWAY FORD, INC. Ph: 864-2425060 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2002 Doc #:224722E
Cust Comments: CK ENGINE FOR LOW POWER AT LOW SPEEDS
Tech Comments: ROAD TEST, CK EEC SYS. PERFORMED PP TEST, CLEARED AND RECHECKED, REPLACED SHORTED WIRE, RECHCKED
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 10 7H11 120305 * 19C836 * C05 07 10179
AWS Claim Key: 3158490 Trx Code: 2 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 00977 - * Name: FAIRWAY FORD, INC. Ph: 864-2425060 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2002 Doc #:224722C
Cust Comments: CK A C SYSTEM FOR LEAK
Tech Comments: CK AC FOR LEAKS, REPOSITIONED AND SECURED ACCUMULATOR AND EVAP. CORE FITTINGS, RECHECKED
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 10 6L03 011201 2C3Z 2504459 AAB T90 07 10179
AWS Claim Key: 3158489 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00977 - * Name: FAIRWAY FORD, INC. Ph: 864-2425060 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2002 Doc #:224722A
Cust Comments: REPLACE FUSE PANEL RETAINING TAB BROKEN
Tech Comments: REPLACED FUSE PANEL COVER.
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 18 5V03 060302 * 2B120 * H06 41 22965
AWS Claim Key: 5829717 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02347 - * Name: FAIRWAY FORD OF ANDERSON Ph: 864-2254151 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2003 Doc #:162143A
Cust Comments: CUST STATES VEH PULLING TO LEFT**SEE LARRY M HE DROVE VEH ON SATURSDAY
Tech Comments: DIAGNOS VEHICLE PULLING. R AND R FRONT WHEELS A ND FOUND CALIPERS ARE STICKING,CLEAN AND LUBE S LIDES,TEST DRIVE TO VERIFY REPAIR.
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 27 6P07 011202 2C3Z 7811586 BAB N30 01 34930
AWS Claim Key: 9404772 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02713 - * Name: DON SMITH FORD MERCURY LLC Ph: 828-7651200 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:18-FEB-2004 Doc #:107431A
Cust Comments: CUST STATES OVERHEAD CONSOLE BROKEN
Tech Comments: VEERIFY CONCERN,REPLACED OVERHEAD CONSOLE
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 31 5T01 031801 2C3Z 9F836 DE E29 42 34563
AWS Claim Key: 11021114 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 02713 - * Name: DON SMITH FORD MERCURY LLC Ph: 828-7651200 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2004 Doc #:109249A
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT IS ON
Tech Comments: VERIFY CONCERN,FOUND THROTTLE POSITION SENSOR OUT OF RANGE,REPLACE THROTTLE PEDAL ASSY,TEST DRIVE,CONFIRM PROBLEM FIXED
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 44 2B01 0300XX F7TZ 12K073 A D36 42 50871
AWS Claim Key: 14016097 Trx Code: E72 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02713 - * Name: DON SMITH FORD MERCURY LLC Ph: 828-7651200 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2005 Doc #:115676A
Cust Comments: CUSTOMER STATES VEHICLE CUTS OUT WHILE DRIVING
Tech Comments: VERIFIED CUSTOMER COMPLAINT, REPLACE CAM SENSOR PROBLEM CORRECTED
1FTNX21FX2EB33239 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 24-NOV-2001 21-DEC-2001 121783 USA 77 * * * * * * * 81836
AWS Claim Key: 16724168 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02713 - * Name: DON SMITH FORD MERCURY LLC Ph: 828-7651200 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:20-MAR-2008 Doc #:131116A
Cust Comments: CUSTOMER STATES THERE IS AN OPEN RECALL 07S57 CAM SENSOR
Tech Comments: PERFORMED RECALL 07S57B AS OUTLINED
4play is offline
djbaines (04-06-2009)
Oasis Request austin1972 Ford Oasis requests 2 01-25-2008 06:21 AM
Oasis Request PSD Trav Ford Oasis requests 4 01-15-2008 09:19 PM
Oasis request johns Ford Oasis requests 1 08-17-2007 12:48 AM
Oasis Request johns Ford Oasis requests 1 08-03-2007 01:36 PM
Oasis Request wardlandscape Ford Oasis requests 1 12-13-2006 11:46 AM
