Oasis Report Please... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by whanner, this thread has received 2 replies and been viewed 940 times.
post #1 of 3 (permalink) Old 04-03-2009, 02:27 PM Thread Starter
whanner's Avatar
Oasis Report Please...Thanks for your time.
VIN 1FTWW33P56EC97216
06' F350
I'm not a Diesel Mechanic or Expert. All posts are just guesstimations.
4" Turbo Back Exhaust, 2" lift in front,1" Lift In the Rear, EGT Gauge, ARP Studs.
whanner is offline
post #2 of 3 (permalink) Old 04-04-2009, 04:11 PM
4play's Avatar
OASIS RESULT:
1FTWW33P56EC97216
USA
EN
04/04/2009
12:08:41
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
WARNING MESSAGES
CUDL - DIGITAL IMAGING DENIED A WARRANTY REPAIR. SEE CUDL FOR DETAILS
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/05/2006 BUILD DATE
02/18/2006 SALE MILEAGE
00039
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0994 - USA 2006 NEW 60/60,000 P'TRAINCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: WALTER HANNER
OPTIONS:
EXPIRATION DATE: 09/05/2011
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 40919
ESP CONTRACT START DATE: 09/05/2006
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
02/24/2009
DEALER: Five Star Ford
WARRANTY CLAIM NUMBER: 425661 ODOMETER: 025688M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12A342AA PLUG-GLOW 001 6005F 28 OPEN CIRCUIT
000 6005F1
000 6005F13
000 6005F45
000 6005F1X1
000 10654CA
000 12342D1L
25688 GLOW PLUG NO.4 AND PCM REFLASH CC_28.VERIFIED CONCERN.PERFORMED DIESEL DIAGNOS IS.PERFORMED VISUAL INSPECTIONS AIR,FUEL,OIL PA SSED.PERFORMED KOE O ON DEMAND SELF TEST P0674. PINPOINT TEST AF.CHECKED CHARGING SYSTEM 13.5V PASSED.REFLASHED PCM,FICM,TCM TO LATEST CALIBRA TION PER TSB 08-26-03.REPLA CED NO.4 GLOW PLUG D UE TO OPEN 26OHMS RESISTANCE.NECESSARY TO R&R D EGAS B
02/24/2009
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6700BA OIL SEAL CYL FRT COV 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6619FA GASKET (OIL PUMP) 001 6700A
W300024 004 6083A
3C3Z 6701B CRANKSHAFT REAR SEAL 001
3C3Z 6D083AA GASKET-RR COVER 001
OSP 001
VC 7B 003
3C3Z 6C751A KIT-VLV OIL PRESS RE 001
25702 REAR COVER GASKET,FRONT CRANK SEAL CC_D8.VERIFIED CONCERN.PERFORMED O IL DYE LEAK TEST.INSTALLED OIL DYE AND PRESSURE WASHED ENGI NE.ROADTEST.IN SPECT WITH BLACKLIGHT.REPLACED FR ONT CRANK SEAL,GEROTOR HOUSING GASKET AND OIL PRESSURE REGULATOR DUE TO LEAKING OIL.RESEALED REAR ENGINE COVER AND REPLACED REAR MAIN SEAL D UE TO LEAKING OIL ALSO.NECESSARY TO R&R 4X4 AUT
02/24/2009
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 10346DA ALTERNATOR LESS PULL 001 10654CA 46 BURNED OUT
BXT 65750 MOTORCRAFT BATTERY 002 10654C1T
000 10346A
000 10200A
25702 11LJS XJBS0 000 ACES XE2EK, 11NJT 1JTS0 81W VERIFIED CONCERN, BATTERY TEST BOTH BATTERYS FAILED. REPLACE BATTERYS, CHECKED CHARGING SYSTEM ALTERN ATOR ONLY CHARGING AT 12.2V AND 21 AMPS AND DIODE PATTERN FAILED. REPLACED A LTERNATOR AND VERIFIED REPAIRS.
02/24/2009
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 2520000DAC TAPE STRIPE KIT 001 OSL 81 TARNISHED/FADED
5C3Z35290D12BC TRNSF-BDY SD PNL CLR 001
5C3Z26255A66CAB DECAL STRIPE 001
25702 PIN STRIPES REPLACED BY OUTSIDE LABOR
07/07/2008
DEALER: Bankston Ford of Grapevine
WARRANTY CLAIM NUMBER: 515801 ODOMETER: 021626M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 2660045CC S/BELT&BCKL RR ST LH 001 60044A 42 DOES NOT OPERATE PROPERLY
21626 REAR SEAT BELT BUCKLE FAILED CC-42 VERIFIED CUST CONCERN.REPLACED LEFT REAR SEAT BELT BUCKLE ASSY.
07/07/2008
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12B599AARM IDM MOD ASY-FUELINJ 001 12650D67 42 DOES NOT OPERATE PROPERLY
4C3Z 8A616AA CLUTCH ASY-FAN A/C 001 8616A
000 12650D
000 12650DX1
21634 ELECTRIC FAN CLUTCH CC-42,8A616,12B599 ROAD TEST,VERIFIED CONCERN.PERF ORM EEC QUICK TEST.FOUND CODE P0458(ELECTRIC FAN CLUTCH OPERATION)ALSO FICM CODE P0267(CYL #3 CIRCUIT LOW)MONITOR FAN SPEED WHILE DRIVING.NOTICED UNCO MMANDED FAN OPERATION.REPLACED ELECTRIC FAN CLUTCH & FUEL INJECTOR CONTROL MODULE.RETEST,VERIFIED REPAIR.
07/07/2008
LABOR OP
CONDITION CODE
CONDITION DESC
TA 29 MOTORCRAFT BATTERY 001 080909A 42 DOES NOT OPERATE PROPERLY
4C3Z 9B246C KIT-FUEL SYSTEM SERV 001 080909B
5C3Z 9J332C TUBE ASY FUEL/LN EXT 001 080909C
3C3Z 6379BA BOLT-FLYWHEEL TO CRA 010
21630 STC FITTING ON THE HIGH PRESSURE OIL PUMP CC-42,9B246---080909A-0.8,0 80909B-4.9,080909C- 10.8 VERIFIED CRANK NO START.PERFORM EEC QUICK TEST.COD ES P2290,P2291 IN MEMORY. PERFORM ICP DATA TEST PER TSB 08-09-09.VERIFIED L OW ICP VOLTAGE WHILE CRANKING ENGINE.PERORM AIR PRESSURE CHECK AT ICP PORT AND TEST PORT OF HIGH PRESSURE OIL PUMP.VERIFIED AIR LEAK AT HIGH PRESSURE
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 1 6N04 010807 5C3Z 9942528 CA B66 70 114
AWS Claim Key: 1700548 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02488 - * Name: BANKSTON FORD OF ARLINGTON Ph: 817-4673673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2006 Doc #:376546A
Cust Comments: CUSTOMER STATES THAT THE TAILGATE EMBLEM THE PAINT IS COMING OFF
Tech Comments: 114 TAIL GATEW EMBLEM PEELING MT .5 NO OP CIDE AVL MT PER M DAVIS REPLACED TAIL GATE EMBLEM
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 1 5R02 110601 5C7Z 3600 CBA C50 42 297
AWS Claim Key: 1774760 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02488 - * Name: BANKSTON FORD OF ARLINGTON Ph: 817-4673673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-SEP-2006 Doc #:376699B
Cust Comments: CUSTOMER STATES THAT THE STERRING WHEEL HAS HOLLOW SECTION, SEE CAMP
Tech Comments: 297 3600A 0.7 INSPECTED VEH FOUND STEERING WHEEL HOLLOW REPALCED STEERING WHEEL VEH OK.
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 1 6Q06 011902 1C3Z 17906 BA B66 42 313
AWS Claim Key: 1853699 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02488 - * Name: BANKSTON FORD OF ARLINGTON Ph: 817-4673673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2006 Doc #:017279C
Cust Comments: CUSTOMER COMPLAINS OF BROWN STAINS ON CHROME OF REAR BUMPER
Tech Comments: REMOVE AND REPLACE REAR CHROME BUMPER
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 1 6A15 011803 5C3Z 2520001 DAC F13 81 313
AWS Claim Key: 1853698 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 02488 - * Name: BANKSTON FORD OF ARLINGTON Ph: 817-4673673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2006 Doc #:017279A
Cust Comments: CUSTOMER COMPLAINS OF PAINT EGDE OF TWO TONE ON LEFT REAR CABSIDE
Tech Comments: NECC TO REMOVE DECAL STRIPES AND THEN REFINISH, REPLACED STRIPES
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 10 5C02 050101 EOTZ 4A209 A K03 42 9530
AWS Claim Key: 4233966 Trx Code: 2 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 02413 - * Name: BANKSTON FORD OF GRAPEVINE Ph: 817-4813531 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2007 Doc #:487145A
Cust Comments: K03 SHUDDER FELT WHEN TAKING OFF FROM STOPS WHEN TOWING A HEAVY R.V.
Tech Comments: 9533 062304B 1.7 I PREFORMED THE TSB 062304 I INSTALLED THE SHIM I TEST DROVE AND FOUND SOME VIBRATION I INSTALED ONE MORE SHIM I TEST DROVE AND FOUND OK AT THIS TIME
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 10 5G02 040102 5C3Z 3B440 EEE H62 W6 9530
AWS Claim Key: 4233967 Trx Code: 2 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02413 - * Name: BANKSTON FORD OF GRAPEVINE Ph: 817-4813531 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2007 Doc #:487145B
Cust Comments: H62 FRONT TIRES ARE WEARING UNEVENLY.
Tech Comments: 9533 WHEEL ALIGN OUT OF SPEC CC W6 CHECKED CASTER, CAMBER & TOE. CORRECTED BOTH SIDES CASTER, CAMBER & TOE. TEST DROVE OK. FINAL READINGS ARE CAMBER L S 0.0 R S 0.1, CASTER L S 3.1 R S 3.5 & TOTAL TOE IS 0.14. TECH 2409
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 10 6N04 010802 5C3Z 16720 NA B62 42 9530
AWS Claim Key: 4233968 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02413 - * Name: BANKSTON FORD OF GRAPEVINE Ph: 817-4813531 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2007 Doc #:487145D
Cust Comments: B62 PASSENGER FRONT FENDER EMBLEM PEELING.
Tech Comments: 9533 BOTH FRONT EMBLEM PEELING VERIFIED CONCERN FOUND RIGHT FRONT FENDER EMBLEM PEELING INSPECTED DRIVERS SIDE FOUND EMBLEM STARTING TO PEEL REPLACED BOTH FRONT FENDER EMBLEMS RETESTED
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 11 1A03 031601 3C3Z 6A949 AA D50 42 12363
AWS Claim Key: 4234051 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02486 - * Name: FIVE STAR FORD Ph: 817-4988838 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2007 Doc #:367661B
Cust Comments: POWER STROKE STICKER UNDER HOOD COMING LOOSE
Tech Comments: 12392 REPLACED THE POWER STROKE STICKER UNDER HOOD, TEST DROVE...
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 11 1A02 030102 * 6051 * D50 42 12363
AWS Claim Key: 4234050 Trx Code: E84 Labor Hrs: 12.1
Dlr Cd-Sub Cd: 02486 - * Name: FIVE STAR FORD Ph: 817-4988838 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2007 Doc #:367661A
Cust Comments: CUST STS COOLANT BLOWS OUT RESIVOIR COOLANT FAN IS ON A LOT PULLING TRAILER
Tech Comments: 12392 EGR COOLER,OIL COOLER,EGR VALVE,RESIVOIR COLOR TEST DROVE AND DUPLICATED CONCERN,FOUND THE COOLANT RESIVOIR LOW AND FLUID ON FENDER AREA, I THEN PERFORMED THE TSB 07 14 05 FOR COOLANT DEGAS BOTTLE OVERFLOW CONCERNS...PRESSURE TEST COOLANT SYSTEM,FOUND NEC. TO REMOVE EGR VALVE AND INSPECT VALVE AND INTAKE FOR COOLANT,FOUND THE VALVE WASHED AND INTAKE HAD MOISTURE IN IT. I THEN
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 13 1A01 030102 6C3Z 6049 A L87 42 13280
AWS Claim Key: 4537389 Trx Code: E84 Labor Hrs: 15.5
Dlr Cd-Sub Cd: 02486 - * Name: FIVE STAR FORD Ph: 817-4988838 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-SEP-2007 Doc #:372088A
Cust Comments: CBK CUST STS COOLANT IS LEAKING OUT COOLANT RESIVOIR USUALLY WHILE PULLING A TRAILER
Tech Comments: 13344 VERFIED CONCERN,TEST DROVE,FOUND LOSING COOLANT OUT OF DEGAS BOTTLE PER TSB 07145.NECESSARY TO REPLACED HEADGASKETS AND INSPECT HEADS FOR WAR PAGE.DISASSEMBLED ENGINE TO REMOVE HEADS FROM BLOCK.CLEANED HEADS AND BLOCK SURFACES,INSPEC TED FOR WARPAGE,FOUND DISTORTED SEALING SURFACE ON CYL 3 AND 5,NECESSARY TO REPLACED HEAD.EVER YTHING ELSE OK.REPLACED HEADGASKETS,INSTALLED
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 23 2E04 030408 4C3Z 9B246 C D50 42 21626
AWS Claim Key: 6982226 Trx Code: E84 Labor Hrs: 16.5
Dlr Cd-Sub Cd: 02413 - * Name: BANKSTON FORD OF GRAPEVINE Ph: 817-4813531 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2008 Doc #:515801C
Cust Comments: D50. CUST STATES TRUCK WONT START
Tech Comments: 21630 STC FITTING ON THE HIGH PRESSURE OIL PUMP CC 42,9B246 080909A 0.8,080909B 4.9,080909C 10.8 VERIFIED CRANK NO START.PERFORM EEC QUICK TEST.CODES P2290,P2291 IN MEMORY. PERFORM ICP DATA TEST PER TSB 08 09 09.VERIFIED LOW ICP VOLTAGE WHILE CRANKING ENGINE.PERORM AIR PRESSURE CHECK AT ICP PORT AND TEST PORT OF HIGH PRESSURE OIL PUMP.VERIFIED AIR LEAK AT HIGH PRESSURE OIL
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 23 1F05 030306 4C3Z 8A616 AA D50 42 21626
AWS Claim Key: 6982225 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 02413 - * Name: BANKSTON FORD OF GRAPEVINE Ph: 817-4813531 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2008 Doc #:515801B
Cust Comments: D50. CUST STATES THE ENGINE FAN RUNS ALL THE TIME BELOW 40 MPH
Tech Comments: 21634 ELECTRIC FAN CLUTCH CC 42,8A616,12B599 ROAD TEST,VERIFIED CONCERN.PERFORM EEC QUICK TEST.FOUND CODE P0458(ELECTRIC FAN CLUTCH OPERATION)ALSO FICM CODE P0267(CYL #3 CIRCUIT LOW)MONITOR FAN SPEED WHILE DRIVING.NOTICED UNCOMMANDED FAN OPERATION.REPLACED ELECTRIC FAN CLUTCH & FUEL INJECTOR CONTROL MODULE.RETEST,VERIFIED REPAIR.
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 23 6R01 012001 6C3Z 2660045 CC S26 42 21626
AWS Claim Key: 6982224 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02413 - * Name: BANKSTON FORD OF GRAPEVINE Ph: 817-4813531 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2008 Doc #:515801A
Cust Comments: S26. CUST STATES THE DRIVERS REAR SEATBELT WONT LATCH FROM TIME TO TIME
Tech Comments: 21626 REAR SEAT BELT BUCKLE FAILED CC 42 VERIFIED CUST CONCERN.REPLACED LEFT REAR SEAT BELT BUCKLE ASSY.
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 31 2I04 030709 4C3Z 12A342 AA D13 28 25688
AWS Claim Key: 7925613 Trx Code: S07 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 02486 - * Name: FIVE STAR FORD Ph: 817-4988838 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2009 Doc #:425661A
Cust Comments: CUSTOMER STATES THE CHECK ENGINE LIGHT IS ON RUNS ROUGH AT COLD START WHEN COLD
Tech Comments: 25688 GLOW PLUG NO.4 AND PCM REFLASH CC_28.VERIFIED CONCERN.PERFORMED DIESEL DIAGNOS IS.PERFORMED VISUAL INSPECTIONS AIR,FUEL,OIL PA SSED.PERFORMED KOEO ON DEMAND SELF TEST P0674. PINPOINT TEST AF.CHECKED CHARGING SYSTEM 13.5V PASSED.REFLASHED PCM,FICM,TCM TO LATEST CALIBRA TION PER TSB 08 26 03.REPLACED NO.4 GLOW PLUG D UE TO OPEN 26OHMS RESISTANCE.NECESSARY TO R&R D EGAS BOTTLE AND
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 31 7A01 140101 BXT 65 750 C25 46 25688
AWS Claim Key: 7932847 Trx Code: E83 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 02486 - * Name: FIVE STAR FORD Ph: 817-4988838 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2009 Doc #:425661C
Cust Comments: CUSTOMER STATES THE ENGINE CRANKS SLOW WHEN SITS ALL DAY OR FOR FEW DAYS
Tech Comments: 25702 11LJS XJBS0 000 ACES XE2EK, 11NJT 1JTS0 81W VERIFIED CONCERN, BATTERY TEST BOTH BATTERYS FAILED. REPLACE BATTERYS, CHECKED CHARGING SYSTEM ALTERNATOR ONLY CHARGING AT 12.2V AND 21 AMPS AND DIODE PATTERN FAILED. REPLACED ALTERNATOR AND VERIFIED REPAIRS.
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 31 1D01 031001 3C3Z 6700 BA L65 D8 25688
AWS Claim Key: 7925614 Trx Code: E84 Labor Hrs: 7.7
Dlr Cd-Sub Cd: 02486 - * Name: FIVE STAR FORD Ph: 817-4988838 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2009 Doc #:425661B
Cust Comments: CUSTOMER STATES THE ENGINE LEAKS OIL
Tech Comments: 25702 REAR COVER GASKET,FRONT CRANK SEAL CC_D8.VERIFIED CONCERN.PERFORMED OIL DYE LEAK TEST.INSTALLED OIL DYE AND PRESSURE WASHED ENGI NE.ROADTEST.INSPECT WITH BLACKLIGHT.REPLACED FR ONT CRANK SEAL,GEROTOR HOUSING GASKET AND OIL PRESSURE REGULATOR DUE TO LEAKING OIL.RESEALED REAR ENGINE COVER AND REPLACED REAR MAIN SEAL D UE TO LEAKING OIL ALSO.NECESSARY TO R&R 4X4 AUT
1FTWW33P56EC97216 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-FEB-2006 05-SEP-2006 152019 USA 31 6A15 011803 5C3Z 2520000 DAC F15 81 25688
AWS Claim Key: 7925615 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 02486 - * Name: FIVE STAR FORD Ph: 817-4988838 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2009 Doc #:425661E
Cust Comments: CUSTOMER STATES THE DRIVERS SIDE PINSTRIPES ARE PEELING
Tech Comments: 25702 PIN STRIPES REPLACED BY OUTSIDE LABOR
4play is offline
post #3 of 3 (permalink) Old 04-04-2009, 05:47 PM Thread Starter
whanner's Avatar
Thank you...look at all the crap I've gone through with this truck! year model is 06-09
06' F350
whanner is offline
oasis report please joeseppy Ford Oasis requests 1 06-22-2007 01:36 AM
Thank you for Oasis report on this VIN GeoDad Ford Oasis requests 1 06-07-2007 03:37 AM
Oasis report please ianblaster Ford Oasis requests 1 06-07-2007 03:35 AM
oasis report dg250 Ford Oasis requests 5 08-24-2006 10:49 AM
oasis report please stairwayz Ford Oasis requests 2 08-23-2006 09:07 AM
