I finally found 2 trucks just like the one I had.Oasis pleasee - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lee boy, this thread has received 10 replies and been viewed 1362 times.
post #1 of 11 (permalink) Old 04-07-2009, 05:43 AM Thread Starter
lee boy's Avatar
first truck 1FTSW21PX5ED01660
SECOND TRUCK 1FTSW21P97EA10442
Thank you guys for this info. See , I just found these two trucks just like the truck I had that got hit and totalled . After three years now of searching everywhere for a truck just like the one I had I am very happy and cant wait untill I get one of these two. Cant wait to start modding it again.
R.I.P My First Diesel Hit by lady
running red light:Just like the avatar pic but mine was red(
4/4/06-3/28/08:: Totaled frame twist
RED 2006 Ford F250 powerstroke Lariat crew cab sb
7inch lift
4 inch straight pipe, no cat or muffler to 6inch tip
Chrome accufab intake elbow
22inch kmc with 37 inch kumho tires
Amp powersteps
Zoodad mod
HOPEFULLY SOON: Injectors, headstuds,sct:
Dads truck: 1997 F-250 4x4Black crew cab short bed 7.5L 460 engine:
6 inch lift on 35's
Fox shocks
K&N Fipk filter kit
BBK throtle body
Helix power spacer, 50 series Flow Masters:3inch dual exhaust piping to 5inch tips
My New Truck2005 F-250 4x4 powerstroke Crew cab short bed Charcoal gray metalic all stock , but not for long
Zoodad mod
4inch Turbo Back straight pipe to 5 inch Chrome Tip , exiting in front of rear right tire
Polished intake elbow
Sct Livewire
S&B Cold Air Intake
3 gauge A Pillar with Phantom II"s / PYRO/ BOOST/TRANS
Viper Alarm Remote Start/ Turbo Timer/ Window Module setup
5% tint all around
Dynoed at 425Hp 850 torque
03 Turbo VEEEEERy LOud
Cobra Cb Radio
The perfect Sleeper Looking truck/ Looks completely stock from the outside except for the turbo back exhaust, and when I get challenge they quickly find out it's not stock haha
lee boy is offline
post #2 of 11 (permalink) Old 04-07-2009, 06:47 PM
4play's Avatar
1st one...
OASIS RESULT:
1FTSW21PX5ED01660
USA
EN
04/07/2009
14:46:40
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710D0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/08/2005 BUILD DATE
04/05/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0701 - USA 2005 NEW 72/75,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD DISAPPEARING DEDUCTIBLE
OWNER NAME: DENNIS PARAS
OPTIONS: DIS.,DED
EXPIRATION DATE: 07/08/2011
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07737
ESP CONTRACT START DATE: 07/08/2005
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
0712 - USA 2005 NEW 60/60,000 PREMIUM MAINT(M&W)6.0L DSL 7.5K
STANDARD DEDUCTIBLE: 0 USD
OPTIONS:
EXPIRATION DATE: 07/08/2010
DISTANCE: 61,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
WARRANTY REPAIR HISTORY
10/15/2008
DEALER: Serramonte Ford, Inc.
WARRANTY CLAIM NUMBER: 041030 ODOMETER: 029395M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9G489AARM KIT TRBCH CTR HSG RO 001 081613F 42 DOES NOT OPERATE PROPERLY
XL 2 MOTORCRAFT BATTERY 001
W302677 001
W302676 001
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001
6K682 TURBO CHG-EXH DRIVE 000
TEST DROVE THE VEHICLE. IDS HOOK UP. EEC SELF TEST. DTC P0299. PID DATA MON ITOR. IDS TURBO BOOST TEST. CHECKED OASIS. AS PER TSB 08.16.13. REMOVED AN D DIASSEMBLED THE TURBO FOR INSPECTION. FOUND THE TURBO IS CORRODED. REPLACE D THE CENTER HOUSING AND CLEANED THE TURBO. REASSEMBLED AND REINSTALLED TH E TURBO. TEST DROVE THE VEHICLE AND RERAN THE SELF TEST TO VERIFY THE REPAIR
08/15/2008
WARRANTY CLAIM NUMBER: 036837 ODOMETER: 027592M
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 070504A 42 DOES NOT OPERATE PROPERLY
IDS HOOK UP. EEC SELF TEST. DTC P0308. POWER BALANCE TEST. REPROGRAMED THE FICM AS PER TSB 07- 5-4. RETESTED OK
08/15/2008
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9275BA GAUGE ASY FUEL TANK 001 12650D81 42 DOES NOT OPERATE PROPERLY
000 12650D
000 12650D45
000 9275D
000 9002A
IDS HOOK UP. INTRUMENT CLUSTER MODULE SELF TEST AND PID DATA MONITOR. TEST DROVE THE VEHICLE TO VERIFY THE CONCERN. INSPECTED THE WIRING AND CONNECTO RS. REMOVED THE FUEL TANK FOR ACCESS AND REPLACED THE BAD FUEL LEVEL SENDER ASSEMBLY. RECHECKED OK
08/15/2008
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6731AA ELEMENT ASY OIL FILT 001 MB30 82 FREIGHT/POSTAGE/MAINTENANCE
XO 15W40QSD 015 MULTI
3C3Z 9N184CA WATER-FUEL SEP ELEM 001
VC 7B 002
XT 6QSP 016
2W4Z 7B155G FLTR&HD ASY TRNS OIL 001
MAINT VEHICLE MAINTENANCE 000
FRONT BKS 10MM REAR BKS 8MM TOPPED OFF FLUIDS TIRE ROTATION COMPLETED 15 QT S FL OIL FILTER REPLACED FUEL FILTERS COOLING SYSTEM FLUSH COMPLETED.17 QT S MERCON SP FLUID TRANS SERVICE COMPLETED
1FTSW21PX5ED01660 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-APR-2005 08-JUL-2005 172024 USA 8 * * * * * * * 5695
AWS Claim Key: 3797280 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-FEB-2006 Doc #:059782D
Cust Comments: RECALL 05B32
Tech Comments: INSTALL COOLANT TANK STICKER DECAL AS REQUIRED ED PER SAFETY RECALL # 05B32 RECHECKED FOR PROPER OPER..O.K.
AWS Claim Key: 3797279 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-FEB-2006 Doc #:059782C
Cust Comments: RECALL 05E16 REPRGRAM
Tech Comments: REPROGRAM P.C.M FOR EMISSIONS UPDATES AS REQUIRED PRE SAFETY RECALL # 05E16 ROAD TEST..O.K.
1FTSW21PX5ED01660 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-APR-2005 08-JUL-2005 172024 USA 8 6Y05 000001 * MAINT * A99 82 5695
AWS Claim Key: 3797278 Trx Code: 0712S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-FEB-2006 Doc #:059782A
Cust Comments: COMPLIMENTARY 5K OIL AND FILTER CHANGE.
Tech Comments: CHANGE OIL FILTER AND 15QT DIESEL OIL TIRES PRESSURE ARE 75PSI TOP OFF ALL FLUIDS
1FTSW21PX5ED01660 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-APR-2005 08-JUL-2005 172024 USA 19 6Y05 000001 * MAINT * A99 82 17159
AWS Claim Key: 6988910 Trx Code: 0712S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2007 Doc #:083874A
Cust Comments: 15K QCM DIESEL PREMIUM MAINT SERVICE
Tech Comments: OIL AND FITLER CHANGED 15 QTS 15W 40 ADDED BRAKES INSPECTED TIRES ROTATED FLUIDS CHECKED AND TOPPED OFF BELTS AND HOSES INSPECTED
1FTSW21PX5ED01660 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-APR-2005 08-JUL-2005 172024 USA 31 6Y05 000001 * MAINT * A99 82 25869
AWS Claim Key: 9262173 Trx Code: 0712S Labor Hrs: 1.5
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2008 Doc #:020036A
Cust Comments: PERFORM 25K PER QCM
Tech Comments: DRAIN AND FILL WITH 15 QUARTS 15W40 OIL ROTATE TIRES. CHECK BRAKES. FRONT BRAKES 8MM. REAR BRAKES 7MM. TOP OFF FLUIDS.
1FTSW21PX5ED01660 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-APR-2005 08-JUL-2005 172024 USA 38 2E03 03XXXX * 9E527 * E29 42 27592
AWS Claim Key: 10291970 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2008 Doc #:036837A
Cust Comments: CK ENGINE LIGHT DIOGNOSIS:ROADTEST TO VERIFY CONCERN USING ANALYZER. RUN PINPOINT TEST AS NECC. TO FIND FAILED PARTS AND OR CONCERN. INCLUDES UP TO 1.5 OF TESTING.
Tech Comments: IDS HOOK UP. EEC SELF TEST. DTC P0308. POWER BALANCE TEST. REPROGRAMED THE FICM AS PER TSB 07 5 4. RETESTED OK
1FTSW21PX5ED01660 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-APR-2005 08-JUL-2005 172024 USA 38 6Y05 000001 * MAINT * A99 82 27592
AWS Claim Key: 10286888 Trx Code: 0712S Labor Hrs: 2.4
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2008 Doc #:036837C
Cust Comments: PREMIUM 30K DIESEL WARRANTY
Tech Comments: FRONT BKS 10MM REAR BKS 8MM TOPPED OFF FLUIDS TIRE ROTATION COMPLETED 15 QTS FL OIL FILTER REPLACED FUEL FILTERS COOLING SYSTEM FLUSH COMPLETED.17 QTS MERCON SP FLUID TRANS SERVICE COMPLETED
1FTSW21PX5ED01660 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-APR-2005 08-JUL-2005 172024 USA 38 2E06 100101 5C3Z 9275 BA E40 42 27592
AWS Claim Key: 10286887 Trx Code: 0701D Labor Hrs: 3
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2008 Doc #:036837B
Cust Comments: CUSTOMER STATES AT TIMES THE FUEL GUAGE GIVES FALSE READINGSS..GOES TO 1 2 WAY OR EMPTY WHEN HAS FUEL..HAS 3 4 TANK AT THIS TIME...
Tech Comments: IDS HOOK UP. INTRUMENT CLUSTER MODULE SELF TEST AND PID DATA MONITOR. TEST DROVE THE VEHICLE TO VERIFY THE CONCERN. INSPECTED THE WIRING AND CONNECTORS. REMOVED THE FUEL TANK FOR ACCESS AND REPLACED THE BAD FUEL LEVEL SENDER ASSEMBLY. RECHECKED OK
1FTSW21PX5ED01660 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-APR-2005 08-JUL-2005 172024 USA 40 2H01 0300XX * 6K682 * E29 42 29395
AWS Claim Key: 10502929 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 07737 - * Name: SERRAMONTE FORD, INC. Ph: 650-7557007 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2008 Doc #:041030A
Tech Comments: TEST DROVE THE VEHICLE. IDS HOOK UP. EEC SELF TEST. DTC P0299. PID DATA MONITOR. IDS TURBO BOOST TEST. CHECKED OASIS. AS PER TSB 08.16.13. REMOVED AND DIASSEMBLED THE TURBO FOR INSPECTION. FOUND THE TURBO IS CORRODED. REPLACED THE CENTER HOUSING AND CLEANED THE TURBO. REASSEMBLED AND REINSTALLED THE TURBO. TEST DROVE THE VEHICLE AND RERAN THE SELF TEST TO VERIFY THE REPAIR. OPS
4play is offline
post #3 of 11 (permalink) Old 04-07-2009, 06:54 PM
4play's Avatar
recheck vin number on second one
4play is offline
post #4 of 11 (permalink) Old 04-07-2009, 07:00 PM Thread Starter
lee boy's Avatar
Thanks man for this info. I think I might end up getting the other one , which is the 2007 if the oasis checks out good. Can you please send me the oasis on the 2007 as soon as you have time. Im going to go look at it thursday and I would like to see the results before I go and look at it. Thank you again. Cant wait to finally get another6L. I miss my 6L alot.
7inch lift
Amp powersteps
Zoodad mod
6 inch lift on 35's
Fox shocks
K&N Fipk filter kit
BBK throtle body
Zoodad mod
Sct Livewire
S&B Cold Air Intake
5% tint all around
Cobra Cb Radio
lee boy is offline
post #5 of 11 (permalink) Old 04-07-2009, 07:09 PM Thread Starter
lee boy's Avatar
I rechecked on the second one 2007 F250. The VIN is 1FTSW21P97EA10442. Thanks again 4 play.
7inch lift
Amp powersteps
Zoodad mod
6 inch lift on 35's
Fox shocks
K&N Fipk filter kit
BBK throtle body
Zoodad mod
Sct Livewire
S&B Cold Air Intake
5% tint all around
Cobra Cb Radio
lee boy is offline
post #6 of 11 (permalink) Old 04-07-2009, 07:09 PM
4play's Avatar
2nd one...
OASIS RESULT:
1FTSW21P97EA10442
USA
EN
04/07/2009
15:08:51
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2007 F-SERIES BODY STYLE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
6F710H0A
ARN MESSAGES
WARRANTY START DATE
12/24/2006 BUILD DATE
05/21/2006 SALE MILEAGE
EXTENDED COVERAGES
0968 - USA 2009 72/100,000 CPO POWERTRAINCARE WTY W/ROADSIDE
OWNER NAME: CERTIFIED CUSTOMER
OPTIONS:
EXPIRATION DATE: 12/24/2012
DISTANCE: 100,000
RENTAL: 30 UP TO 5 DAYS
TOWING: 0
CONTRACT SOLD BY: USA 09947
ESP CONTRACT START DATE: 12/24/2006
0968 - USA 2009 NEW 72/100000 PREMIUMCARE W/ROADSIDE
OWNER NAME: JOHN STEVENS
OPTIONS:
DISTANCE: 100,000
RENTAL: 30 UP TO 10 DAYS
TOWING: 0 USD
and no warranty history on this one.
4play is offline
post #7 of 11 (permalink) Old 04-07-2009, 07:28 PM Thread Starter
lee boy's Avatar
The second truck got sold yesterday. What do you think about the first one. Would you guys buy it?
7inch lift
Amp powersteps
Zoodad mod
6 inch lift on 35's
Fox shocks
K&N Fipk filter kit
BBK throtle body
Zoodad mod
Sct Livewire
S&B Cold Air Intake
5% tint all around
Cobra Cb Radio
lee boy is offline
post #8 of 11 (permalink) Old 04-13-2009, 03:37 AM
Powered By Ford
FordRacing200's Avatar
I wouldn't, sounds like a POS. The 2nd one looked good, too bad it sold.
FordRacing200 is offline
post #9 of 11 (permalink) Old 04-15-2009, 04:57 AM Thread Starter
lee boy's Avatar
the one your are talking about ford racing just had the turbo cleaned , because it was rusted. I dont think it has more problems, or unless you saw something I didnt. What do you think about it ford racing?
7inch lift
Amp powersteps
Zoodad mod
6 inch lift on 35's
Fox shocks
K&N Fipk filter kit
BBK throtle body
Zoodad mod
Sct Livewire
S&B Cold Air Intake
5% tint all around
Cobra Cb Radio
lee boy is offline
post #10 of 11 (permalink) Old 04-15-2009, 05:16 AM
********* and Mafia #90
Bcarriveau's Avatar
IN my eyes the first one looks just fine, had the turbo cleaned, new fuel lever sensor, coolant sticker and a updated pcm ficm. But i dont ever want to be the deciding factor on someone buying a truck
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
finally found the flux capaciter!!! swampdonky The Parking Lot 7 01-03-2009 04:24 AM
Found this out about dodge trucks imported_99powerstroke The Parking Lot 11 06-07-2007 02:16 AM
Finally Found It!! Billysgoat The Parking Lot 8 01-04-2006 08:41 PM
finally found a one... dieseldummy Duramax 2004.5-2005(LLY) 9 10-07-2005 06:17 AM
Finally Found A Pic Of DOLLY....... bigdraft The Parking Lot 10 09-24-2005 08:17 PM
