oasis request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JPscustoms, this thread has received 1 replies and been viewed 463 times.
post #1 of 2 (permalink) Old 04-07-2009, 09:29 PM Thread Starter
JPscustoms's Avatar
1ftsw21p25ea34725, thanks
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #2 of 2 (permalink) Old 04-08-2009, 12:25 AM
4play's Avatar
OASIS RESULT:
1FTSW21P25EA34725
USA
EN
04/07/2009
20:24:50
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/10/2004 BUILD DATE
08/11/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 1 6J08 011404 2C3Z 3626605 AAD L08 01 5192
AWS Claim Key: 134300 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2004 Doc #:038528A
Cust Comments: CHECK AND ADVISE ON DRIVERS REAR DOOR OUTSIDE HANDLE IS BROKEN
Tech Comments: 25 REMOVE REAR DOOR TRIM PANEL AND REPLACE OUTSIDEDOOR HANDLE
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 2 2E06 030008 4C3Z 9E527 AA D02 42 14971
AWS Claim Key: 152118 Trx Code: S07 Labor Hrs: 12.7
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2004 Doc #:039035A
Cust Comments: CHECK AND ADVISE ON ENGINE TURNS OVER BUT DOES NOT START
Tech Comments: 27 CHECK FOR NO START ENGINE TRUNS OVER BUT DOES NOT START RUN DIAG AS PER DIESEL DIAG SHEET SEE SHEET P2269 P2291 CHECK FOR SSM AND TSBS INSPECT ENGINE FOUND ICP NOT GOOD CHECK BASE ENGINE OIL PRESSURE WAS OK REMOVE IPR AND INSPECT AND CHECK TO SEE IPR CAN TURN TEST LITE ON AND OFF OK CALLED HOT LINE WAS TOLD TO REPLACE HIGH OIL PRESSURE PUMP DUE TO METAL IN OIL REPLACE PUMP STILL NO START RETEST
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 2 1B01 030201 3C3Z 6619 EA L65 D8 15242
AWS Claim Key: 152119 Trx Code: E84 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2004 Doc #:039151A
Cust Comments: CHECK AND ADVISE ON OIL LEAK
Tech Comments: 25 AFTER GETTING ENGINE TO RUN SEE REPAIR ORDER NUMBER 39035 DROVE TRUCK FOR 50 MILES AND CHECK OVER ENGINE FOUND OIL LEAKING ADD OIL DYE AND CHECK FOR LEAK FOUND LEAK AT REUSEABLE INTAKE MANIFOLD GASKET LEAKING REMOVE TURBO AND INTAKE MANIFOLD AND REPLACE REUSEABLE GASKET REASSEMBLE AND ROAD TEST AND RECHECK NO LEAKS
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 9 1H03 030008 5C3Z 9F452 AA D42 42 50327
AWS Claim Key: 1014746 Trx Code: S07 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2005 Doc #:041471A
Cust Comments: CHECK AND ADVISE ON LACK OF POWER GOING UP HILL
Tech Comments: CHECK AND ADVISE ON LACK OF POWER AND BALCK SMO KE WHEN GOING UP HILL TEST DRIVE TO VERIFY CONCERN EEC TEST FOUND NO CODES PERFORM DIAG FOR CONCERN PRESENT PERFORM 6.0 DIESEL ENGINE PERFORMANCE DIAG SHEE T TESTS 1 THROUGH 15 FOUND EGR VALVE NOT OPENING COMPLETELY REPLACE EGR VALVE AND TEST DRIVE TO VERIFY REPA IR RETEST FOUND NO CODES REPROGRAM PCM TO MOST CURRENT CAL
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 16 1C03 030008 5C3Z 6079 B E23 42 87256
AWS Claim Key: 2917304 Trx Code: E72 Labor Hrs: 15.4
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2005 Doc #:04452202
Cust Comments: CHECK AND ADVISE ENGINE USING COOLANT NO EXTERNAL LEAKS
Tech Comments: FOUND HEAD GASKETS LEAKING
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 16 2E06 030008 4C3Z 9E527 AA D50 42 87256
AWS Claim Key: 2917303 Trx Code: E72 Labor Hrs: 7.4
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2005 Doc #:04452201
Cust Comments: CHECK AND ADVISE ON ENGINE RUNS ROUGH
Tech Comments: FOUND 2 INJECTORS FAILING
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 20 * * * * * * * 102917
AWS Claim Key: 4487124 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2006 Doc #:04581602
Cust Comments: RECALL 05B32
Tech Comments: RECALL 05B32
AWS Claim Key: 4470398 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2006 Doc #:04588801
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 25 * * * * * * * 102917
AWS Claim Key: 5960948 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2006 Doc #:04581601
Cust Comments: RECALL 05E15
Tech Comments: RECALL 05E15
1FTSW21P25EA34725 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2004 10-SEP-2004 141111 USA 39 6Y20 000000 * TAP5 * A99 82 202068
AWS Claim Key: 8978933 Trx Code: TAP5 Labor Hrs: 0
Dlr Cd-Sub Cd: 06162 - * Name: ELKHORN MOTORS INC Ph: 262-7232131 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:09-NOV-2007 Doc #:05103601
Cust Comments: 3 DAYS OF TAP VEHICLE PROVIDED RETAIL ORDER 51011
Tech Comments: 3 DAYS OF TAP VEHICLE PROVIDED RETAIL RO 51011
4play is offline
Oasis Request PSD Trav Ford Oasis requests 4 01-15-2008 09:19 PM
oasis request tman945 Ford Oasis requests 1 01-06-2008 12:56 AM
OASIS Request midnight2004 Ford Oasis requests 1 10-23-2007 01:21 AM
OASIS request Mustang50 Ford Oasis requests 1 07-22-2007 06:33 PM
OASIS Request, Please colorado_okie Ford Oasis requests 1 07-17-2006 12:27 AM
