oasis please? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mxracer201, this thread has received 1 replies and been viewed 548 times.
post #1 of 2 (permalink) Old 04-07-2009, 10:58 PM Thread Starter
oasis please?
vin: 1FTSW31P54EE03422
thanks in advance
mxracer201 is offline
post #2 of 2 (permalink) Old 04-08-2009, 12:28 AM
4play's Avatar
OASIS RESULT:
1FTSW31P54EE03422
USA
EN
04/07/2009
20:26:33
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/30/2004 BUILD DATE
07/01/2004 SALE MILEAGE
00011
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/01/2009
DEALER: Downs Ford Lincoln-Mercury
WARRANTY CLAIM NUMBER: 024994 ODOMETER: 091319M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6840AA GASKET-OIL FILLER AD 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001 MTCLEANOIL
OSP 001 MT6A831
XO 15W40QSD 001
6A831 GSKT-OIL FLTR ELEM S 000
ADD DYE CK FOUND LEAKAGE FROM LWR OIL FILTER -FUEL FILTER HOUSING, MTIME NO PUB TIME, R&R NEC HARDWARE AND OIL FILTER AND FUEL LINES AND REMOVED HOUSING , O RING SPLIT. REPL O RING AND OIL FILTER CAP O RING CLEANED ENG AND UN DER CARRIAGE OF OIL, ROAD TEST OK
04/01/2009
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F 41 STICKS/BINDS/GRABS
000 6005F1
000 12650D30
000 6005F39
000 6005F45
000 MTINTAKE
000 6005F1X1
CK, VERIFIED CONCERN, CK EEC SYSTEM NO CODES, PERF NEC PERF TEST AND PINPOI NT TESTS FOUND EGR VALVE STICKS, MTIME CLEANE D CARBON OUT OF INTAKE MANIFOLD EGR PORTS, INST NEW VALVE CLEARED CODES ROAD TEST OK
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 8 2G05 031405 * RECAL * D13 42 25146
AWS Claim Key: 4409818 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 03688 - * Name: LUCAS FORD LINCOLN MERCURY, INC. Ph: 631-7659200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2005 Doc #:069143A
Cust Comments: CUSTOMER STATES LOSES POWER ON HILLS
Tech Comments: F EEC TEST, PIN POINT, NGS TESTED, REPROGRAM PCM
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 9 1H03 030008 4C3Z 9F452 A E29 42 26629
AWS Claim Key: 4722654 Trx Code: E84 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 03688 - * Name: LUCAS FORD LINCOLN MERCURY, INC. Ph: 631-7659200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:06-APR-2005 Doc #:069519A
Cust Comments: CHECK CAUSE OF CHECK ENGINE LIGHT COMES ON AT TIMES
Tech Comments: EEC TEST, PIN POINT, NGS TESTED, TRACE AND REPAIR WIRING REPLACE HEGO SENSOR
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 12 1F05 030306 4C3Z 8A616 AA N12 14 32522
AWS Claim Key: 7023553 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03688 - * Name: LUCAS FORD LINCOLN MERCURY, INC. Ph: 631-7659200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2005 Doc #:071964A
Cust Comments: CHECK CAUSE OF THE COOLING FAN NOISE
Tech Comments: REPLACE COOLING FAN CLUTCH
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 20 * * * * * * * 48632
AWS Claim Key: 8654651 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03688 - * Name: LUCAS FORD LINCOLN MERCURY, INC. Ph: 631-7659200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2006 Doc #:076420B
Cust Comments: 59B01 CALCALIBRATION
Tech Comments: PERFORM RECALL
AWS Claim Key: 8783929 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03688 - * Name: LUCAS FORD LINCOLN MERCURY, INC. Ph: 631-7659200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2006 Doc #:076420A
Cust Comments: EXHAUST PRESSURE SENSOR RECALL
Tech Comments: PERFORM RECALL AND REPLACE EGR VALVE
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 20 1H03 030008 4C3Z 9F452 A D21 42 48632
AWS Claim Key: 8993702 Trx Code: P05 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03688 - * Name: LUCAS FORD LINCOLN MERCURY, INC. Ph: 631-7659200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2006 Doc #:076420D
Tech Comments: REPLACE EGR VALVE
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 38 1A01 030102 6C3Z 6049 C E23 31 69890
AWS Claim Key: 12287138 Trx Code: E72 Labor Hrs: 17.2
Dlr Cd-Sub Cd: 03688 - * Name: LUCAS FORD LINCOLN MERCURY, INC. Ph: 631-7659200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:05-SEP-2007 Doc #:084329A
Cust Comments: OWNER STATES WATER LEAKING ENGINE SIDE
Tech Comments: VERIFY CONCERN, PRESSURE TESTED COOLING SYSTEM, FOUND LEAK FROM HEAD GASKETS, REMOVE HEADS AND FOUND CRACKS REPLACE HEADS AND GASKETS
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 40 2G01 03XXXX 4C3Z 12B599 AARM D02 42 81584
AWS Claim Key: 12321705 Trx Code: E72 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 03688 - * Name: LUCAS FORD LINCOLN MERCURY, INC. Ph: 631-7659200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2007 Doc #:088267A
Cust Comments: OWNER STATES NO START
Tech Comments: VERIFY CONCERN, EEC TESTED REPLACE MODULE
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 57 1B02 03XXXX * 6A831 * L65 D8 91319
AWS Claim Key: 13120731 Trx Code: E72 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 20681 - * Name: DOWNS FORD LINCOLN-MERCURY Ph: 732-3492240 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:01-APR-2009 Doc #:02499451
Cust Comments: C S DEISEL IS LEAKING OIL
Tech Comments: ADD DYE CK FOUND LEAKAGE FROM LWR OIL FILTER FUEL FILTER HOUSING, MTIME NO PUB TIME, R&R NEC HARDWARE AND OIL FILTER AND FUEL LINES AND REMOVED HOUSING, O RING SPLIT. REPL O RING AND OIL FILTER CAP O RING CLEANED ENG AND UNDER CARRIAGE OF OIL, ROAD TEST OK
1FTSW31P54EE03422 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 01-JUL-2004 30-JUL-2004 113485 USA 57 1H03 030008 4C3Z 9F452 A D42 41 91319
AWS Claim Key: 13120732 Trx Code: E72 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 20681 - * Name: DOWNS FORD LINCOLN-MERCURY Ph: 732-3492240 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:01-APR-2009 Doc #:02499452
Cust Comments: C S SMOKES AT TIMES & SEEMS TO BE LACKING POWER
Tech Comments: CK, VERIFIED CONCERN, CK EEC SYSTEM NO CODES, PERF NEC PERF TEST AND PINPOINT TESTS FOUND EGR VALVE STICKS, MTIME CLEANED CARBON OUT OF INTAKE MANIFOLD EGR PORTS, INST NEW VALVE CLEARED CODES ROAD TEST OK
4play is offline
