Can I get an Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BAF250, this thread has received 1 replies and been viewed 638 times.
post #1 of 2 (permalink) Old 04-08-2009, 06:27 PM Thread Starter
1FTSW21P05EA82644
Thank You in advance for your help!
05 F250 CC / 4x4 / 6.0 / CC / 20"x 8.5" / Toyo / 4" Pro FLo / AM GS Pyro / Bilstein shocks
SOLD F250 SD / PSD / SWB / CC / 4x4 / Silver / Med.Flint / TT Mirrors / RH Bullnose / Dipricol gauges / 35" BFG A/Ts / Bilstein shocks / Spray Liner / Billet grille / Edge 2" Mini Spring Pack / clearance lights / MBRP / XM Radio / 24" wipers/ PC Xtream 8085
BAF250 is offline
post #2 of 2 (permalink) Old 04-09-2009, 02:33 PM
4play's Avatar
OASIS RESULT:
1FTSW21P05EA82644
USA
EN
04/09/2009
10:32:16
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/06/2004 BUILD DATE
10/06/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/10/2009
DEALER: Phil Long Ford of Chapel Hills
WARRANTY CLAIM NUMBER: 535090 ODOMETER: 041532M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6D083AA GASKET-RR COVER 001 6007D 30 CHAFED,EXCESSIVE WEAR,FRAYED
3C3Z 6701B CRANKSHAFT REAR SEAL 001 6083A
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6731A
XO 10W30DSD 015
3C3Z 6766CA CAP ASY OIL FILLER 001
41532 6D083 D8 VERIFIED CONCERN, PERFORMED OIL LEAK DIAG, BLACKLIGHT TEST, FOUND REAR ENGINE COVER LEAKING. REMOVED TRANSMISSION PER ACCESS. REPLACED REAR ENGINE COVER GASKET AND REAR MAIN SEAL(RELATED). CHANGED OIL AND FILT ER. REPLACED FILTER CAP, STRIPPED. ROAD TEST VEHICLE ALL OK.
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 2 3B01 070201 * 7A095 * L72 42 2762
AWS Claim Key: 236655 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:24-DEC-2004 Doc #:54669101
Cust Comments: STATES TRANS COOLER LINES LEAKING UNDER FRONT END
Tech Comments: INPSECT, ADD DYE AND PINPOINT LEAK TO CLAMPS ON COOLER LINES, REPLACE LINES AND RETEST T
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 6 5V09 120307 4C3Z 2A451 BA C19 42 6123
AWS Claim Key: 735309 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2005 Doc #:56376101
Cust Comments: CHECK CLIMATE CONTROL ONLY BLOWS AIR OUT OF DEFROST VENTS
Tech Comments: TEST CIRCUITS, TEST VAC AND PINPOINT TEST AND REPLACE VAC PUMP ADN RETEST
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 6 2G01 031401 5C3Z 12A650 KYC D42 42 6123
AWS Claim Key: 735308 Trx Code: S07 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2005 Doc #:56376102
Cust Comments: CHECK FOR ANY UPDATES HE IS STILL GETTING ONLY 10.7 MPG ON MOSTLY HIGHWAY MILES
Tech Comments: TEST EEC P0606 P0695 PRESENT, PERFORM DIESEL DIAG AND MONITOR PIDS AND CALL HOTLIEN, REPLACE PCM AND REPROGRAM AND RETEST
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 7 5O01 110201 5C3Z 3504 AA H22 42 6366
AWS Claim Key: 1118058 Trx Code: 2 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2005 Doc #:56928301
Cust Comments: CHECK POWER STEERING SEEMS TO BE CATCHING WHEN TURNING
Tech Comments: ISNEPCT, CONFIRM, CALL HOTLINE, REMOVE DRAG LIK AND TEST. REMOVE AND REPLACE STEERING GEAR AND ALIGN, RETEST
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 15 * * * * * * * 12728
AWS Claim Key: 3292940 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2006 Doc #:60952604
Cust Comments: REPAIR PER RECALL 59B01
Tech Comments: RECALLED BY FORD MOTOR CO REPAIR AS NEEDED
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 15 7J05 0502XX 4L3Z 9E731 AA H19 42 12728
AWS Claim Key: 3292942 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2006 Doc #:60952602
Cust Comments: ABS LIGHT COMES ON SOMETIMES WHEN DRIVING
Tech Comments: TEST EEC, C1175 C1235 PRESENT, CALL HOTLINE, PINOPINT TEST AND REPLACE REAR SPEED SENSOR ADN RETEST
AWS Claim Key: 3292941 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2006 Doc #:60952603
Cust Comments: REPAIR PER RECALL 05E15
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 15 3A10 070100 5C3Z 7005 E L85 42 12728
AWS Claim Key: 3367360 Trx Code: E84 Labor Hrs: 10.8
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2006 Doc #:60952601
Cust Comments: CHECK FOR TRANS FLUID LEAK
Tech Comments: INSEPCT, ADD DYE, REMOVE ADN REPLACE TRANS PAN GASKET AND RETEST, CASE CRACKED REMOVE TRANS ADN TEAR DOWN, FOUND CRACK IN CASE, REPLACE CASE AND ALL PARTS AS NECESSARY ADN RETEST
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 16 * * * * * * * 12894
AWS Claim Key: 3409537 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:61085502
Cust Comments: RECALL 05B32
Tech Comments: 1 REPAIR AS PER RECALL
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 16 3A04 070102 3C3Z 7J136 BA P66 42 12894
AWS Claim Key: 3409538 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:61085501
Cust Comments: TRANS DOESNT SHIFT RIGHT NO OVERDRIVE HAVE TO REV UP TO 4000 RPM TO GET IT TO MOVE #27 REPLACED TRANS CASE LAST WEEK
Tech Comments: ROAD TEST ADN TEST EEC, NO CODES, TEST LINE PRESSURE AND FLUID ALLOK, TEST CONVERTOR LOCK UP ALL OK TEST EEC, CONFIRM, REMOVE PAN AND CHECK SOLENOIDS, REPLACE SOLENOIDS ADN RETEST
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 22 7H08 12XXXX 6C3Z 19980 AA C05 42 18999
AWS Claim Key: 5536254 Trx Code: E83 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2006 Doc #:64026301
Cust Comments: AC SYSTEM DIED WONT COME ON AT ALL NOTHING ON THE DISPLAY
Tech Comments: TEST CONTROL MOD. NOT RESPONDING. REPLACED AC CONTROL MOD AND RETEST. OK.
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 22 7K11 130101 * 10849 * D02 42 18999
AWS Claim Key: 5536253 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01385 - * Name: SIOUX FALLS FORD LINCOLN MERCURY Ph: 605-3610361 St:SD Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2006 Doc #:64026302
Cust Comments: ENGINE CRANKS SLOW CHECK BATTERIES
Tech Comments: TEST CHARGING SYSTEM. OK. TEST BATTERIES. BAD CELL. REPLACED BOTH BATTERIES. 1
1FTSW21P05EA82644 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 06-OCT-2004 06-NOV-2004 153507 USA 53 1D01 03XXXX 3C3Z 6701 B L65 30 41532
AWS Claim Key: 10828991 Trx Code: E72 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2009 Doc #:535090A
Cust Comments: CUSTOMER REPORTS OIL LEAKS UNDER MOTOR
Tech Comments: 41532 6D083 D8 VERIFIED CONCERN, PERFORMED OIL LEAK DIAG, BLACKLIGHT TEST, FOUND REAR ENGINE COVER LEAKING. REMOVED TRANSMISSION PER ACCESS. REPLACED REAR ENGINE COVER GASKET AND REAR MAIN SEAL(RELATED). CHANGED OIL AND FILTER. REPLACED FILTER CAP, STRIPPED. ROAD TEST VEHICLE ALL OK.
4play is offline
BAF250 (04-09-2009)
