oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2004 Psd, this thread has received 1 replies and been viewed 497 times.
post #1 of 2 (permalink) Old 04-09-2009, 01:49 AM Thread Starter
oasis please
can i get one for
1ftnx21p74eb28883
thanks
04 f250 ext. cab short bed
11-03 engine
4" magnaflow straight pipe
03' turbo
access roll up cover
putco bed rails
spartan tuning
ficm tune by I.D.
2004 Psd is offline
post #2 of 2 (permalink) Old 04-09-2009, 02:34 PM
4play's Avatar
OASIS RESULT:
1FTNX21P74EB28883
USA
EN
04/09/2009
10:33:42
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/18/2003 BUILD DATE
11/08/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
06/27/2008
DEALER: Byerly Ford Inc
WARRANTY CLAIM NUMBER: 395737 ODOMETER: 058556M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
E7TZ 7086A GASKET-TRNS HOUSING 001 6005F1
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005F2
XO 15W40QSD 015 6005F13
000 6005F20
000 6005F6
000 12342D1T
000 9527AL
000 6731A
58556 INSPECTED AND FOU ND ENGINE HYDROLOCKED. PREFORMED VISUAL INSPECTION AND FOUND NO PROBLEMS. CHECK FUEL; OK. CHECK OIL AND LEVEL. OIL WAS A LITT LE OVERFUL. PREFORMED KOEO TEST AND RETRIVED CODE P1000. PREFORMED KEO INJEC TOR TEST AND RETRIEVED NO CODES. REMOVED ALL GLOW PLUGS TO CHECK-VENT . CRA NK OVER ENGINE AND DIESEL FUEL POURED OUT OF CLYINER 4 GLOW PLUG HOLE. REIN
04/07/2008
DEALER: Ray's Ford-Mercury, Inc.
WARRANTY CLAIM NUMBER: 054823 ODOMETER: 049684M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6700BA OIL SEAL CYL FRT COV 001 6007A D8 FAILED GASKET/SEAL
000 6700A
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 18 2H01 030008 4C3Z 6K682 AARM D50 42 13392
AWS Claim Key: 4840764 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2005 Doc #:334239A
Cust Comments: C S AT TIMES ENGINE LOADS UP WITH FUEL BLOWS BLACK SMOKE
Tech Comments: 13400 WARR 42 RAN ENGINE PERFORMANCE SHEET (SEE ATTACHGED) CODE P0299 RAN PINPOINT TEST KA1 CODE P0299 KA2 OIL TEMP OK KA4 .23 VOLTS KA5 ALL PIDS IN SPEC KA6 NO MOVEMENT KA8 MOVEMENT PRESENT INTALLED NEW TURBO ASSM ROADTEST OK
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 21 * * * * * * * 18174
AWS Claim Key: 6464228 Trx Code: 05S34 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:02-AUG-2005 Doc #:340208B
Cust Comments: 05S34 FUEL INJECTOR CONTROL MODULE
Tech Comments: 18180 W 05S34E 1.2 INSPECT AND INSTALL REPAIR KIT AND ICP CONNECTO R
AWS Claim Key: 6325601 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:02-AUG-2005 Doc #:340208C
Cust Comments: 59B01 CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: 18180 W .30 05S34G ROAD TEST ALL OK
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 23 * * * * * * * 19536
AWS Claim Key: 6860055 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:342314B
Tech Comments: 19536 RECALL 59B01 59B01A 0.3 PERFORMED CUST ASSURANCE ROADTEST VEH OK
AWS Claim Key: 6860054 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:342314A
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT
Tech Comments: 19536 RECALL 05E15 05E15F 1.0 PERFORMED RECALL 05E15 INSTALLED EXHAUST PRESSURE SENSOR AND RECALIBRATED MODULES
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 28 2G02 030008 4C3Z 12A690 AA L65 D8 22729
AWS Claim Key: 8737553 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2006 Doc #:351009C
Cust Comments: CUSTOMER STATES OIL LEAKING ON ENGINE
Tech Comments: 22735 D8 3.1 E VERIFIED CONCERN FOUND ENGINE LEAKING OIL. CLEANED ENGINE AND INSTALL OIL DYE. ROAD TEST RAISE ON LIFT AND PERFORMED BLACK LIGHT TEST FOUND OIL LEAKING AT CRANK SHAFT SENSOR AND PASS SIDE GLOW PLUG HARNESS CONNECTERS. R&R CRANK SHAFT SENSOR AND REPLACED O RING REMOVED CAC HOSE AND REPLACED GLOW PLUG HARNES S ,CLEANED ENGINE AND ROAD TEST. CHECK OIL LEVE L.
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 31 2H01 030008 4C3Z 6K682 BA D42 69 23966
AWS Claim Key: 9494217 Trx Code: S07 Labor Hrs: 5
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:25-MAY-2006 Doc #:355358B
Cust Comments: VEHICLE IS LOOSING POWER
Tech Comments: 23976 69 5.0 ROAD TEST VERIFIED CONCERN,CONCERN SAME AS LINE A B. PERFORMED ENGINE DIAG 1 6 RETREIVED CODES P0299. RAN OASIS 511260604, WENT ONLINE AND RETREIVED UPDATED DIAG. TEST KA. PERFORMED TEST KA1 KA10,FOUND TURBO ACTUATOR BINGING IN STEP KA10. REPLACED TURBO. CLEARED CODES AND ROAD TEST.
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 34 6H19 010702 6C3Z 2851222 A B63 33 26471
AWS Claim Key: 10391011 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2006 Doc #:360094A
Cust Comments: RH DOOR OPENING WEATHERSTRIP COMMING APART
Tech Comments: 26471 NECC TO REMOVE WEATHERSTRIP AND INSTALL NEW ONE
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 53 1A01 030102 3C3Z 6049 CARM L65 D8 48097
AWS Claim Key: 12527072 Trx Code: E72 Labor Hrs: 14.4
Dlr Cd-Sub Cd: 05716 - * Name: RAY'S FORD-MERCURY, INC. Ph: 270-4224901 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:26-FEB-2008 Doc #:05421251
Cust Comments: CHUST STATES VEHICLE HAS TWO OIL LEAKS
Tech Comments: DIAG OIL LEAK ADD DYE AND INSPECT FOR LEAKS FOUND OIL LEAKS AT BOTH CYL HEADS AT BACK OF ENGINE REMOVED CYL HEADS CHECK FOR WARPAGE LEFT CYL HEAD WARPED005 REPLACE CYL HEAD GASKETS AND L CYLINDER HEAD COUND EGR COOLER LEAKING REPLACE EGR COOOLER CHANGED OIL AND FILTER TEST DROVE VEHCILE VERIFY REPAIR NO LEAKS FOUND
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 54 1D01 030201 3C3Z 6700 BA L85 D8 49684
AWS Claim Key: 12582033 Trx Code: E72 Labor Hrs: 13.8
Dlr Cd-Sub Cd: 05716 - * Name: RAY'S FORD-MERCURY, INC. Ph: 270-4224901 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2008 Doc #:05482351
Cust Comments: CUST STATES HAS OIL LEAK
1FTNX21P74EB28883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 08-NOV-2003 18-NOV-2003 147523 USA 57 2E03 030402 4C3Z 9E527 BRM D02 42 58556
AWS Claim Key: 12745240 Trx Code: E72 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 05702 - * Name: BYERLY FORD INC Ph: 502-4481661 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2008 Doc #:395737A
Cust Comments: NO CRANK,WHEN RUNNING HAD A PUFF OF SMOKE AND LOST POWER
Tech Comments: 58556 INSPECTED AND FOU ND ENGINE HYDROLOCKED. PREFORMED VISUAL INSPECTION AND FOUND NO PROBLEMS. CHECK FUEL; OK. CHECK OIL AND LEVEL. OIL WAS A LITTLE OVERFUL. PREFORMED KOEO TEST AND RETRIVED CODE P1000. PREFORMED KEO INJECTOR TEST AND RETRIEVED NO CODES. REMOVED ALL GLOW PLUGS TO CHECK VENT . CRANK OVER ENGINE AND DIESEL FUEL POURED OUT OF CLYINER 4 GLOW PLUG HOLE. REINSTALL
4play is offline
2004 Psd (04-10-2009)
