Oasis request please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by EJ Krueger, this thread has received 1 replies and been viewed 575 times.
post #1 of 2 (permalink) Old 04-09-2009, 04:06 AM Thread Starter
1ftnw20p94ec09680
EJ Krueger is offline
post #2 of 2 (permalink) Old 04-09-2009, 02:35 PM
4play's Avatar
OASIS RESULT:
1FTNW20P94EC09680
USA
EN
04/09/2009
10:34:53
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/23/2004 BUILD DATE
01/18/2004 SALE MILEAGE
00198
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
10/21/2008
DEALER: Signature Lincoln Mercury
WARRANTY CLAIM NUMBER: 251886 ODOMETER: 079424M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9A543AARM PUMP ASY-FUEL INJECT 001 6005E 42 DOES NOT OPERATE PROPERLY
3C3Z 9C968AA FUEL PRESSURE REG 001 6005E2
000 6005E3
000 6005E4
000 6005E5
000 6005E7A
000 6005E45
000 6005PA
000 9543A
000 9543AZN
000 9968B
000 6781AUP
VERIFIED ENGINE CRANKS AND WONT START DIESEL ENGINE NO START DIAG KOEO RETRE IVED CODES P1212 P1211 GLOW PLUGS SYSTEM TEST PASSED CK ICP WAS LOW ONLY 10 PSI CK FUEL PSI WAS OK 50 PSI PPT PER DIAG AND RETEST CONCERN STILL PRESENT WAS NEC TO FILL OUT PRIOR APPROVAL FORM AND WAIT FOR APPROVAL ACCESS AND REP LACE HP OIL PUMP FOUND SEALING BALL TO BE MISSING FROM THE SIDE OF THE PUMP
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 5 2A01 031202 4C3Z 6C646 DA D41 68 8547
AWS Claim Key: 1842474 Trx Code: 2 Labor Hrs: 3
Dlr Cd-Sub Cd: 05539 - * Name: SUNRISE FORD Ph: 909-8224401 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-SEP-2004 Doc #:595860A
Cust Comments: CUST STATES TURBO UPPER HOSE BLEW OFF AND DENTED HOOD
Tech Comments: 8549 3.0 INSPECT FOR BLOWN OFF CAC TUBE. FOUND COLD SIDE TUBE BLOWN OFF. REMOVE AIR CLEANER COMPLETE AIR CLEANER ASSEMBLY ALONG WITH DEGASS BOTTLE AND HOSES. REPLACE CAC TUBE WITH UPDATED VERSION. PERFORM KOEO KOER AND ON DEMAND TESTS NO CODES PRESENT. ROAD TEST WITH WDS TO PERFORM MGP TESTS, FOUND TO BE INSPEC AT 21 PSI. REFLASH ALL MODULES TO LATEST CALIBRATION. ROAD TEST
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 5 6Y05 000001 * ESPRCR * A99 82 8547
AWS Claim Key: 1912823 Trx Code: RCR Labor Hrs: 0
Dlr Cd-Sub Cd: 05539 - * Name: SUNRISE FORD Ph: 909-8224401 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-SEP-2004 Doc #:59586056
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 13 2H01 030008 4C3Z 6K682 AARM E29 41 16951
AWS Claim Key: 4927670 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 05485 - * Name: RACEWAY FORD Ph: 909-7841000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2005 Doc #:532165A
Cust Comments: CK ENG LIGHT IS ON
Tech Comments: SET PERF PINPOINT TEST FOUND EBP SENSOR OUT OF SPEC INSTALL NEW EBP SENSOR RECALIBRATE PCM W LATEST CALIBRATION CLEAR CODE ROAD TEST NOTICED EXCESSIVE TURBO NOISE ON DECEL PERF TUBRO BOOST TEST 30LBS OVER BOOST COND CK TURBO FOUND VAINS STUCK REPL TURBO ASSY ROADT EST OK NOW NO CODES
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 14 2G02 030008 4C2Z 12A690 AB L65 D8 17618
AWS Claim Key: 5418950 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 05432 - * Name: RANCHO FORD L-M Ph: 951-6991302 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-MAY-2005 Doc #:41060401
Cust Comments: OIL LEAKING FROM ENGINE
Tech Comments: OIL DYE LEAK FROM GLOW PLUG HARNESSES REPALCED
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 17 2H01 * * * * * * 19455
AWS Claim Key: 6707567 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:06737951
Cust Comments: 05B29 REPLACE AIR COOLING DUCT
Tech Comments: PERFORM RECALL PERFORM AIR DUCT REPLACEMENT.RECALL
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 17 2G05 031405 * RECAL * D36 42 19455
AWS Claim Key: 6707570 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:06737956
Cust Comments: VEHICLE HAS A SURGE PROBLEM SEEMS IT WANTS TO TAKE OFF THEN IT WANTS TO STALL
Tech Comments: OPERATION ALL OK, ROADTEST AFTER PCM UPDATE, OK RETEST EEC OK.
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 17 5U05 110301 F81Z 3E650 AA H45 42 19455
AWS Claim Key: 6707569 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:06737954
Cust Comments: , ESPECIALLY WHEN GOING OVER SPEED BUMPS OR BUMPY ROAD
Tech Comments: INOP. STEERING STABILIZER DIAGNOSIS VIBRATION INSTALL STEERING STABILIZER AND ROAD TEST
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 17 * * * * * * * 19455
AWS Claim Key: 6707568 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 05439 - * Name: FIESTA FORD, INC. Ph: 760-7728000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2005 Doc #:06737952
Cust Comments: 05S34 FUEL INJECTOR CONTROL MOD HARNESS
Tech Comments: PERFORM RECALL PERFORM IDM WIRE HARNESS REPAIR KIT
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 37 * * * * * * * 52973
AWS Claim Key: 11508192 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2007 Doc #:04236051
Cust Comments: 05E15**SPOKE WITH EMILIO**** EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTR OL MODULES RECALIBRATION
Tech Comments: RECALL EP SENSOR, CONNECTOR, AND RECALIBRATION
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 37 1H03 030804 4C3Z 9P456 AF D42 42 52973
AWS Claim Key: 11508193 Trx Code: E72 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2007 Doc #:04236052
Cust Comments: CUST STATES THAT ENGINE LACKS POWER,AND HESITATES, CUSTOMER ALSO STATED THAT ENGINE DOES NOT RUN THE SAME SEEMS TO BE LOOSING POWER ON BOOST GAUGE, WAS GETTING 25 POUNDS OF BOOST AND NOW I
Tech Comments: EGR COOLER ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTNW20P94EC09680 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 18-JAN-2004 23-APR-2004 171152 USA 55 2E06 030008 4C3Z 9A543 AARM D02 42 79424
AWS Claim Key: 12967715 Trx Code: E72 Labor Hrs: 12.8
Dlr Cd-Sub Cd: 11068 - * Name: SIGNATURE LINCOLN MERCURY Ph: 702-4570321 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:21-OCT-2008 Doc #:25188601
Cust Comments: NOW IS A CRANK NO START
Tech Comments: VERIFIED ENGINE CRANKS AND WONT START DIESEL ENGINE NO START DIAG KOEO RETREIVED CODES P1212 P1211 GLOW PLUGS SYSTEM TEST PASSED CK ICP WAS LOW ONLY 10 PSI CK FUEL PSI WAS OK 50 PSI PPT PER DIAG AND RETEST CONCERN STILL PRESENT WAS NEC TO FILL OUT PRIOR APPROVAL FORM AND WAIT FOR APPROVAL ACCESS AND REPLACE HP OIL PUMP FOUND SEALING BALL TO BE MISSING FROM THE SIDE OF THE PUMP WAS NEC TO RR OIL PA
4play is offline
OASIS Request Wildland Ford Oasis requests 2 01-10-2008 07:48 PM
Oasis Request Please shawnrans Ford Oasis requests 1 07-28-2007 03:23 AM
Oasis request POWER STROKE 99 Ford Oasis requests 1 01-03-2007 12:56 AM
OASIS Request Please mxrider39 Ford Oasis requests 4 01-02-2007 12:18 AM
OASIS Request, Please colorado_okie Ford Oasis requests 1 07-17-2006 12:27 AM
