6.4l oasis - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by FordRacing200, this thread has received 2 replies and been viewed 490 times.
post #1 of 3 (permalink) Old 04-13-2009, 03:35 AM Thread Starter
Powered By Ford
FordRacing200's Avatar
6.4l oasis
1FTXW43R08EA87847
very curious about the truck, 08 with 120k miles.
TIA
FordRacing200 is offline
post #2 of 3 (permalink) Old 04-13-2009, 04:31 AM
4play's Avatar
OASIS RESULT:
1FTXW43R08EA87847
USA
EN
04/13/2009
00:30:32
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-450 CREW CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
8L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/23/2007 BUILD DATE
04/05/2007 SALE MILEAGE
08B07
CERTAIN 2008 MODEL YEAR F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM) AND INSTRUMENT CLUSTER (IC)
EXTENDED COVERAGES
0968 - USA 2007 NEW 72/75,000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: FREEMAN BEILFUSS
OPTIONS: $50,DED.,1ST,DY,RNT
EXPIRATION DATE: 04/23/2013
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 01857
ESP CONTRACT START DATE: 04/23/2007
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
11/14/2008
DEALER: Buss Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 159882 ODOMETER: 119736M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8B379B GASKET SET RAD TANK 001 08B06B
PERFORM RECALL
04/30/2008
WARRANTY CLAIM NUMBER: 150140 ODOMETER: 083582M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z25600A58C KIT - SEAT FASTENERS 001 08C01B
INSPECTED WELDS FINE - INSTALLED CLIP PER FSA
1FTXW43R08EA87847 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 05-APR-2007 23-APR-2007 141420 USA 8 1F01 030301 8C3Z 8009 B L87 D8 49792
AWS Claim Key: 300971 Trx Code: 0968D Labor Hrs: 2.7
Dlr Cd-Sub Cd: 01857 - * Name: BUSS FORD SALES Ph: 815-3852000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2007 Doc #:1423341
Cust Comments: C/S CHECK COLING SYSTEM LEAK DRIVERS SIDE BY RADIO LOOSES 1/2 GALLON EVERY 200 MILES ( ADDED BARS STOP LEAK )
Tech Comments: PRESSURE TEST COOLING SYSTEM REPLACE RADIATOR
1FTXW43R08EA87847 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 05-APR-2007 23-APR-2007 141420 USA 11 1G01 030305 8C3Z 8575 B E29 42 68245
AWS Claim Key: 503982 Trx Code: E72 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 00654 - * Name: BAYTOWN FORD Ph: 281-8393300 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2008 Doc #:023728A
Cust Comments: CHECK ENGINE LIGHT ON,LACK OF POWER
Tech Comments: 68245 CK ENGINE FOR CK ENGINE LIGHT & NO POWER.RUN DIAG ON ENGINE6005F 16 ENGINE HAS CODE P0128.RUN THERMOSTAT DIAG.THERMOSTAT IS STUCK OPEN CAUSING ENGINE TO HAVE REDUCIED POWER.R&R THERMOSTAT & REPLACE.REFILL WITH COOLANT & ROAD TEST ALL O..K 6.4 L 6005F 16 ,8575B .4 ,8575B1 2.2
1FTXW43R08EA87847 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 05-APR-2007 23-APR-2007 141420 USA 13 6E01 * * * * * * 83582
AWS Claim Key: 770382 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01857 - * Name: BUSS FORD SALES Ph: 815-3852000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2008 Doc #:1501401
Cust Comments: FSA 08C01 FRONT DRIVERS SEAT BACK INSPECTION AND REPAIR
Tech Comments: INSPECTED WELDS FINE INSTALLED CLIP PER FSA
1FTXW43R08EA87847 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 05-APR-2007 23-APR-2007 141420 USA 20 1F01 * * * * * * 119736
AWS Claim Key: 2009212 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01857 - * Name: BUSS FORD SALES Ph: 815-3852000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:14-NOV-2008 Doc #:1598821
Cust Comments: DIESEL ENGINE COOLING SYSTEM VENTURI TEE
Tech Comments: PERFORM RECALL
4play is offline
post #3 of 3 (permalink) Old 04-13-2009, 04:47 AM Thread Starter
Powered By Ford
thanks a ton!
