Oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jrmmustang, this thread has received 1 replies and been viewed 471 times.
post #1 of 2 (permalink) Old 04-15-2009, 12:21 AM Thread Starter
jrmmustang's Avatar
Oasis report please
vin 1FTSW31P94EA26660
New horse
2003 F-350 Crew Dually 4x4 Auto Cold air intake Silverline stainless 4" turbo back SCT erics x-race,x-street, tow
195k runs good
359.8 hp 6-13-09
14.9-91 mph 7-10-09
SOLD IN ITS PRIME LIVE LONG
1995 CC F-350 292,456 miles auto 4x4 4.10 gears
Intake 4" exhaust 160 cc injectors gauges IDM mod ts redone by "TW" 6 pos
jrmmustang is offline
post #2 of 2 (permalink) Old 04-15-2009, 03:19 AM
4play's Avatar
OASIS RESULT:
1FTSW31P94EA26660
USA
EN
04/14/2009
23:17:59
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
6 SPEED MANUAL AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/16/2003 BUILD DATE
08/06/2003 SALE MILEAGE
00018
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTSW31P94EA26660 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 06-AUG-2003 16-AUG-2003 156483 USA 0 * * * * * * * 5
AWS Claim Key: 4632 Trx Code: TDE Labor Hrs: 0
Dlr Cd-Sub Cd: 03172 - * Name: GLENWOOD SPRINGS FORD-LINCOLN-MERCURY, INC. Ph: 970-9452317 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:14-AUG-2003 Doc #:12961201
Cust Comments: BOTH REMOTE ENTRY FOBS ARE MISSING...A99 DELIVERY RECEIPT #DENL1743492. DAMAGE CODE 28 08 6.
Tech Comments: REPROGRAM KEY FOBS
1FTSW31P94EA26660 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 06-AUG-2003 16-AUG-2003 156483 USA 29 1H03 030008 4C3Z 9F452 A D21 42 73297
AWS Claim Key: 7997332 Trx Code: E72 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 03172 - * Name: GLENWOOD SPRINGS FORD-LINCOLN-MERCURY, INC. Ph: 970-9452317 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:03-DEC-2005 Doc #:17111901
Cust Comments: CUSTOMER STATES THAT VEH WILL INTER STALL AND VEH IS ONLY GETTING NINE MILES TO THE GALLON
Tech Comments: TEST DROVE COULD NOT VERIFY STALL CONCERN. DI DIAG 1 8&13 ALSO PERFORM CYLINDER CONTRIBUTION TEST. FOUND RANDOM MISFIRES. REFLASH PCM,FICM,TCM R&R EGR VALVE DUE TO PERFORMANCE CLEAR CODES TEST DROVE GOOD.
1FTSW31P94EA26660 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 06-AUG-2003 16-AUG-2003 156483 USA 30 2E06 030008 3C3Z 9F838 EA E29 42 78537
AWS Claim Key: 8409532 Trx Code: E72 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 04875 - * Name: ROUNTREE-MOORE INC Ph: 386-7550630 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2006 Doc #:20238801
Tech Comments: DIESEL DIAGNOSIS AFTER CLEARING CODES FOUND PO238 AND P2263 PERFORMED PINPOINT TEST FOUND FAULTY MAP SENSOR. R&R MAP SENSOR. RETEST POWER BACK UP BUT UNSTABLE IDLE. CONTINUED DIAGNOSIS ABOVE AND FOUND FAULTY ICP SENSOR IN LOW STABILITY TEST. R&R ICP SENSOR, REASSEMBLE AND RETEST, OK. WPI
1FTSW31P94EA26660 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 06-AUG-2003 16-AUG-2003 156483 USA 38 * * * * * * * 82323
AWS Claim Key: 10230411 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04967 - * Name: DUNCAN FORD-LINCOLN-MERCURY Ph: 305-2945126 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2006 Doc #:09622005
Cust Comments: RECALL # 06E17 CONTROL MODULE CALIBRATION
Tech Comments: VERIFIED BY OASIS CALIBRATE CONTROL MODULE AS PER FORD INSTRUCTIONS. RECALL COMPLETED.
1FTSW31P94EA26660 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 06-AUG-2003 16-AUG-2003 156483 USA 43 2B01 030707 3C3Z 12K073 AA E29 42 83249
AWS Claim Key: 11180744 Trx Code: E72 Labor Hrs: 8
Dlr Cd-Sub Cd: 04967 - * Name: DUNCAN FORD-LINCOLN-MERCURY Ph: 305-2945126 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-FEB-2007 Doc #:10121701
Cust Comments: CUST. STATES CHECK ENGINE WARNING LIGHT ON & TRUCK SEEMS TO BE RUNNING ROUGH.MAY NEED TUNE UP.CHECK & ADVISE.
Tech Comments: VERIFIED COMPLAINT. PERFORMED DIESEL TEST & FOUND 2 BAD INJECTORS & CRANK SENSOR.REPLACED # 1 & # 6 FUEL INJECTORS & CRANK SENSOR. CLEARED CODES.REPROGRAMED PCM & RETEST,PASSED.
4play is offline
Oasis report please bpogue Ford Oasis requests 1 08-16-2007 04:53 AM
Oasis Report Please cuebird Ford Oasis requests 1 07-28-2007 03:18 AM
OASIS Report Please DSL4x4x4 Ford Oasis requests 2 09-26-2006 12:44 AM
Oasis Report Please kg4bhr Ford Oasis requests 2 09-25-2006 10:47 PM
OASIS report please JD99PSD Ford Oasis requests 1 09-25-2006 11:19 AM
