Oasis Thanks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bigshowdawg, this thread has received 1 replies and been viewed 384 times.
post #1 of 2 (permalink) Old 04-15-2009, 11:03 PM Thread Starter
Oasis Thanks
1FDAW57P46EB81517 Much appreciated!!!!
Bigshowdawg is offline
post #2 of 2 (permalink) Old 04-16-2009, 06:15 PM
4play's Avatar
OASIS RESULT:
1FDAW57P46EB81517
USA
EN
04/16/2009
14:14:42
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-550 CC CHASIS 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
8L ENGINE CALIBRATION
6F710E0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/04/2006 BUILD DATE
11/03/2005 SALE MILEAGE
00058
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FDAW57P46EB81517 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 03-NOV-2005 04-MAY-2006 171069 USA 12 2E03 030402 4C3Z 9E527 AA D13 42 17991
AWS Claim Key: 3520308 Trx Code: S07 Labor Hrs: 6.8
Dlr Cd-Sub Cd: 05556 - * Name: TUTTLE-CLICK FORD LINCOLN MERCURY Ph: 949-4725200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-APR-2007 Doc #:72404701
Cust Comments: CUSTOMER STATES THE ENGINE SEEMS TO IDLE ROUGH. ALSO STATES SOUNDS LIKE THERE MAY BE AIL LEAKING COMING FROM ENGINE COMPARTMENT.
Tech Comments: 3121 MO18001 CC42 CP9E527 PERFORMED ENG. PERFORMANCE TEST 1 14,FOUND STORED CODE P0263 FOR #1 INJECTOR. PER TSB 07 5 4 REPROGRAMMED CONTROL MODULES AND RETEST STILL HAD ROUGH IDLE. PERFORMED CYL BALANCE TEST AND FOUND #1 INJ STILL MISSING. REPLACED INJECTOR AND RETEST OK.
1FDAW57P46EB81517 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 03-NOV-2005 04-MAY-2006 171069 USA 12 7K11 130101 6C3Z 10849 JA L69 42 17991
AWS Claim Key: 3520307 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 05556 - * Name: TUTTLE-CLICK FORD LINCOLN MERCURY Ph: 949-4725200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-APR-2007 Doc #:72404702
Cust Comments: CUSTOMER STATES THE FUEL GAUGE IS NOT READING ACCURATLY.
Tech Comments: 3121 DIAG FOUND INSTRUMENT CLUSTER INFO CENTER NOT READING CORRECTLY.REPLACED CLUSTER AND RETEST PASS.
1FDAW57P46EB81517 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 03-NOV-2005 04-MAY-2006 171069 USA 14 2E03 030402 4C3Z 9E527 AA D21 41 20963
AWS Claim Key: 3767580 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 00602 - * Name: CROWN FORD Ph: 530-2414321 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2007 Doc #:31119101
Cust Comments: CUSTOMER STATES: STALLS WHILE DRIVING. RESTARTED AND DROVE ABOUT .1 MILES THEN DIED AGAIN.
Tech Comments: VERIIFED NO START PERFORM TEST CODES P0266 INSPECT #2 CYLINDER & INJECTOR FOUND INJECTOR STUCK OPEN REPLACE INJECTOR #2 CYLINDER REPLACE PASS SIDE GLOW PLUG BUZ CLEAR CODES RETEST ROAD TEST OK
1FDAW57P46EB81517 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 03-NOV-2005 04-MAY-2006 171069 USA 14 7J05 0502XX 6L3Z 9E731 A H19 42 21978
AWS Claim Key: 4118221 Trx Code: S07 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 05556 - * Name: TUTTLE-CLICK FORD LINCOLN MERCURY Ph: 949-4725200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2007 Doc #:73615801
Cust Comments: CUSTOMER STATES ABS LIGHT HAS BEEN COMING ON AND THEN GO OFF INTERMITTENTLY, DIAGNOSE AND ADVISE
Tech Comments: TECH 3135 CC 42 2219D ABS DIAG PIN POINT TEST C 1236 REPLACE REAR ABS SENSOR CLEAR CODE OK AT THIS TIME
4play is offline
