Looking at buying - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordfanatic69, this thread has received 1 replies and been viewed 529 times.
post #1 of 2 (permalink) Old 04-16-2009, 11:47 PM Thread Starter
Smokin
fordfanatic69's Avatar
Looking at buying
1ftsw21p15ec65406
05 f250
09 F250 Crew Cab FX4
5% tint 35% whole windshield w/5% brow
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
5" Flow Pro No Muffin W/6" tip
Spartan 310
fordfanatic69 is offline
post #2 of 2 (permalink) Old 04-20-2009, 03:59 AM
4play's Avatar
OASIS RESULT:
1FTSW21P15EC65406
USA
EN
04/19/2009
23:58:15
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/24/2005 BUILD DATE
03/03/2005 SALE MILEAGE
00469
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/20/2009
DEALER: Jimmy Granger Ford Mercury
WARRANTY CLAIM NUMBER: 069383 ODOMETER: 099120M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 9527AR
PERFORMED PERFORMANCE DIAGNOSTICS AND ALSO REPROGRAMMED MODULE TO LATEST CAL IBRATION FOR COLD START CONCERN FOUND NUMBER 1 INJECTOR NO OPERATING PROPE RLY, R&R INJECTOR RETESTED AND TEST DROVE VEHICLE 20 MILE NO PROBLEM AT THIS TIME
1FTSW21P15EC65406 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-MAR-2005 24-AUG-2005 123036 USA 1 6N04 010802 5C3Z 16720 EB B66 81 15
AWS Claim Key: 1761816 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2005 Doc #:71403901
Cust Comments: CHECK RIGHT SIDE EMBLEM ......BLACK PAINT PEELING ON
Tech Comments: VERIFY PAINT PEELING ON NAME PLATE REMOVE OLD NAME PLATE CLEAN OFF OLD TAPE TO INSTALL NEW NAME PLATE
1FTSW21P15EC65406 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-MAR-2005 24-AUG-2005 123036 USA 18 * * * * * * * 35502
AWS Claim Key: 6988384 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:77936305
Cust Comments: THE ENGINE CONTROL MODULES ON THE AFFECTED VEHICLES MAY NOT BE CALIBRATED TO THE LATEST SOFTWARE LEVELS AFFECTING PERFOR
Tech Comments: 1 05B35 RECALL
AWS Claim Key: 6988385 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:77936304
Cust Comments: THE COOLANT FILL MARKINGS ON AFFECTED VEH ARE INCORRECT CREATING THE POTENTIAL FOR AN OVER FILL CONDITION
Tech Comments: MAY CAUSE ENGINE OVERHEATING AND MAY CAUSE A LOSS OF ENGINE POWER 05B32 RECALL
1FTSW21P15EC65406 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-MAR-2005 24-AUG-2005 123036 USA 18 2G02 031403 * 12A697 * D13 X2 35502
AWS Claim Key: 6988386 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:77936301
Cust Comments: CUST STATES ON COLD STARTS VEHCILE MISSES RUNS ROUGH THIL WARM
Tech Comments: DIESEL DIAG TEST 1 10 CODE P0112 TRACE AND REPAIR ERRATIC CONN, CONN129 CIR 743 GRAY WIRE LOOM 12A697
1FTSW21P15EC65406 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 03-MAR-2005 24-AUG-2005 123036 USA 42 2E03 030402 4C3Z 9E527 BRM D03 42 99120
AWS Claim Key: 10721850 Trx Code: S07 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 07724 - * Name: JIMMY GRANGER FORD MERCURY Ph: 318-9253333 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2009 Doc #:06938301
Cust Comments: CUST STATES TO CK ENG HARD TO START WHEN COLD ,RUNS ROUGH COLD OR WARM ENGINE REPORT TRK HAS POWERTRAIN WARR.
Tech Comments: PERFORMED PERFORMANCE DIAGNOSTICS AND ALSO REPROGRAMMED MODULE TO LATEST CALIBRATION FOR COLD START CONCERN FOUND NUMBER 1 INJECTOR NO OPERATING PROPERLY, R&R INJECTOR RETESTED AND TEST DROVE VEHICLE 20 MILE NO PROBLEM AT THIS TIME
4play is offline
buying a 6.0 HeffPsDiesel 2003-2007 6.0L Power Stroke 2 02-20-2008 03:27 AM
what should i look for in buying a psd sootman73 1994-2003 7.3L Power Stroke 3 02-05-2008 01:46 AM
Buying Help FrankieC714 5.9L Cummins (2003-2007.5) 6 08-08-2007 02:29 PM
Buying a used 12V Tippy 5.9L Cummins 12 Valve (1994-1998.5) 2 04-21-2007 12:16 AM
Might be buying CTD need help!!!! ryan10 5.9L Cummins (Pre 1994) 14 11-08-2006 11:04 PM
