Oasis Report Please- Thanks in advance - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CoGo, this thread has received 1 replies and been viewed 591 times.
post #1 of 2 (permalink) Old 04-18-2009, 01:36 PM Thread Starter
1FTSW21P06EA91362
[email protected]
CoGo is offline
post #2 of 2 (permalink) Old 04-20-2009, 04:05 AM
4play's Avatar
OASIS RESULT:
1FTSW21P06EA91362
USA
EN
04/20/2009
00:04:35
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/09/2005 BUILD DATE
08/09/2005 SALE MILEAGE
00113
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
08/20/2008
DEALER: Hub City Ford, Inc.
WARRANTY CLAIM NUMBER: 138880 ODOMETER: 026170M
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 001 10654C 42 DOES NOT OPERATE PROPERLY
000 10654C1
000 10200A
42,DOES NOT OPERATE PROPERLY-BATTERY DTC CODES 13WMAC8VSOOOW ACES CODE XG66K TESTED,CHARGED AND REPLACED PASSENGER SIDE BATTERY BAD. ROADTESTED AND RE TESTED,OK.
08/20/2008
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 2504810AAD RECEPTACLE-INST PNL 001 MT2504810 01 BROKEN/CRACKED
BC-2504810, CC-01 VERIFIEDE CONCERN. REMOVED AND INSTALLED NEW PULL-OUT C UP HOLDER & ASHTRAY ASSY M TIME TO REPLACE CUP HOLDER
1FTSW21P06EA91362 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-AUG-2005 09-SEP-2005 123271 USA 4 6N07 010801 * 8200 * B63 33 4235
AWS Claim Key: 259238 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06481 - * Name: HUB CITY FORD, INC. Ph: 337-2334500 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-2005 Doc #:00000202
Cust Comments: CUST STATES CK GRILL LOOSE ON PASS SIDE
Tech Comments: LOOSE GRILL CC33 PART 8200 TITENED BOLTS ON CRILL
1FTSW21P06EA91362 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-AUG-2005 09-SEP-2005 123271 USA 15 5G03 050300 5C3Z 3050 AB C50 42 15417
AWS Claim Key: 2467759 Trx Code: E84 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 06481 - * Name: HUB CITY FORD, INC. Ph: 337-2334500 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2006 Doc #:09643203
Cust Comments: CUST STATES FRONT END SHAKES BADLY HITTING SERIES OF BUMPS MUST SLOW DOWN TO REGAIN CONTROL CODE C50
Tech Comments: CC: 42 ROAD TESTED CHECKED FOR WORN PARTS REPLACED LEFT LOWER BALL JOINT AND HUB SEAL AND DUST SEAL ROAD TEST
1FTSW21P06EA91362 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-AUG-2005 09-SEP-2005 123271 USA 20 5V09 120307 6C3Z 2A451 A C20 42 17797
AWS Claim Key: 3381203 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 06481 - * Name: HUB CITY FORD, INC. Ph: 337-2334500 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2007 Doc #:10530801
Cust Comments: CUST STATES THAT THE AC WHEN STARTED STAYS ON DEFROST HIGH ALL THE TIME
Tech Comments: VACUUM MOTOR CONDITION CODE:42 BODY CHASSIS ELECTRICAL TEST, PINPOINT TEST, PID VALUE, DCL DISPLAY, TRACED WIRING, FOUND A C VACUUM PUMP MOTOR NOT OPER ATING CORRECTLY, REPLACED A C VACUUM PUMP MOTOR, RE RAN QUICK TEST, ROAD TEST, RETEST OK.
1FTSW21P06EA91362 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-AUG-2005 09-SEP-2005 123271 USA 23 7B02 140201 6C3Z 10346 DA A85 42 19257
AWS Claim Key: 4096308 Trx Code: E83 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 06481 - * Name: HUB CITY FORD, INC. Ph: 337-2334500 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:11-JUL-2007 Doc #:11167702
Cust Comments: CUST STATES THAT THE RED BATTERY LITE STAYS ON CODE A85
Tech Comments: ALTERNATER DOES NOT OPERATE PROPELRY 42 10346 VERIFIED CONCERN EST DROVE RAN IDS ONDEMADN TEST NO CODES MONITERED PIDS RAN CHASIS,PINPOINT TEST REPLACED ALTERNATER RETESTED T
1FTSW21P06EA91362 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-AUG-2005 09-SEP-2005 123271 USA 23 7H13 120303 6C3Z 19E624 AA C02 69 19257
AWS Claim Key: 4096309 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 06481 - * Name: HUB CITY FORD, INC. Ph: 337-2334500 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:11-JUL-2007 Doc #:11167701
Cust Comments: CUST STATES CK AC BLOWS COLD THEN HOT, LIKE WHEN YOU ACCERLA TE BLOWS FROM WHEREVER, CODE C02
Tech Comments: BLOWER CONTROL RELAY BINDING 69 19E624 VERIFIED CONCERN TEST DROVE RAN IDS ON DEMAND TEST NO CODES MONITERED PIDS,CHASIS,PINOPINT TEST HOOKED UP AC GUAGES CHECKED FOR LEAKS REPLACED BLOWER RELAY CONTROL RETESTED
1FTSW21P06EA91362 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-AUG-2005 09-SEP-2005 123271 USA 36 6L05 011201 5C3Z 2504810 AAD T50 01 26170
AWS Claim Key: 7051395 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06481 - * Name: HUB CITY FORD, INC. Ph: 337-2334500 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:20-AUG-2008 Doc #:13888002
Cust Comments: CUST STATES CENTER CUP HOLDERS BROKEN WILL NOT STAY TIGHT T50
Tech Comments: BC 2504810, CC 01 VERIFIEDE CONCERN. REMOVED AND INSTALLED NEW PULL OUT CUP HOLDER & ASHTRAY ASSY M TIME TO REPLACE CUP HOLDER
1FTSW21P06EA91362 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-AUG-2005 09-SEP-2005 123271 USA 36 7A01 140101 BXT 65 750 D02 42 26170
AWS Claim Key: 7087552 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06481 - * Name: HUB CITY FORD, INC. Ph: 337-2334500 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:20-AUG-2008 Doc #:13888001
Cust Comments: CUST STATES HAD TO JUMP START CODE D02
Tech Comments: 42,DOES NOT OPERATE PROPERLY BATTERY DTC CODES 13WMAC8VSOOOW ACES CODE XG66K TESTED,CHARGED AND REPLACED PASSENGER SIDE BATTERY BAD. ROADTESTED AND RETESTED,OK.
4play is offline
Oasis report please, Thanks In Advance! parasail Ford Oasis requests 0 11-27-2007 03:38 PM
Oasis report please, Thanks In Advance! parasail Ford Oasis requests 1 09-03-2007 10:53 PM
Oasis report please, Thanks In Advance! parasail Ford Oasis requests 1 06-28-2007 04:56 PM
Oasis report please, Thanks In Advance! parasail Ford Oasis requests 1 06-22-2007 01:42 AM
Oasis report please, Thanks In Advance! parasail Ford Oasis requests 2 04-18-2007 04:09 AM
