OASIS request, please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by djbaines, this thread has received 1 replies and been viewed 578 times.
post #1 of 2 (permalink) Old 04-21-2009, 08:55 PM Thread Starter
1FTNX21PX4ED13994
Thank you!
djbaines is offline
post #2 of 2 (permalink) Old 04-23-2009, 12:56 AM
4play's Avatar
OASIS RESULT:
1FTNX21PX4ED13994
USA
EN
04/22/2009
20:55:39
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
31 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/30/2004 BUILD DATE
04/07/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
09/30/2008
DEALER: Crossroads Ford of Kernersvill
WARRANTY CLAIM NUMBER: 016623 ODOMETER: 079207M
LABOR OP
CONDITION CODE
CONDITION DESC
6051 GASKET CYL HEAD 000 081103A 42 DOES NOT OPERATE PROPERLY
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 081103B
3C3Z 9433BE GASKET SET-MANIFOLD 001 12650D30
4C3Z 9P456AF COOLER - EGR 001 MT081613
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
VERIFIED CUSTOMER CONCERN. PERFORMED KOEO TEST AND RETRIEVED CODES P2263, P0 404, P0401. PERFORMED EGR COMMAND TEST AND TEST FAILED. PERFORMED TURBO BOOS T TEST AND TEST FAILED. PRESSURE TESTED COOLING SYSTEM AND FOUND SYSTEM NOT HOLDING PRESSURE. REMOVED EGR VALVE AND FOUND VALVE STUCK OPEN AND THE INTAK E WAS REAL WET WITH COOLANT. ORDERED EGR COOLER
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 2 1H03 030008 3C3Z 9F452 AC E29 41 3338
AWS Claim Key: 2673802 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03783 - * Name: OTIS FORD, INC. Ph: 631-6534000 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:19-NOV-2004 Doc #:15892101
Tech Comments: 9F452 41 EEC TEST P0402, MONITORED PIDS. REPLACED EGR RETEST OKAY
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 4 5G04 040100 1C3Z 5K483 BB N50 42 5740
AWS Claim Key: 3234800 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03783 - * Name: OTIS FORD, INC. Ph: 631-6534000 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2005 Doc #:16124002
Tech Comments: 1 REPALCED SWAY BAR LINKS 1
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 4 1H03 030008 3C3Z 9F452 AC E29 49 5740
AWS Claim Key: 3234799 Trx Code: E93 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03783 - * Name: OTIS FORD, INC. Ph: 631-6534000 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2005 Doc #:16124003
Tech Comments: EEC TEST P0402, PINPOINT TEST, REPLACED EGR VALVE, CARBONED
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 9 1F03 03XXXX B7A 8287 B L87 01 16020
AWS Claim Key: 5817649 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 03783 - * Name: OTIS FORD, INC. Ph: 631-6534000 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2005 Doc #:17048503
Tech Comments: 8287 01 FILL SYSTEM AND PRESS TEST REPLACED UPPER RAD HOSE CLAMP BROKEN
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 12 * * * * * * * 21657
AWS Claim Key: 7046645 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03676 - * Name: RIVERHEAD FORD LINCOLN-MERCURY Ph: 631-7272200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:14775505
Cust Comments: PERFORM RECALL# 05S34
Tech Comments: FACTORY MODIFICATION COMPLETED RECALL
AWS Claim Key: 7046646 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03676 - * Name: RIVERHEAD FORD LINCOLN-MERCURY Ph: 631-7272200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:14775504
Cust Comments: PERFORM RECALL# 59B01
AWS Claim Key: 7046647 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03676 - * Name: RIVERHEAD FORD LINCOLN-MERCURY Ph: 631-7272200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:14775503
Cust Comments: PERFORM RECALL# 05E15
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 12 3A03 * * * * * * 21657
AWS Claim Key: 7046648 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 03676 - * Name: RIVERHEAD FORD LINCOLN-MERCURY Ph: 631-7272200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:14775502
Cust Comments: PERFORM RECALL# 04B24
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 12 3A04 070102 3C3Z 7J136 AA P59 42 21657
AWS Claim Key: 7046649 Trx Code: E84 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 03676 - * Name: RIVERHEAD FORD LINCOLN-MERCURY Ph: 631-7272200 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:14775501
Cust Comments: CUSTOMER REPORTS DELAY INTO DRIVE AND REVERSE,LONGER THEN NORMAL,ONE ENGAGED,ALL SHIFTS OK
Tech Comments: TEST TRANSMISSION FOR DELAYED ENGAEMENT REPLACE COAST CLUTCH SOLENOID
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 15 5V03 060302 * 2B120 * H02 42 23687
AWS Claim Key: 7891395 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09084 - * Name: STEVEN'S FORD LINCOLN-MERCURY Ph: 631-4751133 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2005 Doc #:038141A
Cust Comments: CUST STATES BRAKES LOCK UP
Tech Comments: 23687 C S BRAKES LOCK UP ROAD TEST TRUCK FOR BRAKES LOCKING UP BRAKES DIDNT LOCK UP PUT ON LIFT AND REMOVE ALL 4 WHEELS AND CHECK BRAKES OK AND CHECK CALIBERS OK NO PROBLEM FOUND
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 16 2H01 030008 * 6K682 * D42 42 24000
AWS Claim Key: 8093289 Trx Code: S07 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09084 - * Name: STEVEN'S FORD LINCOLN-MERCURY Ph: 631-4751133 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-2005 Doc #:038706A
Cust Comments: CUST STATES FUEL MILAGE LOW 16MPG CK AND ADVISE
Tech Comments: CHECK AND CANNOT VARIFY COMPLAINT MON BOOST PSI AMD FIND NORMAL
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 16 1G03 030507 3C3Z 8620 DB N11 30 24661
AWS Claim Key: 8184733 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09084 - * Name: STEVEN'S FORD LINCOLN-MERCURY Ph: 631-4751133 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2006 Doc #:038901A
Cust Comments: CUST STATES BELT NOISEY GENE VERIFIED NOISE
Tech Comments: 24662 BELT CHECKED AND VERIFY NOISE ON COLD START UP FOUND SERPINE BELT TO BE DRYED OUT REMOVED SHROUDS AND FAN ASSEMBLY TO ACCESS BELT R R BELT STARTED AND VERIFY NOISE GONE
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 17 1F03 030304 * 8287 * E23 33 26500
AWS Claim Key: 8454111 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 09084 - * Name: STEVEN'S FORD LINCOLN-MERCURY Ph: 631-4751133 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:039874A
Cust Comments: CUST STATES COOLANT LEAKING FROM CENTER OF ENGINE
Tech Comments: 26564 CHECK CONCERN PRESSURE TEST AND FIND LOOSE CLAMP ON UPPER RAD HOSE.SECURE CLAMP AND TOP OFF COOLANT
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 36 2H01 031202 6C3Z 6C640 C L65 D1 59778
AWS Claim Key: 11986965 Trx Code: E72 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 09084 - * Name: STEVEN'S FORD LINCOLN-MERCURY Ph: 631-4751133 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:20-AUG-2007 Doc #:058207A
Cust Comments: C S OIL HITTING HOOD ABOVE OIL FILTER HOUSING
Tech Comments: 59779 LEAK VERIFIED OIL LEAK PERFORM DYE TEST REPLACE CAC HOSE ON TURBO CLEAN & RECHECK VERIFIED REPAIR PTEFORMED TSB 07 5 15 REPLACED CAC HOSE
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 36 1A04 030103 * 9424 * L85 42 60567
AWS Claim Key: 12121119 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 03840 - * Name: SYOSSET FORD Ph: 516-4969700 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:04-SEP-2007 Doc #:134608A
Cust Comments: CUSTOMER STATES ENGINE LEAKS OIL
Tech Comments: DYE TESTED FOR LEAKS, REPLACE AIR COOLER AND CONNECTOR
1FTNX21PX4ED13994 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 07-APR-2004 30-SEP-2004 113489 USA 49 1A02 030102 * 6051 * E29 42 79207
AWS Claim Key: 12909166 Trx Code: E72 Labor Hrs: 11
Dlr Cd-Sub Cd: 05604 - * Name: CROSSROADS FORD OF KERNERSVILLE, INC. Ph: 336-9963700 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2008 Doc #:01662301
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT IS ON. DIAGNOSE & ADVISE. ALSO FEELS LIKE THE TURBO NOT PRODUCING PROPERLY
Tech Comments: VERIFIED CUSTOMER CONCERN. PERFORMED KOEO TEST AND RETRIEVED CODES P2263, P0404, P0401. PERFORMED EGR COMMAND TEST AND TEST FAILED. PERFORMED TURBO BOOST TEST AND TEST FAILED. PRESSURE TESTED COOLING SYSTEM AND FOUND SYSTEM NOT HOLDING PRESSURE. REMOVED EGR VALVE AND FOUND VALVE STUCK OPEN AND THE INTAKE WAS REAL WET WITH COOLANT. ORDERED EGR COOLER
4play is offline
djbaines (04-24-2009)
Oasis Request 75867586 Ford Oasis requests 4 06-20-2007 10:42 PM
Request OASIS please Mustang50 Ford Oasis requests 1 06-15-2007 02:26 AM
Oasis request please Mustang50 Ford Oasis requests 2 06-15-2007 02:25 AM
Oasis Request Pandiger Ford Oasis requests 0 06-07-2007 05:09 AM
Oasis Request superxcrewfx4 Ford Oasis requests 1 06-07-2007 03:36 AM
