Request before purchasing truck please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fitzy, this thread has received 4 replies and been viewed 583 times.
post #1 of 5 (permalink) Old 04-22-2009, 07:11 PM Thread Starter
1FTWW32P7EC22532.
Thanks to all. Aaron
fitzy is offline
post #2 of 5 (permalink) Old 04-23-2009, 01:03 AM
4play's Avatar
check vin number. needs 17 characters
4play is offline
post #3 of 5 (permalink) Old 04-23-2009, 03:55 AM Thread Starter
well that sucks I guess I am human and made a mistake.
Alrighty here it goes: ZFTWW32P73EC22532
fitzy is offline
post #4 of 5 (permalink) Old 04-23-2009, 05:46 AM
4play's Avatar
ok, i see you missed the "3" or the 10th digit and its for the year 2003, i tried a couple of years to try to correct the missing digit just not the 3. but you may double check vin because you changed the first digit to a "Z" and thats not an option. i put a "1" back up. if this is incorrect let me know.
OASIS RESULT:
1FTWW32P73EC22532
USA
EN
04/23/2009
01:41:04
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/31/2003 BUILD DATE
02/01/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 0 2G05 * * * * * * 2
AWS Claim Key: 1348539 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2003 Doc #:218099D
Cust Comments: PERFORM COLD OPERATION CALIBRATION ENHANCEMENT PROGRAM 03B06
Tech Comments: PERFORM RECALL
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 0 2E01 * * * * * * 2
AWS Claim Key: 1348538 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2003 Doc #:218099C
Cust Comments: PERFORM ICP RECALL 03B05
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 2 2A01 031201 3C3Z 9N622 AA G29 01 7402
AWS Claim Key: 1871234 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:19-JUL-2003 Doc #:221276A
Cust Comments: CONCERN; CHECK AIR FILTER LIGHT IS ON
Tech Comments: INSTALLED AIR FILTER RESTRICTION INDICATOR ON AIR FILTER BOX
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 4 * * * * * * * 13610
AWS Claim Key: 2593062 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2003 Doc #:225476A
Cust Comments: CHANGE ENGINE OIL, FILTER, LUBRICATE (IF EQUIPPED WITH FITTINGS), CHECK FLUID LEVELS AND CHECK TIRE PRESSURE
Tech Comments: CHANGE OIL AND FILTER
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 4 1F06 030304 F6DZ 8100 A L87 D8 13610
AWS Claim Key: 2593064 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2003 Doc #:225476E
Cust Comments: CHECK FOR COOLANT LEAKING
Tech Comments: REPLACE RADIATOR CAP
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 4 2G05 031405 * RECAL * D13 42 13610
AWS Claim Key: 2593063 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2003 Doc #:225476C
Cust Comments: ENGINE RUNS ROUGH ON STARTS
Tech Comments: RAN EEC TEST, ALL PASS CODES, CHECK DCL, REPROGRAMPCM, VEH HAS A ROUGH IDLE ON HOT STARTS, UNPLUGGE D EOT SENSOR, ENGINE STARTS FINE, ADVISED CUSTOMERWAITING ON A FIX FROM FORD
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 7 2G04 031401 * 12A650 * D13 42 19709
AWS Claim Key: 3661513 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2003 Doc #:229875A
Cust Comments: CONCERN: ENGINE IDLES ROUGH ON HOT STARTS
Tech Comments: REPROGRAM PCM PER TSB 3 20 12
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 8 1D01 030008 3C3Z 6701 AA L65 D8 26700
AWS Claim Key: 4378113 Trx Code: E84 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2004 Doc #:233001A
Cust Comments: CONCERN; CUSTOMER STATES IT LEAKS OIL WHEN PULLING A TRAILER HAS DYE IN OIL FROM LAST VISIT
Tech Comments: CHECKED COMPLAINT OF OIL LEAK FROM ENGINE. ADDED OIL DYE PER SSM17252. TEST DROVE AND BLACKLIGHTED ENGINE. FOUND REAR CRANK SEAL AND FRONT CRANK SEALSLEAKING OIL. REMOVED SHROUD, FAN AND STATOR TO RE PLACE FRONT SEAL HAD TO REMOVE DAMPER ALSO. REASSEMBLED. REMOVED AUTO. TRANS AND FLEXPLATE TO REPLACE REAR CRANK SEAL. REASSEMBLED AND TEST DROVE. RECHECKED FOR LEAKS. OK.
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 10 1F06 030304 F6DZ 8100 A D50 D8 32687
AWS Claim Key: 4753791 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2004 Doc #:235204B
Cust Comments: CONCERN;CUST STATES THAT THE AIR FILTER GUAGE HAS BROKEN OFF
Tech Comments: REPLACE COOLANT CAP AND AIR FILTER MINDER UNIT
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 10 5A09 050201 1C3Z 4676 AA L88 D8 33572
AWS Claim Key: 4806518 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:06-MAR-2004 Doc #:235469A
Cust Comments: CHECK FOR A FLUID LEAK AT REAR DIFFERENTIAL
Tech Comments: REPLACE REAR PINION SEAL
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 17 * * * * * * * 75212
AWS Claim Key: 7929230 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:24-SEP-2004 Doc #:248185B
Cust Comments: PERFORM RECALL 04S15.
Tech Comments: PERFORMED RECALL O4S15 PER RECALL INSTRUCTIONS. REPLACED GROUND STUD ON ENGINE. INSPECTED RADIO SUPPRESION STRPA FOR DAMAGE. OK.
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 17 2E06 030008 3C3Z 9F838 EA D21 42 75212
AWS Claim Key: 7929229 Trx Code: E72 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:24-SEP-2004 Doc #:248185A
Cust Comments: CHECK ENGINE DYING
Tech Comments: CHECKED COMPLAINT OF ENGINE DIEING. PERFORMED DIESEL ENGINE DIAGNOSTICS. CHECKED FOR CODES. MONITORED PIDS FOUND ICP TOO HIGH. CHECKED WIRING TO ICPSENSOR. REPLACED ICP SENSOR AND CLEARED CODES. TE ST DROVE AND RECHECKED OPERATION. REPORGRAMMED PCMTO LATEST CALIBRATION LEVEL.
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 20 1D01 03XXXX 3C3Z 6701 AA L65 D8 98561
AWS Claim Key: 9816948 Trx Code: E72 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2005 Doc #:254568B
Cust Comments: CONCERN; CHECK FOR A OIL LEAK AT FRONT OF ENGINE AND AT THE TRANSMISSION
Tech Comments: CHECKED COMPLAINT OF OIL LEAK ON THE ENGINE. FOUNDFRONT AND REAR CRANKSHAFT SEALS LEAKING OIL, CHAR GE AIR PIPING HOSES OIL SOAKED AND LEAKING. REMOVED AUTO TRANS AND REPLACED REAR CRANK SEAL. LACED FRONT CRANK SEAL. REPLACED BOTH CHARGE AIR PIPING HOSES. DEGREASED ENGINE AND RECHECKED FOR LEAKS. TEST DROVE. OK.
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 20 1A05 030104 * 9430 * E41 42 98561
AWS Claim Key: 9853124 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2005 Doc #:254568A
Cust Comments: CONCERN; EXHAUST LEAK
Tech Comments: CHECKED COMPLAINT OF EXHAUST LEAK. FOUND EXHAUST MANIFOLDS LEAKING EXHAUST. REMOVED BOTH EXHAUST MANIFOLDS AND CHECKED FLATNESS. MANIFOLDS NOT FLAT. HAD EXHAUST MANIFOLDS MILLED FLAT. REINSTALLED AND RECHECKED LEAKS. OK.
1FTWW32P73EC22532 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 01-FEB-2003 31-MAY-2003 147067 USA 39 * * * * * * * 194721
AWS Claim Key: 14125535 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2006 Doc #:287464D
Cust Comments: RECALL 06E17
AWS Claim Key: 14125534 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05705 - * Name: RUXER FORD LINCOLN MERCURY, INC. Ph: 812-4821200 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2006 Doc #:287464C
Cust Comments: RECALL 59B01
4play is offline
post #5 of 5 (permalink) Old 04-24-2009, 03:46 AM Thread Starter
you're the bomb man. Thanks
fitzy is offline
purchasing II 62/70 strokin6L 2003-2007 6.0L Power Stroke 73 04-13-2009 12:09 AM
Help please !! Purchasing an '08 supr87gt 2008-2010 Body & Suspension 12 01-28-2009 03:52 PM
Purchasing a used 7.3 powerstroke2003 1994-2003 7.3L Power Stroke 2 08-08-2007 04:09 AM
purchasing paint hhrecovery The Detailing, Paint & Bodyshop 19 10-03-2006 11:44 PM
Need help purchasing new rig I10HaulR Medium and Heavy Duty 20 02-06-2006 04:39 AM
